3rd gen Top Hat
Discussion in 'Suspension' started by TacoMex85, Feb 21, 2018.
  1. Feb 21, 2018 at 10:33 AM
    TacoMex85
    TacoMex85 [OP] Well-Known Member
    Mark
    2017DCLB
    Hi guys I had a quick question, I recently ordered 5100’s and new springs. However I didn’t order them assembled, Does anyone know the part number or a good place to order the hardware to assemble them so I don’t have have to take apart my stock stuff for it?
  2. Feb 21, 2018 at 8:34 PM
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    Coming from?
  3. Feb 21, 2018 at 8:39 PM
    tcjacado
    tcjacado Well-Known Member
    After you jack the truck up and put it on jack stands. Move the jack to the lower control arm and jack it up to compress the spring .Just need to remove the lower shock bolt and the slowly and i mean slowly release the jack hydraulic and lower the control arm then remove the top hat nuts and shock top bolt. Then pull it all out. Reassemble the new set the same way, but in reverse.
  4. Feb 21, 2018 at 8:42 PM
    11Bguy
    11Bguy Well-Known Member
    Va
    2017 DCSB TRD
    Icons/ JBA UCA's
    There are some videos on this too, just be careful.
    You can also take them somewhere to have them done and/or installed if your not that comfortable as you'll need an alignment after anyway.
    tcjacado[QUOTED] likes this.
  5. Feb 21, 2018 at 8:45 PM
    TacoMex85
    Mark
    2017DCLB
    Awesome thanks guys.
    tcjacado likes this.
  6. Feb 21, 2018 at 8:45 PM
    tcjacado
    I was scared the first time I did it, but it is very simple to do. I mean the coil isn't preloaded like on a fox, icon, etc... and it's not a super heavy rated spring. I am a idiot and I got it accomplished.
    11Bguy[QUOTED] likes this.
  7. Feb 21, 2018 at 8:53 PM
    TacoMex85
    Mark
    2017DCLB
    Yeah I’ve helped a few buddies with tundras do them. I was debating ordering new strut mounts but I think I’ll save the money and dis assemble the stock struts.
  8. Feb 21, 2018 at 8:54 PM
    TacoMex85
    Mark
    2017DCLB
    Jactado do you have a white truck with icons up front? Think I met you on that bee trail run
  9. Feb 21, 2018 at 8:57 PM
    tcjacado
    Yup, guilty on the set up, still trying to get the rear end situated. Have shocks and extended brake lines ordered from headstrong. Just waiting for the email to go pick them up
    11Bguy likes this.
  10. Feb 21, 2018 at 9:01 PM
    TacoMex85
    Mark
    2017DCLB
    I was the guy in the stock white long bed behind you. I just got my shipment from headstrong today.
    11Bguy and tcjacado like this.
  11. Feb 21, 2018 at 9:05 PM
    tcjacado
    :sorry: in the year that I have been doing runs and what not I have met a couple hundred people between t4r and TW. Plus it seems like I attract white trucks, the last run on pilot rock I think we had 6 white rigs and 4 colored. Lol
    TacoMex85[QUOTED][OP] likes this.
  12. Feb 21, 2018 at 9:11 PM
    TacoMex85
    Mark
    2017DCLB
    Haha I think it was 3 of with white trucks in the back now that think of it. Lol
  13. Feb 28, 2018 at 8:33 AM
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    I have an extra used set that I was going to use to put together 6112's but I got a deal on the 2015 Pro suspension so I don't need them anymore. Figured it would be easier to put them together so I would just have to swap them out. Once that stuff gets here and I know I don't need them I would let them go if your interested.
