3rd Gen. Tacoma Serpentine Belt Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 06ltd, Mar 15, 2021.
  1. Nov 6, 2021 at 6:49 PM
    #61
    Pool Guy
    Pool Guy New Member
    2019 White Tacoma TRD 4x4
    Roof Rack, ski racks
    Thanks for the great instructions OP! Made my job of replacing my belt sooooo much easier. The thing that gripes me is that my Tacoma only has 27,5000 miles and this annoying kazoo sound develops. I've owned a 1987 Toyota 4x4 which I had for 15 years....no such problem. And my previous 2002 Tacoma for 17 years.....no such problem. Now my 2019 needs a new serpentine belt at 27,500 miles! What's up with Toyota's quality parts? First the fuel pump breaks at 18,000 miles, (luckily covered under warranty) recall on back bed light seal/gasket, (covered under warranty) then the belt starts squealing like a banshee. Both Toyota dealerships in my neighborhood wouldn't cover under warranty because they said it was a wear part....like tires and brakes, and wanted around $170 to replace. Bought a new belt ($38) and installed myself thanks to your posting instructions. Took about 30 minutes, start to finish. Thanks again, you saved me about $130! Love my Tacoma 3rd Gen, but at this rate I might have to buy the extended warranty just to be safe!
    mquibble and Technique like this.
  2. Nov 6, 2021 at 6:54 PM
    #62
    Pool Guy
    Pool Guy New Member
    Probably not covered, 2 Toyota dealerships near me claimed it was a "wear" part like tires and brakes. And my truck only has 27,500 miles! (2 and 1/2 years old)
  3. Nov 15, 2021 at 9:51 AM
    #63
    xKryToN
    xKryToN Well-Known Member
    2019 TRD OFF ROAD
    Bilstein 6112/5160 ICON 1.6 AAL Tacoma TRD Pro Wheels 285 75 16 KO2
    thanks for the help..it stopped the squealing noise coming from my engine. thought it was one of my pulley but did the water test and knew it was the belt. replaced with the continental belt at 42,500 miles. thanks for the help!
  4. Jan 13, 2022 at 10:16 PM
    #64
    edyuen888
    edyuen888 Well-Known Member
    18’ Cement DCLB
    OV tuned, 5100’s, airbags, k02s.
    Got a sqeal on cold starts lasts a minute max. Upon visual, idler no. 2 is wobbling.
    In the TSB linked in this thread it says to “follow procedure” but there’s no procedure mentioned other than just changing the belt? And then is states not to replace the idler? Should I just get a new belt and idler/ idler bearing and do it all or just do the belt as per the tsb? 2018 w 101k kms.
    mquibble likes this.
  5. Jan 21, 2022 at 8:27 AM
    #65
    Volksparts
    Volksparts AKA The Un"Official" Meso Taco
    Dave
    San Diego
    2017 Taco Runner
    Just had to swap mine out at 50,000 miles on my early 2017 model. Everything in the instructions is pretty much the same thanks to OP. The only difference was mine didn't have the 5 mm Allen key so I ended up having to use a 17 mm wrench to hold the pulley loose. No more squeaky for me.
    Taco Egghead likes this.
  6. Jan 21, 2022 at 8:45 AM
    #66
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    I have always thought of serpentine belts as a PITA. To the extent I don't have a spare. I will be putting a spare in my box soon though thanks to this thread.
    Taco Egghead, mquibble and Volksparts like this.
  7. Jan 30, 2022 at 11:39 AM
    #67
    TacoTom19
    TacoTom19 New Member
    Tom
    2019 Black TRD Sport 4x4 V6
    Thanks for the write up! Was searching for something to go by as I have a chirp now at 90k on my '19. This should make it easy.
  8. Feb 8, 2022 at 3:09 PM
    #68
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I think I've got a belt going bad too. An idler pulley going bad would make noise all the time right? It currently chirps when it is warmer out. No chirping in the morning when it's 60°, but in the afternoon when it's 85° it does.
  9. Feb 8, 2022 at 8:17 PM
    #69
    lostMarbles
    Micah
    Alaska
    I would guess there is no guarantee it is not a pulley, but if a pulley is out you should replace the belt anyway. So replace the belt and see it it fixes it.
    But, yes that sounds more like a belt than a pulley to me as well.
  10. Feb 10, 2022 at 2:47 PM
    #70
    ihatemytruck
    Dave
    Southern California
    That's the plan, replacing the belt this weekend, then inspect the pulleys. Hopefully it's just the belt.
    lostMarbles[QUOTED] likes this.
  11. Feb 11, 2022 at 7:21 PM
    #71
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I replace mine today. I don't think I was using a long enough Allen wrench because I couldn't get the tensioner to stay in the slack position. It was a wrestling match with several escapes and reversals but Gotter Done!
    Taco Egghead and mquibble like this.
  12. Apr 11, 2022 at 9:08 PM
    #72
    cartter469
    cartter469 Professional Idiot
    Cartter
    Reno NV
    '17 4x4 DCSB OR
    Sliders; Skids; Diodes; 33" Falkens; Elka 2.5's; Icon Rxt
    I got the belt halfway around the fan, and couldn’t get the second half around. Also didn’t have too much time to work on it tonight so I’ll give it a go when I’ve got more time and more importantly, energy
  13. Apr 14, 2022 at 8:04 PM
    #73
    c0inman
    c0inman Member
    2019 Tacoma TRD Sport DCLB
    Awesome! just what I needed, you made my day 06ltd!!!!
  14. Apr 14, 2022 at 9:51 PM
    #74
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Just replace mine at 52k miles with the new Toyota P/N from the local dealership, they had one left.
    Took me 5 mins. No more chirp now.
  15. Apr 24, 2022 at 4:57 PM
    #75
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    Perfect write up, thanks OP. I only had one problem, there wasn’t enough time to open a beer.
    Blak Shinobi likes this.
  16. Apr 24, 2022 at 5:14 PM
    #76
    bizarrocolin
    bizarrocolin Well-Known Member
    Colin
    SoCal
    Blue 2016 TRD OR 4x4 DCLB
    Always make time for the important things!
    mud[QUOTED] likes this.
  17. Apr 24, 2022 at 7:14 PM
    #77
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    For the record -
    147k on a '17 and starting to get some belt noise. Ordered a Gates from Amazon for $32.
    These belts should last a long time....
  18. May 1, 2022 at 12:06 PM
    #78
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    Just changed mine out at 45K thanks to the OP. Think I have it seated correctly. If the seating on a grooved pulley is whisker off, will it quickly seat itself or will it make a mess? Sort of afraid to start the truck.
    Edit: seems to be running ok. Replaced with Michelin belt. Will listen for chirps this week.
  19. May 5, 2022 at 7:37 PM
    #79
    Gametracker
    Gametracker Well-Known Member
    Fort Worth, Tx
    17 sport TRD 4x4
    SSO Hidden winch bumper, Meso puddle lights,
    Just replaced mine for the second time. Much easier. Great write up
  20. May 6, 2022 at 5:42 AM
    #80
    bbartol
    bbartol Well-Known Member
    Brandon
    Central Ohio
    2025 TRD Off-Road Premium in Terra
    Thanks for the great easy to follow write up. I’m only about to hit 26k miles but I know the day will come with age or mileage eventually.
