3rd Gen. Tacoma Serpentine Belt Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 06ltd, Mar 15, 2021.
  1. May 7, 2022 at 4:38 PM
    #81
    5000kelvin
    5000kelvin New Member
    What does the water test involve? My 2019 just started chirping. I'd like to rule out the idlers.
    shotgunbilly420 likes this.
  2. May 7, 2022 at 11:26 PM
    #82
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Interested I just put on my third belt at 155k miles, now I have a slight chirp in the morning ,but it goes away almost immediately.
  3. May 8, 2022 at 12:26 AM
    #83
    Mrb1268
    Mrb1268 Well-Known Member
    2019 Cav Blue Tacoma DCLB TRD OR
    44k , time to get a belt.
  4. May 11, 2022 at 9:02 PM
    #84
    taco! taco!
    taco! taco! New Member
    17 DCSB 4x4 OR
    Much thanks for this. Never replaced a belt myself before and this write up helped me do it in 15 minutes! Local stealers wanted 400 and 265 respectively, NUTS.
  5. May 17, 2022 at 5:09 AM
    #85
    t6p
    t6p Active Member
    New York
    I was having the same problem until I realized that I wasn't turning the tensioner far enough to get the allen key in the slot. You have to go pretty far.
    Thanks OP for the great write up. I've never changed a belt before and it only took me about 20 mins using these instructions. No more chirp!
  6. May 17, 2022 at 3:51 PM
    #86
    Bridger
    Bridger Well-Known Member
    South Jordan, UT
    2016 Tacoma TRD Off Road
    3" Lift 33" Tires on stock 16" rims Body Armor Rock Steps Decked Drawer System
    My '16 had an issue like this - mad squealing, then an intermittent chirp - around 30k miles, and the dealer diagnosed it as a belt or pulley issue. I decided to wait until it was a little older and replace the belt. At 52k miles I took it in and told the dealer (Karl Malone Toyota in Riverton, Utah) that I needed him to replace the belt. He quoted me $460 and I left the truck with him. About 30 minutes later he called to tell me the belt and pulleys were fine, and the noise was coming from the fuel injection system. A part - can't remember what, anymore - had a defective orifice and the fuel squeaked going through it. I was pretty happy to hear the belt was fine, but about passed out when he told me the replacement module was $1600 because I was past the 50,000 miles covered by a TSB.
    I asked him what he could do, as I'd initially been led to believe the squeak was a belt thing, and he told me he'd call me back.
    In less than 10 minutes he was on the phone with me telling me they would cover it under the TSB.
    If you're in the Salt Lake/Utah County area, the guys in the service department at Karl Malone are decent and honest.
    And, Amanhowzit, you may want to look at that fuel booster as a source for the noise.
  7. May 17, 2022 at 3:51 PM
    #87
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I beg to differ....never giving my money or taking my truck back to Karl Malone lol. Mark Miller in SLC is where its at.
  8. May 17, 2022 at 3:54 PM
    #88
    Bridger
    South Jordan, UT
    Sorry to hear about that. My experiences have all been good with them.
    Technique[QUOTED] and Bisley4525 like this.
  9. May 21, 2022 at 1:39 PM
    #89
    bizarrocolin
    bizarrocolin Well-Known Member
    Colin
    SoCal
    Blue 2016 TRD OR 4x4 DCLB
    Thank you for the instructions. The hardest part was finding the hole for the Allen key...I often have similar problems.
    Technique and CaptainBart45 like this.
  10. May 22, 2022 at 11:13 AM
    #90
    shotgunbilly420
    So replaced my third belt I'm at 160k mi on my Tacoma and with new belt I have a slight chirp in the morning and within 30sec it goes right away . I'm thinking i need to replace a idler some where ? Anyone run into this issue ?
  11. May 25, 2022 at 3:08 PM
    #91
    Hiker46
    Hiker46 Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    I replaced my serpentine belt at 89K mi with another Toyota belt. The old one is in really good shape with no cracks or uneven wear, so it's stored under the passenger seat in case some critter chews up the new one. I suggest you try to remove the old belt instead of just cutting it. You might have a good spare.
    PokerPilot and bizarrocolin like this.
  12. May 25, 2022 at 4:32 PM
    #92
    bizarrocolin
    Colin
    SoCal
    I did the same and printed the serp diagram from the first post to put in the glove box.
  13. Jun 10, 2022 at 4:40 PM
    #93
    willhahn24
    willhahn24 Well-Known Member
    2016 Tacoma
    Nice post. I never knew about the 5mm Allen key trick to hood the tensioner in the slack position. Definitely going to try that next time I change the belt
  14. Jun 24, 2022 at 11:52 AM
    #94
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    Perfect writeup. I used a T handle allen I had. A+
    2017 Tacoma w/28000 miles. Replaced it for age over mileage. Old belt looked good but stretched some. Replaced with Toyota Oem, new version.
    Thanks
  15. Jun 24, 2022 at 12:02 PM
    #95
    Dirt McGirk
    Dirt McGirk Well-Known Member
    Phoenix, AZ
    19 TRD OR 4X4
    Used the Allen key truck when I replaced mine a few months ago, but I made a stupid mistake.
    As a disclaimer I’ve worked on cars my entire life and I honestly just wasn’t paying attention when I did this.
    When I pulled the tensioner I was using a breaker bar, and the handle hit the little brown sensor that goes into the plastic water neck/ thermostat housing. I cracked the sensor, and had to order a new thermostat housing because the sensor is molded to it.
    Replacing the housing only took maybe 20 min but was out of stock everywhere so I had to wait for a few days to get it.
  16. Jun 30, 2022 at 10:37 AM
    #96
    Barcelona21Taco
    Barcelona21Taco Well-Known Member
    21 OR
    Water is a good lubricant for a rubber. While the engine is running lightly spray the belt with water and see if the squeaking goes away. If it does the squeaking is most likely being caused by the belt.
  17. Jul 1, 2022 at 8:51 AM
    #97
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    OP, thanks for the great write-up. Here is a video of a guy changing the belt on a 3rd Gen. He leaves the video running in real-time so you can see how long it took him to change the belt. No noise from my belt, but at 51K mile this will be my next project for peace of mind.
    https://www.youtube.com/watch?v=sv5fAcT0JAY
    Optimus14 and mquibble like this.
  18. Jul 1, 2022 at 8:54 AM
    #98
    Ob1-adobe
    Ob1-adobe Well-Known Member
    2019 Tacoma TRD Off-Road DCSB Magnetic Gray
    I had mine replaced with the recall
  19. Jul 23, 2022 at 9:19 AM
    #99
    GOTH.TACO
    GOTH.TACO Well-Known Member
    Josh
    San Diego
    2017 Tacoma TRD OffRoad
    Step 6: Finish the beer you started because this took less time than you thought it would
    For real! Took me not even twenty minutes. Smooth to smooth, groove to groove, piece of cake
  20. Jul 23, 2022 at 9:32 AM
    #100
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I need to do mine.
    Handy tip, keep your old belt for a back-up, just in case the new one breaks (however unlikely) while you’re in the middle of nowhere.
    JFick likes this.
