3rd-Gen Tacoma OEM Mic Adapter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WickedAx, Mar 28, 2021.
  1. Jul 5, 2022 at 7:28 AM
    #281
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I'm running an external mic set up. Works pretty well:
  2. Aug 18, 2022 at 12:04 PM
    #282
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    Lmk if any of you guys still looking to buy this adapter. I’ll be selling mine. DM me…I have the low profile mini fuse version.
  3. Oct 26, 2022 at 7:37 PM
    #283
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Anyone have one of these they want to sell? Send me a PM
  4. Oct 26, 2022 at 11:56 PM
    #284
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Don’t bother with this one anymore, they had questionable performance at best. I’ve seen at least pioneer and kenwood not have good performance. Get the Enfig microphone for Tacoma. It sounds great (per people I’ve called it’s significantly better than stock or the mic that comes with the radios) and it clips into the upper console so there’s no “added mic” look. 100% happy with mine. Make sure you get the 3.5 to 2.5mm adapter if you have one of the radios with the smaller mic jack. My kenwood used 3.5 so I didn’t order that piece.
    MiTacoTRD likes this.
  5. Oct 27, 2022 at 12:14 AM
    #285
    MiTacoTRD
    N. Idaho
    https://shop.enfigcarstereo.com/product/enfig-mic-toy1/
    Definitely need the 2.5mm adapter if you have a Pioneer.
    BLtheP[QUOTED] likes this.
  6. Dec 18, 2022 at 9:42 AM
    #286
    pochoboy
    pochoboy Well-Known Member
    do you or anyone else have a pic of where you clipped this to the upper console? it lists to fit in the '16 to'18 models overhead console, would this clip fit the 2020+ model overhead console?
  7. Dec 18, 2022 at 10:00 AM
    #287
    BLtheP
    Plano, TX
    It fits perfectly in my 2021. Goes right in the center spot on that upper console. You pull out the little piece of foam in there from the factory and then clip in the mic. Works great.
    Leave some cable slack in the roof so you can lower the roof console in the future. Since the mic cable is all one piece to the radio.
    pochoboy[QUOTED] likes this.
  8. Dec 18, 2022 at 10:01 AM
    #288
    MiTacoTRD
    N. Idaho
  9. Dec 18, 2022 at 1:09 PM
    #289
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Did you manage to integrate with the OEM connector at all? That would make it killer but I guess it’d be a PIA and expensive to have parts on both ends.
    I’ve got my Pioneer mic in foam in the same spot. I hate talking to people anyway :) someday I need to Enfig. Cool that they link to TW!
  10. Dec 18, 2022 at 1:59 PM
    #290
    BLtheP
    Plano, TX
    Unfortunately not. The two wires in the bundle are a center wire and a stranded ground wrapped around that wire, then a thick sheath around both. I could not find a clean way to split into two wires at all. I was going to crimp them to a Deutsch connector so it would at least be disconnectable, but no dice.
    My solution is leave a bunch of slack in the roof so I can set the console on the seat if need be, and worst case I just grab a screwdriver and unlock the tangs to get the mic out if I need to remove the console fully. Thankfully, I’m barely ever up there now that all my projects are done, so none of it really Matters for me.
    daveeasa[QUOTED] likes this.
