3rd Gen Tacoma HAI's Cable Assy. for Front/Rear Camera Anytime, Navigation Override, Smartphone Mirr
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Hoangde, Jul 18, 2017.
  1. Feb 12, 2018 at 8:20 PM
    #361
    UplandExplorer
    UplandExplorer Level of crazy: Chukar Hunter
    Turbine Tommy aka Mr.Pickles
    Nor Cal
    2017 White TRD OR DCSB
    mud, bugs, feathers, and dog hairs.
    Is a switch needed for the Navigation speed bypass? Can you simply cut the speed sensor wire (Pin 17)?
    Sorry if this was addressed already....I didn’t see it.
  2. Feb 12, 2018 at 9:01 PM
    #362
    Hoangde
    Hoangde [OP] Well-Known Member
    Switch MAY needed on some Taco if Navigation didn't acquire GPS signal fast enough.
    Meaning if you are not plan to use Navigation, don't care or don't have Navigation system then don't need switch.
  3. Feb 13, 2018 at 11:56 AM
    #363
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    you have any more of these for sale?
  4. Feb 13, 2018 at 1:24 PM
    #364
    Hoangde
    Go ahead with Paypal then pm me for your address.
    I will build the cable harness, ship and pm you for tracking number.
    Regards,
  5. Feb 19, 2018 at 8:20 AM
    #365
    Garrito-Burrito
    Garrito-Burrito Active Member
    Garret
    Eureka, CA
    2017 Tacoma TRD OR
    OEM Roof Rack, Metal-Tech bolt on sliders, Total-Chaos bed stiffeners, Kicker tweeters and door speakers (Noico sound deadener in doors), AT Habitat w/ DIY LED interior lighting, Hefty Fab aluminum front bumper w/ Smittybilt 9.5k winch, Genesis dual battery kit, Expedition Essential TPAM, MobTown full skid set, Pelfreybilt gas tank skid
  6. Feb 19, 2018 at 9:56 AM
    #366
    Hoangde
  7. Feb 20, 2018 at 11:11 AM
    #367
    941taco
    941taco Member
    Can the AV speed override be wired to an OEM style switch as well? Maybe a dual purpose switch?
  8. Feb 20, 2018 at 11:16 AM
    #368
    Hoangde
    Any on/off switch will do the job.
  9. Feb 20, 2018 at 12:58 PM
    #369
    941taco
    941taco Member
    And just to confirm most people just leave it on and hide it away with no problem with the nav?
    I sent you payment and address in the notes. Thanks again
  10. Feb 20, 2018 at 1:02 PM
    #370
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I mounted the switch under the steering column. I need to switch it to enable the speed sensor to use navigation, the voice guidance won't start with the speed switch disabled - even though the map will still update with my current location.
    tonered likes this.
  11. Feb 20, 2018 at 1:14 PM
    #371
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just to note that in my case, everything works great with the switch on override permanently. It could have something to do with the option packages, different model years, or ??
    @941taco Test it out for a day or two and see how it acts. It takes a 10min or so drive for the navi to start updating after you flick the switch. After that first wait, it is immediate until the switch is flipped off.
    dilbert[QUOTED] likes this.
  12. Feb 20, 2018 at 1:18 PM
    #372
    dilbert
    dilbert AI Member
    PNW
    Have you tried using the navigation with a destination selected? Mine keeps repeating "Proceed to the highlighted route and the the voice guidance will begin" (or something similar to that) while I'm driving along the highlighted route on the map.
    tonered[QUOTED] likes this.
  13. Feb 20, 2018 at 1:25 PM
    #373
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes (and sorry!). It has given me accurate voice guidance and has even updated both the display and guidance due to traffic.
    Depending on cell coverage and such, I have been bouncing between it, Waze, G-maps, and my offline map app (CoPilot GPS). The part that puts the Entune navi in the mix is the breadcrumbs and the decent sync with the phone data. They help me a lot because I am extremely navigationally challenged.
    dilbert likes this.
  14. Feb 20, 2018 at 1:29 PM
    #374
    dilbert
    dilbert AI Member
    PNW
    That's not fair! :pout:
  15. Feb 20, 2018 at 1:31 PM
    #375
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hear you. I am usually not that lucky!
    I was just out solo on some forest service roads and felt a lot of confidence with this layered system. I might not have attempted it alone otherwise.
  16. Feb 20, 2018 at 2:11 PM
    #376
    941taco
    941taco Member
    I would go to the dealer and tell them the head unit is freezing and you would like to update to the latest software. The only variation i can see would be the software revision since you have like hardware.
    I'll install and test when i get mine. Hoping for smooth operation and never having to touch the switch ever. I don't use the nav just look at the map anyway, but i don't like the thought of lost functionality
  17. Feb 21, 2018 at 9:09 AM
    #377
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Can you elaborate on this? I use my front camera for wheeling but hate that it cuts out my FM and XM music.
    ebbs15 likes this.
  18. Feb 21, 2018 at 8:51 PM
    #378
    Hoangde
    There are numerous way to input video signals into HU. Allow me to explain 2 common ways that everybody can understand:
    1. Tap into Rear Camera signal and use switch to toggle between Rear or Front Camera signal. The advantage is only video is changing, audio still playing such as AM/FM/XM ...etc. Disadvantage is complicated and required hand on soldering, no other source can be use such as media player or smartphone mirroring. Kit may available from other Vendors which built from my design and may cost few hundred dollars. ...etc.
    2. Use A/V as an input for video signal to the HU. The advantage is simple, easy to prep. and can be use as smartphone mirroring, front camera signal or media player ...etc. Disadvantage is upon selected A/V option, only audio can hear is from input from RCA jack, not from AM/FM/XM.
    Or you can have both like my TACO, use option 1 for Front Camera and option 2 for others.
    I only do option 2 online for our members due to materials availability and easy plug and play. If you are near me, I can help you to do both.
    tonered and PNWTacoma[QUOTED] like this.
  19. Feb 21, 2018 at 10:11 PM
    #379
    krock72
    krock72 New Member
    Kevin
    2018 taco trd sport
    Would love to get one as well, if yes I will follow paypal instructions from post #366, Thanks in advance
  20. Feb 21, 2018 at 10:46 PM
    #380
    Hoangde
    Yes, do paypal and pm me your address. Will ship out via usps with tracking number.
    Thanks
