3rd Gen. Tacoma Serpentine Belt Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 06ltd, Mar 15, 2021.
  1. Mar 15, 2021 at 7:38 PM
    06ltd
    06ltd [OP] Well-Known Member
    Maryland
    2019 TRD OR 6MT
    I just replaced the serpentine belt on my '19 and after many hours of googling had a very hard time finding a complete description of how to do this on the 3rd gen, so I thought I'd write up a couple things I learned and steps I couldn't find described.
    This whole job requires nothing more than a 14mm socket, breaker bar, and a 5mm Allen Key.
    Step one: use the 14mm socket on the breaker bar to rotate the belt tensioner counter clockwise creating slack on the belt. As the tensioner rotates you can insert a 5mm allen key into the service hole which will keep the tensioner in the slack position.
    Step 2: remove the old fan belt by either cutting it or sliding it off the pulleys and then around the fan itself. I just cut mine with some wire snips.
    Step 3: Slide the new belt around the fan and position it to be installed. It's finicky and a squeeze but very doable. Just be careful with the fan blades. I recommend removing any watches/bracelets/fitbits ahead of time.
    Step 4: With the tensioner held in place by the allen key, you should be able to get the belt over every pulley without too much effort. Once the belt is installed rotate the tensioner counterclockwise until you can remove the Allen Key and then slowly back off the breaker bar to let it take up the slack.
    Step 5: Double check that the belt is fully seated in every pulley. Grooves go to grooves and flat goes to flat.
    Step 6: Finish the beer you started because this took less time than you thought it would
    The two areas I struggled with were the service opening on the tensioner and squeezing the new belt around the fan. It's a super simple job that I spent way more time on due to a lack of clear guidance so hopefully this will help somebody.
    Bronxguy, eight, bchillin54 and 119 others like this.
  2. Mar 15, 2021 at 7:50 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 230k+mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Very nice , I've done many serpentine understand the concept but specifically for our trucks you did excellent write up
  3. Mar 15, 2021 at 7:58 PM
    Coyote501
    Coyote501 Well-Known Member
    Ohio
    2019 Barc Red AC
    How many miles did you have on your '19 when you replaced the belt?
  4. Mar 15, 2021 at 8:02 PM
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    Nice post. I knew about the service hole but wasn't sure where it was. Now I know.
    WilliamJames and 06ltd[OP] like this.
  5. Mar 15, 2021 at 8:02 PM
    06ltd
    Maryland
    2019 TRD OR 6MT
    Thanks, honestly getting that 5mm allen wrench into the service opening is the key to making this simple. They reference a "pin" in the maintenance manual and I had no clue what they were talking about until I saw that little hole. One of those dope slap, lightbulb moments of "ahh, so THAT's how this works, damn I'm an idiot" lol.
    That, and the "oh yeah, you have to get this stupid thing around the fan to get it on. Why doesn’t anybody show that in the youtube videos??"
    Learning has occurred here, hopefully I can share it :)
  6. Mar 15, 2021 at 8:02 PM
    06ltd
    Maryland
    2019 TRD OR 6MT
    40,115
    mquibble and Coyote501[QUOTED] like this.
  7. Mar 15, 2021 at 8:02 PM
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    This is excellent. I think I have squeaky belt syndrome and it's annoying af.
    Which belt did you replace with?
    06ltd[OP] likes this.
  8. Mar 15, 2021 at 8:05 PM
    06ltd
    Maryland
    2019 TRD OR 6MT
  9. Mar 15, 2021 at 8:11 PM
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
    I just had mine replaced under warranty for the same reason per
    T-SB-0098-20
    https://www.tsbsearch.com/Toyota/T-SB-0098-20
    Taco19Dave likes this.
  10. Mar 15, 2021 at 8:23 PM
    06ltd
    Maryland
    2019 TRD OR 6MT
    The only problem is that outside of the 36K warranty it's not covered because it isn't an "internally lubricated component" of the drivetrain, or at least that's what I was told from multiple dealers.
  11. Mar 15, 2021 at 8:26 PM
    Hiker46
    Hiker46 Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    The moderator should put this thread in the maintenance group.
  12. Mar 15, 2021 at 8:27 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    It’s so easy on the new tacomas, takes five minutes and remember how it went on. The old tacomas with three different belts, that’s a challenge. One of the belt tensioners is near the bottom and don’t get the belts mixed up, two of them are similar lengths.
  13. Mar 15, 2021 at 8:28 PM
    St0rm-Tr00per
    SoCal
    That’s too bad since they (Toyota) recognize that it’s an issue. Lucky for me I only have 34K miles on mine plus the extended warranty
    Chew and 06ltd[QUOTED][OP] like this.
  14. Mar 15, 2021 at 8:30 PM
    06ltd
    Maryland
    2019 TRD OR 6MT
    Agreed. Fortunately it's about a 30 minute, $35 fix :)
    gargamel05 likes this.
  15. Mar 15, 2021 at 8:32 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Great DIY tip! Thanks!
    mquibble and 06ltd[QUOTED][OP] like this.
  16. Mar 15, 2021 at 8:35 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I've changed many a belt, never knew about the tensioner keeper. Good on ya, OP
  17. Mar 15, 2021 at 8:36 PM
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2017 TRD OFF-ROAD DCSB
    Nice my ‘17 is due for this. Should be the same I would assume. This seems like it should be doable by a novice home mechanic.
  18. Mar 15, 2021 at 8:43 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    My ’16 is a tad over 5yrs just over 60k miles, no issues but have been thinking of replacing it and the plugs for that new car ready feeling. I could probably go a couple more years or 80k but I’m OCD.
    Couple of things I do different though, I never cut my belts, I store it somewhere on the vehicle as a new one can go if a bearing starts to go and can damage it in a short time leaving me stranded somewhere.
    Two, If I cut it and find I got one a tad short or long I’m SOL.
    And I have never used the service port pin as I seem to work faster without it but I’m glad you pointed it out and explained it well.
    Again great job, good write up, much appreciated
    Cheers! :thumbsup:
    TS4x4, TRDRed, marc1 and 7 others like this.
  19. Mar 15, 2021 at 9:03 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Not cutting is good for comparing old vs new, good point.
    Depending on length of bar / length of tensioner travel / space available, I could see the tensioner keeper being really handy.
    The hammer[QUOTED] likes this.
  20. Mar 15, 2021 at 9:05 PM
    patdeezy
    souLcaL
    Damn and I just ticked over 37K :angrygirl:
    MountainManGuy and The hammer like this.
