3rd Gen Traction Control Modes Explained
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doggman, Jan 25, 2018.
  1. Mar 21, 2024 at 9:33 AM
    #521
    icer22x
    icer22x Too Poor For Mods
    Northwest Arkansas
    2022 TRD Off Road MT - Barcelona Red
    KDMax Tune 10.0 ADM
    And what, technically, is "throttle intervention"? I saw a user on page 6 describe his truck rev limiting at 2K RPM in 4HI, yet in 4HI all TRAC throttle intervention is disabled (and VSC shouldn't be kicking in unless he was sliding). Wouldn't a 2K limit be considered throttle intervention?
    Unless, of course, there is in error in the chart as @ShimStack mentioned and there actually is TRAC throttle intervention in 4HI TRAC.
  2. Mar 21, 2024 at 9:59 AM
    #522
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Yes, that would be throttle intervention. Anything that cuts engine power/output and/or restricts engine speed is throttle intervention.
  3. Mar 21, 2024 at 10:07 AM
    #523
    icer22x
    Northwest Arkansas
    KDMax Tune 10.0 ADM
    If this is true, @Doggman, can we confirm that this is correct on the chart?
    Disregard, it seems post #129 answered my questions. I am curious as to why there is engine regulation in 2WD but not 4WD.
  4. Mar 21, 2024 at 11:39 AM
    #524
    icer22x
    Northwest Arkansas
    KDMax Tune 10.0 ADM
    Also, the description for AUTO LSD on the home page might need revised:
    "AUTO LSD(Automatic Limited Slip Differential) is a 2wd only mode that has TRAC turned on and VSC turned off. Meaning you get the brake simulated LSD functionality from TRAC while preventing VSC from intervening and cutting engine power. This is useful for powering out of situations where VSC is preventing you from getting out/started because it is constantly cutting engine power."
    Since VSC is controlled by yaw sensors and has nothing to do with traction, AUTO LSD is not preventing VSC from intervening, but it is preventing the throttle intervention from TRAC from intervening, correct? VSC should never prevent the truck from getting unstuck since the vehicle is moving close to 0 MPH.
  5. Mar 21, 2024 at 11:43 AM
    #525
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    I also believe there is from what I have experienced. You’ll notice it happening the most when your pedal input is more than what is occurring at the wheel(s) slippage. Like the fella said in the video, you won’t know TRAC is working because no lights go off in 4HI/LO. It just does.
    Be careful in 4LO, and climbing a steep hill. I once lost traction heading up at a good pace, and gave it too much throttle, the motor’s power was cut out, and I snail crawled up and over. The TRAC system would not allow the motor/gearing to wind back up to a “comfortable” pace.
    It’s an awesome system that is working in the background, the majority of the time unnoticed.:spy:
    On a side note, for brake actuation, I erased a comment about a “possible” Locker TRAC system, but got it all goofed up and made it sound like it was only occuring on one wheel. I know, hard to believe, sounds like BS, and beyond logic. But from what the patterns showed on the ground, I have no doubt TRAC is working even though the locker is engaged and the sensors should not detect any “abnormalities.”
    I’ll have to get some rollers. It’s the only way to know for sure. But if the traction control comes on in 2WD/Rear Locker/ALSD engaged, then I have no doubt TRAC does too, even though both wheels are turning at the same time.
  6. Mar 21, 2024 at 11:49 AM
    #526
    ShimStack
    Ben
    NC
    Maybe there isn't engine regulation. There was a MORR video where they struggled with a Tacoma engine cutting out in sand but it's possible it was something different going on. The traction control problem is a little more difficult in 4wd than 2wd because there's no good easy speed reference to characterize slip. Maybe that's why it would be brake simulated LSD only because slip across the axle is still straightforward to measure in 4wd as is measuring vehicle skid for the VSC.
  7. Mar 21, 2024 at 3:50 PM
    #527
    icer22x
    Northwest Arkansas
    KDMax Tune 10.0 ADM
    Did they have it in 4HI? If the engine was cutting out, wouldn't that lend more towards the possibility that there is throttle regulation?
    What do you mean by "no easy speed reference to characterize slip"? If I recall correctly, the entire TRAC system operates by using speed sensors, hence the brake LSD choice by Toyota and not an internal clutch pack system. Therefore, wouldn't all 4 wheels' speed be measured to characterize slip?
  8. Mar 21, 2024 at 5:34 PM
    #528
    ShimStack
    Ben
    NC
    That's the thing, I have no idea. Hence my hesitancy to take it as more than weak evidence. They attempted to explain but who knows. If it *was* cutting then that's definitely throttle intervention.
    They're all measured, but in 4wd you can't easily characterize slip because each axle is driven the same speed. In 2wd to know if the powered rears are slipping it's compared to the rolling speed of the fronts. The rolling front tires are an accurate ground speed reference. In 4WD, if the rears are slipping, so are the fronts. So how do you know if they're all slipping or if the truck's just driving along at that speed? It's doable but it's a more difficult problem.
    Doggman[OP] likes this.
  9. Mar 22, 2024 at 6:34 AM
    #529
    icer22x
    Northwest Arkansas
    KDMax Tune 10.0 ADM
    I see. This makes sense, thanks. As you said, I think this is why we only get brake assist during 4HI TRAC.
    ShimStack[QUOTED] likes this.
  10. Mar 22, 2024 at 4:57 PM
    #530
    Mr x 1979
    Mr x 1979 23 TRD Sport MT SB
    Mitch
    Truro Nova Scotia Canada
    2023 Black Tacoma TRD Sport MT SB
    Sorry dont feel like reading over 500 comments.
    How do you turn all these electronic traction control stuff off so i can actually do a donut in the mud ??? Must do donuts!!
    Pista1 likes this.
  11. Mar 22, 2024 at 5:40 PM
    #531
    icer22x
    Northwest Arkansas
    KDMax Tune 10.0 ADM
    In 2WD, hold down the VSC button for 3 seconds. Then you’re good to go.
    Pista1 likes this.
  12. Apr 20, 2024 at 2:15 PM
    #532
    Topanga Taco
    Rick
    Last one for the road and a hell of a read to understanding Toyota’s TRAC system. Originally developed for the 1994 Turbo Supra.
    TRAC is one hell of an engineering feat.
    Later Days:hattip:
    http://autoshop101.com/forms/brake12.pdf
    Canadian Caber and H3llRid3r like this.
  13. Jul 17, 2024 at 4:05 PM
    #533
    ODtheOG
    ODtheOG Well-Known Member
    Mo
    Orange County
    2022 Tacoma TRD OR
    Great information! Thanks for sharing!
  14. Feb 3, 2025 at 11:44 AM
    #534
    trailmeisterjoe
    trailmeisterjoe Well-Known Member
    Joe
    Pacific Northwest USA
    2017 Tacoma SR5 2WD AC
    SO........For my 2WD AC, and when driving on snowy roads I want the VSC switch "OFF", for best control? I know the manual says to only use it momentarily, but can't I keep it off only on snow roads? Same with a little higher speed with snow in the mountain passes on the interstate? OR.....Is holding the VSC switch for 3 seconds in those situations even better? Again, mine is only 2WD.
    Thanks, Joe
  15. Apr 13, 2025 at 1:53 PM
    #535
    Topanga Taco
    Rick
    Just when I thought it was done and dusted, yet another TRAC jewel! At least I’m hoping.
    We picked up a RAV4 AWD and that car is damn crafty. Not too bad of a drive. But one question for those that might know.
    So we are at the northern outskirts of the Cal Poppy Reserve and was somewhat gnarly for a suv. We get over a blind crest and all of a sudden my left front drops on the way down. Shoot, I think it’s time to turn around. Drive a bit more and decide it’s been enough of the question marks and turned around. Alright, for you folks that like it short but sweet (lol) I got to the part where the front dipped and decide to go for it as opposed to taking the left side which was steep, but no dip.
    BAD ASS TRAC system. It got up with some crazy noises and actions, and noticed the AWD blue boxes all lite up but with a twist(??) In between the TRAC doing its things to get over this obstacle, I noticed a single orange box light up on all four corners with no order. Firing off and constantly changing. But it did it so fast, was it one orange box per side?
    Was that a warning, or letting the pilot know which tire is doing the magic?
    TOYOTA TRAC is bad ass. But your prices suck :bananadead:
