3rd Gen. Tacoma Front, Rear Camera, Navigation Bypass, Homelink, Smartphone Mirroring Mod.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hoangde, Jan 31, 2017.
  1. Aug 3, 2017 at 11:05 AM
    #161
    Nov8tr
    Nov8tr Member
    2017 Taco RWD Extended Cab Sport
    I can not attach an STL file to this forum or in a conversation. Send me your email address and I'll get you the files.
  2. Aug 15, 2017 at 5:42 PM
    #162
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    Hi @Hoangde
    Do you have a schematic of the 24 pin connector labeled for each pin like you have for the 28 pin connector?
    Thanks!
  3. Aug 15, 2017 at 8:53 PM
    #163
    Hoangde
    Hoangde [OP] Well-Known Member
    Yes,
    And sorry for now , I am out of town at this moments. All my docs at home.
    If my memory still good then pin 12 and 24 are for video signal. Pin 11 and 23 are for power.
  4. Aug 30, 2017 at 8:36 PM
    #164
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I skimmed over this thread, awesome stuff.
    I want to do this without but the "any time camera" button - I just want to use a single switch. I want to keep the rear camera as the default to come on in reverse but be able to toggle the front and rear camera off and on when ever Id like.
    I didnt see anything in this thread like that. Any suggestions?
  5. Aug 31, 2017 at 12:49 PM
    #165
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Yup, check page 1 post 8
  6. Aug 31, 2017 at 1:09 PM
    #166
    steveo27
    Pittsburgh
    Thanks. I was staring at the last night for a lil bit. I'll have to stare at it again. Any time camera was mentioned so I don't think I thought much of it since I don't want an any time rear camera
  7. Sep 1, 2017 at 7:49 PM
    #167
    steveo27
    Pittsburgh
    I stared at post #8 and Im still not seeing it.
    Did some more thinking and brain storming.
    I plan on using 2 aftermarket cameras. I want the rear camera to be the default and come on when ever the truck is in reverse. I want to be able to toggle the front and rear cameras on any time as well using a DPDT switch...
    I came up with this.
    Does this make sense?
  8. Nov 5, 2017 at 5:13 PM
    #168
    Snakedoctor
    Snakedoctor Well-Known Member
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Mandatory tint, in-channel visors, and 265/75R16 MT Toyos.
    Is the front camera image reversed on the camera you chose? It says reversed so is it backwards?
  9. Nov 14, 2017 at 5:16 PM
    #169
    Arrampico
    Arrampico Well-Known Member
    Dan
    2018 4Runner SR5
    2017 SR5 Silver DCSB 4x4 V6 (RIP - Traded-in for T4R)
    Ok, dumb question, but I did not see it asked already, please don't crucify me....wondering if anybody here might already know the answer.
    If I just buy this pre-made harness (lazy) for just creating the anytime back-up camera https://www.anytimebackupcamera.com/product-page/camera-override-dongle-28-position-1 will my back-up camera still automatically display when I shift into reverse without pressing with the switch?
    Thank you in advance,
    Dan
  10. Nov 14, 2017 at 5:33 PM
    #170
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Yes the override basically just activates the camera and brings up the display. Still functions as it should in reverse.
    Arrampico[QUOTED] likes this.
  11. Nov 14, 2017 at 6:27 PM
    #171
    Arrampico
    Dan
    2018 4Runner SR5
  12. Nov 22, 2017 at 10:41 PM
    #172
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    I bought a backup anytime mod setup brandon was selling a while back. It uses the diode. Trying to install my front cam and trying to figure out how to get it power. Before my truck catches on fire, can I wire the power to the Red 1 on the Mictuning switch to power the camera and the backup anytime mod at the same time?
  13. Dec 21, 2017 at 7:36 AM
    #173
    ra29dreams
    ra29dreams Well-Known Member
    Jacksonville, FL
    2017 Tacoma TRD Off-Road
    ABec23 Since this is a SPDT switch, how exactly does this activate? Hoangde's setup you activate the anytime switch first, then toggle between front and rear. Since yours is a SPDT and not a DPDT, I'm a little lost.
  14. Jan 17, 2018 at 10:15 PM
    #174
    Istan
    Stan
    Vegas and Yuma
    Just making sure I get this right. I have the mini dpdt switch. The middle prongs are the ones that need to go to the head unit and the upper and lower prongs are for the two different signals correct?
    Like below?
  15. Jan 18, 2018 at 3:34 PM
    #175
    Nov8tr
    Nov8tr Member
    The DPDT switch I use is an "On/Off/On" type (there is actually 3 positions the switch can be used in), so in the above example you could have both of the fans off, if the switch were left in the middle position.
  16. Feb 17, 2018 at 12:34 AM
    #176
    Nermac89
    Nermac89 Well-Known Member
    2016 Magnetic Grey Tacoma TRD
    how do you get the guidelines in the front display? is that based on what kind of camera you have?
  17. Feb 17, 2018 at 6:28 AM
    #177
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    Kind of an aside question, does anyone have a suggestion for fuse size for the front camera? I have the inewcow one that fits in the Toyota logo.
  18. Feb 17, 2018 at 6:50 AM
    #178
    Imagesetc
    Imagesetc Shock Stormtrooper
    Monterey Park, 2nd Best City to live in USA
    2017 Sup White 4x4 TRD Sport LB
    Runner, Rola Rack,Front/Rear bed cam,Pop N Lock
    Camera doesn't take much to work. Any will do, I used add-a-fuse and tapped power off the fuse labeled S/Roof. Guessing that means sunroof which I don't have.
  19. Apr 28, 2018 at 11:40 AM
    #179
    Snowtrooper17
    Snowtrooper17 Well-Known Member
    Colorado
    '17 White TRD OFFRD V6 4x4 ACLB
    I just wanted to say thanks here to @Hoangde for creating this thread and providing lots of good info and schematics for this mod. I completed mine back last June and have really enjoyed the Rear Cam anytime, a Front Facing Cam, and Navigation Bypass. I've not done a write-up yet as of this posting but hope to include one eventually linked/in my build thread. :bowdown:
    Hoangde[OP] likes this.
  20. Apr 28, 2018 at 7:44 PM
    #180
    TurdOR89
    TurdOR89 Well-Known Member
    2017 Black TRD OFF ROAD DOUBLE CAB LONG BED
    Is there a video on how to do this? Not good at electronics.
