3rd Gen. Tacoma Serpentine Belt Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 06ltd, Mar 15, 2021.
  1. Jul 23, 2022 at 9:40 AM
    #101
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Anyone have the oem part number for this?
  2. Jul 23, 2022 at 12:37 PM
    #102
    JFick
    JFick Sawzall Enthusiast
    Los Angeles
    ‘19 TRDOR 6MT, ‘11 BMW M3 DCT
    Softopper 255/85r16 Yokohama MTs Camburg UCAs King extended travel coilovers King extended travel rear shocks Firestone airbags OME medium duty leafs
    Mine started squeaking at cold starts on warm days randomly last month (one month after my toyotacare ran out…). Purchased May 2019, and currently have 33,000 miles. Dealer told me it was “normal” so I swapped it for 10% the cost they quoted to diagnose and replace. Using this thread, did the work myself today with the Michelin belt linked in this thread from Amazon. Skid plate would have been a pain to take off, so I got by just accessing the pulleys from the top of the engine bay. Checked all of my pulleys, and installed the new one. Easy peasy! Thanks for the write up, @06ltd. Keeping my old one as a spare since it looks good enough for a quick fix if I ever need one.
    econwatch likes this.
  3. Jul 23, 2022 at 3:27 PM
    #103
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  4. Jul 23, 2022 at 3:42 PM
    #104
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I just replaced mine at 95k miles with a continental.
    It could have gone quite a bit longer. Don't see why people are replacing them at 30k.
  5. Jul 23, 2022 at 4:22 PM
    #105
    JFick
    Los Angeles
    Simply because some of us have had problems with them at 30k miles. My Tacoma’s sounded worse than my old Avalon with 100k miles on the original belt. There’s a TSB out there too on this condition, and for myself I was one month out of Toyota Care.
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10182963-9999.pdf
  6. Jul 23, 2022 at 7:22 PM
    #106
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I have a new belt waiting to go on sitting in my garage. Currently @ 71k'ish miles, no issues or noises, but I figured it would be better to do it before it needs done. Went with OEM one.
    mquibble likes this.
  7. Jul 26, 2022 at 10:07 PM
    #107
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Just did mine today. Second gen but same pulley system. Took me about 40 minutes. One idler was spinning a little bit rough so I’ll replace that at the next oil change I think.
    mquibble and JFick like this.
  8. Aug 2, 2022 at 3:35 PM
    #108
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Because our belt was having issues at 30k? Do you think we’re all replacing them for the fun of it at 30k? :rofl:
  9. Aug 2, 2022 at 5:23 PM
    #109
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I replaced mine this year and Its already sqeeling in the morning for a few seconds. I'm gonna probably replace before winter . I keep a old spare in the back compartment.
  10. Aug 31, 2022 at 4:13 PM
    #110
    HighQualityH2O
    HighQualityH2O Member
    I just did this to my ‘16 trd sport. If you’re doing this without removing anything, make sure your breaker bar is accessing the 14mm nut on the tensioner from the OUTSIDE of the coolant tube. You won’t otherwise be able to get sufficient travel of the bar to fully loosen the tensioner. Don’t ask me how I know… I may or may not have fought with it for 30 min and lost a quart of sweat.
  11. Aug 31, 2022 at 9:10 PM
    #111
    Technique
    Alex
    Utah
    Maybe you have a bearing with too much playing causing premature wear on the belt? Replacing it twice in the same year seems like something may be out of spec lol.
  12. Sep 23, 2022 at 11:35 AM
    #112
    Lt. Dangle
    Ohio
    Just replaced mine. Completely unnecessary in my case. Old belt looked great.
    Put old belt behind seat just incase I upset my trucks natural balance.
  13. Sep 28, 2022 at 11:05 AM
    #113
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    About to replace mine. Just started getting a slight "chirp" that I'm guessing is the belt. We'll see though, might be something else. 2017 with 68,000 miles.
  14. Sep 28, 2022 at 12:02 PM
    #114
    Silver Jacket
    Silver Jacket Well-Known Member
    Howie
    2022 Silver TRD OR 4x4 MT
    Thanks for the write-up! Makes me wonder, of all the serpentine belts I've changed on other cars, how many of them also had a "service hole" which would have made the job a lot easier!
    Another pro tip: if you don't have the routing diagram handy, snap a picture of the old belt with your phone prior to removal. It's amazing how quickly you can forget what it looked like after it comes off. Then use that pic for reference when routing the new belt.
  15. Oct 6, 2022 at 1:14 PM
    #115
    RFM56
    RFM56 New Member
    2017 TRD 4X4
    Thanks, done, 30 minutes! Long arms help. Never got the pin in the service hole, just let the tensioner relax after sliding the belt off, then after threading the new belt over all pulleys except the generator, got back on the breaker bar to finish seating the gen. I like one tool jobs. Good to have the belt pattern photo as guide.
    Silver Jacket likes this.
  16. Oct 6, 2022 at 1:54 PM
    #116
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    Might I add that it wouldn’t be a terrible idea to save the old belt, even if it’s got some cracks and whatnot, just throw it somewhere in the truck or toolbox as a spare in case the new one were to break somewhere down the road.
    mquibble and Silver Jacket like this.
  17. Nov 16, 2022 at 11:06 AM
    #117
    bgoods
    bgoods Well-Known Member
    Brian
    Orlando
    2016 TRD Sport 4x4
    Thank you for the write up OP and this nice tip which saved me time.
    The hammer likes this.
  18. Dec 12, 2022 at 10:44 AM
    #118
    leonardlatt
    leonardlatt Member
    JFick likes this.
  19. Dec 16, 2022 at 7:55 PM
    #119
    JFick
    Los Angeles
    Mine’s been on there for four plus months, 3000 miles, three long wheeling trips and still workin great. I’m sure most people know how to replace a belt properly, and I know sometimes there’s defects with products, but I’d wager a guess that some/most people leaving bad reviews probably had a bad accessory or idler pulley and didn’t know it until they killed two belts.
  20. Dec 29, 2022 at 7:19 PM
    #120
    4xTacos
    4xTacos Well-Known Member
    Fernando
    2019 Cement Tacoma Sr5
    Can say Thank You enough for this write up! Changed mine within 30 minutes, only cursed once when i wrapped the belt twice around the fan. No more belt squeaking at 58k, 2019.
    Probably could have lubricated, squeak started after going through some dirt/mud trails. This was too easy not to replace.
