3rd Gen Tacoma HAI's Cable Assy. for Front/Rear Camera Anytime, Navigation Override, Smartphone Mirr
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Hoangde, Jul 18, 2017.
  1. May 9, 2018 at 12:21 PM
    #501
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    I too have been looking at this (I just haven't gotten the rest of my project off the ground) and started down this very path. I actually had @Hoangde build my cables loose without the switch. The problem I find is getting appropriate switches that fit in with the purpose/Tacoma. I have thought about double switching.... first to enable 'anytime' and second to determine which camera is selected. Another idea was to go to an ON/ON configuration to avoid that middling issue you have. Of course you have to avoid the plethora of (ON)/(ON) and ON/(ON) configurations. I know I have seen click select buttons like this, I just need to find one. I'm trying to avoid doing an arduino project to solve this simple concept. So many ways to do this....
  2. May 9, 2018 at 12:44 PM
    #502
    Logistics91
    Logistics91 Well-Known Member
    JJ
    2017 Quicksand Tacoma TRD OR
    Switch Pros/sPOD = Problem solved
  3. May 9, 2018 at 3:42 PM
    #503
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Those might work for power control or signal control (limited to two) but not signal switching which is what is happening here. Also, $600 recommended solution for a $20 problem.
    tonered likes this.
  4. May 9, 2018 at 4:18 PM
    #504
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    With a relay installed on the video inputs you could use a single DPDT switch (ON -OFF-ON) and still have reverse video operate as normal in the OFF position.
    Tacomavkk and Logistics91 like this.
  5. May 9, 2018 at 6:39 PM
    #505
    Tacomavkk
    Tacomavkk Well-Known Member
    Woodinville, WA
    2018 TRD Off-road DCSB Quicksand
    Cool - yes my cables were built without the switch also. For me in the end one switch to rule them all wins. :)
  6. May 9, 2018 at 11:48 PM
    #506
    Hoangde
    Hoangde [OP] Well-Known Member
    I am back. Was out to El Mirage for assignment.
    Anyway, if you have Hai Cable Harness and Add-On cable. Now you have dpdt switch and wanted to combine "Anytime Camera" with dpdt switch then pm me. i will explain how to do it (the way @Tacomavkk wanted which R gear kick in Rear camera automatically regardless dpdt postion and able to control F/R camera manually).
    You will needed additional parts you can get from eBay for a few dollar.
    Again, I am not recommended or will build that kind the cable but I will explain via pm and parts as needed. Do it at your own risk and you need at least cut and splice a few wires.
  7. May 11, 2018 at 9:24 PM
    #507
    Hoangde
  8. May 12, 2018 at 7:18 PM
    #508
    Vulteiv1
    Vulteiv1 Active Member
    Vince
    2018 trd sport
    Pm sent
    Hoangde[OP] likes this.
  9. May 14, 2018 at 6:47 PM
    #509
    Sgthawker
    Sgthawker Member
    2017 Silver Tacoma Double Cab TRD Sport 4 x 4
    PM sent. Thanks, again!
  10. May 14, 2018 at 9:04 PM
    #510
    Hoangde
    Sold out earlier.
    Will build one for you and ship out. Thanks
  11. May 18, 2018 at 9:30 PM
    #511
    slowboater
    slowboater Well-Known Member
    This switch doesn't fit into the opening on the right side of a 2016+. Ask me how I know....
    It's too large.
  12. May 19, 2018 at 1:44 PM
    #512
    novel
    novel New Member
    I would like a HAI cable assy. and a Add-on cable Assy. Are those available for order?
  13. May 19, 2018 at 1:55 PM
    #513
    Hoangde
    Pm'd
  14. May 19, 2018 at 11:29 PM
    #514
    Hoangde
    ALCON,
    So many requested from members so I will roll back to my old design for Add-On cable. You are no longer required to have dpdt switch. All you have to get is a push switch as below from:
    ebay (searched for)
    Amazon (searched for)
    Aironboard
    or any place as you wish.
    So basically when the switch is UN-PRESSED, the rear camera is connected and selected.
    When the switch is PRESSED, the front camera is power on and selected.
    For this old design Add-On cable, the donation is $70.00 (cost more for the part installed in Add-On cable). I will also included the Mini Fuse tap (see below) in the package so you do not have to purchase separately.
    So, for Add-On cable, all you have to do is donate $70.00 (due to parts cost more) and buy a Camera push switch (links above for you to buy).
    To all the people received the Add-On cable before, I can pm you the wiring diagram so you can DIY (if you wanted). Just pm me.
    Best regards,
  15. May 20, 2018 at 7:58 AM
    #515
    slowboater
    Sorry @Hoangde , I'm not sure I understand. With the new wiring (above) how does it work? Only 1 switch? Sorry for not understanding.
  16. May 20, 2018 at 8:01 AM
    #516
    Hoangde
    Pm'd
  17. May 21, 2018 at 7:48 AM
    #517
    slowboater
    Ok boys and girls. Onboard air doesn't have a DPDT that fits the opening on the right side (2016+). Anybody know of one that fits the standard opening? I don't want to 'customize' the opening. I may want to trade this in sometime.
  18. May 21, 2018 at 8:10 AM
    #518
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I have a few that I have been looking at that 'should' work. but probably will require mounting within a 'blank' filler. I'll pull them and include links this evening. You are wanting to go the three step switch (on/off/on), correct? I ask, because I have also been looking at on/on style as well.
  19. May 21, 2018 at 10:52 AM
    #519
    slowboater
    Yep, on/off/on. Thanks! About to board a plane!
  20. May 24, 2018 at 8:56 AM
    #520
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Sorry for the delay, I got busy and couldn't find my info as I had moved to looking at on/on. So I had to do some sleuthing in my history/searches.
    I know this one was a pretty close match. I figured I'd have to likely trim the tensioners off to fit - http://www.bepmarine.com/en/1001712
    This is along those same lines, but a different purpose/manufacturer - https://www.gamainc.com/product/129e-bb/
    This was a 'small enough to fit somehow' option I had found - https://www.amazon.com/dp/B002UC6RHG
    This FleaBay find also appeared to be a workable solution - https://www.ebay.com/itm/112974900534
    This is another of those FleaBay finds that appeared to work based on dimensions - https://www.ebay.com/itm/272969284653
    I found this GENERAC switch, but couldn't find enough info on the dimensions to determine if useful - https://www.amazon.com/dp/B000HE93MU
    That should put you on the path of enlightenment...hopefully. I hope you find your magic bullet.
