3rd Gen Tacoma HAI's Cable Assy. for Front/Rear Camera Anytime, Navigation Override, Smartphone Mirr
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Hoangde, Jul 18, 2017.
  1. Nov 17, 2017 at 6:57 PM
    #181
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Soooo, I pulled a tonered. Measure once, cut twice, I say. Thankfully and purposefully, the override switch is in a hidden spot.
    Use the upper hole in the pic. The lower hole will ride on wire bundles under the steering wheel. A 1/4in drill bit is the perfect size.
    Routing from the passenger side.
    Drivers side. I need to get a stick on zip tie mount for the wire over the heater outlet.
    Switch. I fed the wire on the right side of the adjustment lever.
    Loving the location. Thanks for the tip!
  2. Nov 17, 2017 at 7:58 PM
    #182
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I used a step bit and drilled it in place. Feeding the switch through was tricky. Good idea to remove the steering column cover.
    REDNECKTEX and tonered[QUOTED] like this.
  3. Nov 17, 2017 at 8:22 PM
    #183
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm a danger mainly to myself. Ha!
  4. Nov 18, 2017 at 3:18 AM
    #184
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    Finally got around to the front cam, this is awesome!! Just did some testing for now, where are you guys going through the firewall on the passenger side? I’m assuming one of these guys?
    Test shots in the garage, socket for reference. This is gonna be a huge help seeing over that hood!
    Night shot, not bad at all!
    REDNECKTEX, Hoangde[OP] and tonered like this.
  5. Nov 18, 2017 at 8:16 AM
    #185
    My Truck
    My Truck Well-Known Member
    Bay Area, CA
    2016 SR DCSB 4x4 Super White`
    Which camera did you go with? Link?
    REDNECKTEX likes this.
  6. Nov 18, 2017 at 8:52 AM
    #186
    dskakie
    Dan
    Northern CA
    2016 TRD OR DCSB
    iNewcow Car Front View Logo Embeded Camera For Toyota with CCD Waterproof IP67 Wide Degree (Middle) https://www.amazon.com/dp/B00P2EN5J2/ref=cm_sw_r_cp_api_vrgeAb4247YMP
    This was actually the second cam I ordered. The first was also from Amazon but the fit was kinda wonky w the Pro grill. This one should pop right into the Toyota “T” logo per their photos, I’ve just got it between the boxy portions of the Pro with washers and it’s been fine.
  7. Nov 18, 2017 at 9:03 AM
    #187
    My Truck
    Bay Area, CA
    Thanks
  8. Nov 18, 2017 at 10:12 AM
    #188
    dilbert
    dilbert AI Member
    PNW
  9. Nov 18, 2017 at 4:56 PM
    #189
    dilbert
    dilbert AI Member
    PNW
    Here's the camera image from that mounting location. I had to cut the green wire to reverse the mirror function. The object on the ground is where the front of the license plate bracket is, is seems to line up perfect with the red zone. The guide lines work pretty good.
  10. Nov 18, 2017 at 7:22 PM
    #190
    Hoangde
    Hoangde [OP] Well-Known Member
    dilbert likes this.
  11. Nov 20, 2017 at 9:09 AM
    #191
    bstrange
    bstrange Well-Known Member
    2017 Tacoma Off Road
  12. Nov 20, 2017 at 9:21 AM
    #192
    dilbert
    dilbert AI Member
    PNW
    I took it apart (4 little screws), filled it with silicone, and reassembled with loctite on the screws before installation. We're getting heavy rain this week, I'll see how it does. I also put dielectric grease on the plug connections and taped them up.
  13. Nov 20, 2017 at 9:50 AM
    #193
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    anyone figure how to wire in a factory camera in the front?
  14. Nov 20, 2017 at 7:18 PM
    #194
    CortezJB
    CortezJB Well-Known Member
    Juan
    San Francisco
    2017 Tacoma TRD Sport
    NADA
    Can some one show pictures of your front camera wiring ?
    I connected mine but no image comes up.
    Thank you
  15. Nov 20, 2017 at 7:41 PM
    #195
    dilbert
    dilbert AI Member
    PNW
    It should just be power, ground, and and then the yellow video RCA cable to the matching one on the HAI cable with a barrel connector between them.
    Any photos of what you have that isn't working?
  16. Nov 20, 2017 at 7:57 PM
    #196
    CortezJB
    Juan
    San Francisco
    NADA
    Thank you, I appreciate it very much!!
  17. Nov 20, 2017 at 9:06 PM
    #197
    CortezJB
    Juan
    San Francisco
    NADA
    Again thank you.
    Here it is what I have
    For testing, I am powering camera from the 12v socket at the front panel. It has a 3 amp fuse in it. When power is good it has a green circle illuminated, if not good it would have a red circle (circle is green)
    Red wire to red white to black.
    Yellow RCA female out from camera goes into yellow RCA male, and power (red) is also connected.
    Rear any time camera is working fine. Camera switch works nice
    When transitioning to front camera,
    Audio, to Source to A/V = screen does not shows image or video!
    I don’t understand what could be wrong!
    Perhaps you see something g I am not able to figure out
    Thank you!
  18. Nov 20, 2017 at 9:22 PM
    #198
    Hoangde
    @CortezJB
    From your images, you are using a cigarette charger from your old charger and cut-out the tip. The cigarette charger may only provides 5 vdc only and your camera may required 12 vdc. If that the case then your Camera never power on at all.
    Please use 12 vdc to power on Camera.
  19. Nov 20, 2017 at 9:39 PM
    #199
    CortezJB
    Juan
    San Francisco
    NADA
    I also conected the power cable straight to the battery but it did not work ither.
    Any thoughts?
  20. Nov 20, 2017 at 9:50 PM
    #200
    Hoangde
    Do you have any device that you can input video signal such as media player with composite output, home dvd player, surveillance cameras for home...etc. If so then you can input the signal to verify.
    As of right now, two scenarios:
    Bad Camera or damaged cable...
    Upon using other device to input video signal, you can decide which one is bad.
