3rd Gen Tacoma HAI's Cable Assy. for Front/Rear Camera Anytime, Navigation Override, Smartphone Mirr
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Hoangde, Jul 18, 2017.
  1. Jan 26, 2018 at 2:43 PM
    #321
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    Mine is more than long enough to get to the left side console if I wanted it to. In fact I have it coiled under my driver seat for right now until I can drill the hole under the steering wheel.
    I also have more than enough AV cable to reach anywhere in the front of the cab.
    tonered likes this.
  2. Jan 26, 2018 at 3:43 PM
    #322
    Frito
    Frito Well-Known Member
    Wow ! Not so here but I removed the head again this afternoon and re-routed the switch and toggle wires to the left.
    Much easier too, a lot more room there, I bet you could fit a small boys arm in there ! All is well.
    tonered likes this.
  3. Jan 26, 2018 at 3:49 PM
    #323
    Frito
    Might have zeroed in on part of the problem at least, my toggle connections were a little hinkey. Spent some time with that this afternoon.
    Anyway, things seem to be OK for the moment even if the GPS had me one street over from where I was.... eww boy.
    Word to the wise ?
    Forego the factory Nav and spend the saved money on an aftermarket unit.
    Entune Nav sux.
    tonered[QUOTED] likes this.
  4. Jan 26, 2018 at 3:50 PM
    #324
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am sorry to report that the voice and location were spot on for the drive home. It even rerouted me for traffic updates with Entune active. I was also listening to music over BT at the same time.
    If there is anything more that I can do to help, please let me know.
  5. Jan 26, 2018 at 3:52 PM
    #325
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's what my Wife sez!
    Frito[QUOTED] and bigchrisz1 like this.
  6. Jan 26, 2018 at 3:52 PM
    #326
    Frito
    Well.... one thing you can do is quit rubbing it in ! :rofl:
    Only kidding, I appreciate all your help (so far :rolleyes:) and glad things are working the way they should in your rig.
    I was on the fone with Crutchfield this afternoon.....
    Rique and tonered[QUOTED] like this.
  7. Jan 26, 2018 at 3:53 PM
    #327
    Frito
    Heh, heh, heh....
  8. Jan 26, 2018 at 3:54 PM
    #328
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Dammit! I was gonna rub it some moar!
    Dang. Crutchfield is a bad place to put near your wallet.
  9. Jan 26, 2018 at 4:17 PM
    #329
    Frito
    Bring it on ! I got big shoulders ! :D
    Yeah ! Kind of like this whole TW site !
  10. Jan 26, 2018 at 5:05 PM
    #330
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hahaha!
    Yeah, TW is special.
  11. Jan 27, 2018 at 3:54 PM
    #331
    Duroo
    Duroo Member
    2016 Black Tacoma TRD Offroad Access Cab
    Got mine in the mail yesterday and installed it today. It was very easy following the YouTube video instructions. I routed all the wires down to the left, coming out to the right of the gas pedal. I ran the two black wires for the rear camera switch to the blank switch hole below the headlight switch, and hooked them up to a rear camera switch from ch4x4. I couldn't decide on a good spot for the bypass switch, so it is on and hidden for now. I got a cheap media player off Amazon and have it hooked up to the av input. So far everything is working great and as expected. If I had to try and find any negatives about the experience it would be that the two black wires for the rear camera switch are hard to strip for some reason, like the insulation didn't want to come off. But other than that it was an easy install. Very happy!
    tonered likes this.
  12. Jan 27, 2018 at 4:00 PM
    #332
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I haven't tried to strip those wires yet, but speaking of stripping, the strippers that you can see on the floor in my post below are just awesome:
    https://www.tacomaworld.com/threads...erride-smartphone-mirr.501617/page-14#post-16
    I've used them on everything from romex to fine gauge wire. They take a ton of frustration out of that. I think they were less than $20?
    Frito likes this.
  13. Jan 27, 2018 at 5:17 PM
    #333
    Hoangde
    Hoangde [OP] Well-Known Member
    Here is the detail of these black wires.
    These wires are mil-spec and the best of its class. Very expensive wires but since i have in stock so you have them.
    Once stock is depleted, cost less wires will be used.
    Also red silicon tape used on the harness. It is Mox tape which
    "They bond irreversibly to provide an insulative barrier that is resistant to moisture, oxygen, ozone and corona over a wide temperature range (-65 to 500 deg F). Arlon STD silicone tapes provide superior electrical insulation with a dielectric strength of 300 VPM minimum at 356 deg F."
    BountyOR_VF2, Duroo and tonered like this.
  14. Jan 27, 2018 at 6:47 PM
    #334
    Duroo
    Duroo Member
    They do look like really high quality wires. You did a great job, thank you!
    tonered likes this.
  15. Jan 27, 2018 at 7:19 PM
    #335
    Frito
    I have a pair of those... Excellent kit !
  16. Jan 28, 2018 at 2:57 AM
    #336
    chasem
    chasem New Member
    Does anyone know if these will work in the current Australian hilux?
  17. Jan 28, 2018 at 9:19 PM
    #337
    top6491
    top6491 Active Member
    San Diego, CA
    2017 White TRD Off-Road 4x4
  18. Jan 28, 2018 at 10:09 PM
    #338
    Hoangde
    Thanks Mark.
    All,
    Ready to accept order again. Please do paypal and pm me your address.
    - To Members who paid last week, package is ready to go to Post Office. Will pm on Monday afternoon for tracking number.
    Thanks,
    Updated.. Monday 1/29/2018
    Package shipped. Please check your pm for tracking number.
    Estimated Delivery Date: Wednesday 01/31/2018
  19. Jan 29, 2018 at 11:05 AM
    #339
    RandyRiot
    RandyRiot Well-Known Member
    Randy
    Los Angeles, CA
    2016 Tacoma TRD Sport
  20. Jan 29, 2018 at 5:54 PM
    #340
    top6491
    San Diego, CA
    PM sent
