3rd gens with 4" lift pics
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mod fan, Jan 21, 2018.
  1. Jan 21, 2018 at 2:34 PM
    Mod fan
    Mod fan [OP] Well-Known Member
    Would love to see some 17-18s with a 4 inch suspension lifts and wheel and tire info ! And the pros and cons on you setup! Thanks !
  2. Jan 21, 2018 at 2:36 PM
    tnel12
    tnel12 Well-Known Member
    Oklahoma
    2017 QS TRDOR SB
    icon stage 2, icon rebound, wildpeak at3 285/70/17, rago fab light bar, Cali raised led fogs
    My truck is about 2.5”. You can see the picture in my profile. Pros is it’s awesome and drives a little better even though it is slightly more stiff. Cons are it makes a shitty transmission even worse with the bigger tires. I don’t regret anything though. I love my truck.
    harl3ygonewiild likes this.
  3. Jan 21, 2018 at 2:36 PM
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    That's going to be rough my friend. Cause most 4" lifts are going to be a db lift or a spindle. Majority of the trucks on here run no higher than 3". You might find a few that have a 3" with a 1" body lift. Welcome to the forum though :cheers:
    remgu2000 and stealthmode like this.
  4. Jan 21, 2018 at 2:38 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    .....I must agree, too many "other problems" happen after 3" of lift.
    Willbeck and RigginsTaco[QUOTED] like this.
  5. Jan 21, 2018 at 2:41 PM
    Mod fan
    Curious on the reason ? Is it due to the size of the job? Or is there problems associated with a 4 inch suspension lift ?
  6. Jan 21, 2018 at 2:41 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    3” lift with 35s FTMFW. The only lifts higher than 3” you will find are mall crawler drop brackets (not that there is anything wrong with that, just pointless for Offroad use IMO) or spindle lifts for 2wds.
    VLTHNTR77 and HSmith_11 like this.
  7. Jan 21, 2018 at 2:42 PM
    Mod fan
    Looks great
  8. Jan 21, 2018 at 2:43 PM
    RigginsTaco
    Andreas
    Stuff...
    No just the clearance. There's nothing wrong with db lifts. The majority of full size trucks that you see on the road that don't have a spacer lift has a drop bracket lift. If your fixed on 4" just do 3" suspension and 1" body lift. It looks really good
  9. Jan 21, 2018 at 2:44 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    +1
    3"+35's
    Trident904 likes this.
  10. Jan 21, 2018 at 2:44 PM
    Trident904
    Brian
    17 4Runner TRD OR
    Thanks.
    To answer your question, going higher than 3” on a 4wd truck without using a drop bracket creates extreme CV angles and other geometry problems. Getting your truck into alignment will be difficult if not impossible.
    RigginsTaco likes this.
  11. Jan 21, 2018 at 2:44 PM
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Are you 4x4 or pre-runner?
  12. Jan 21, 2018 at 2:44 PM
    RigginsTaco
    Andreas
    Stuff...
    I wouldn't say people don't wheel those. There is a Canadian on our forum that runs a 6" db and he wheels all the time
    Trident904[QUOTED] likes this.
  13. Jan 21, 2018 at 2:47 PM
    Mod fan
    Will be pu not 4 runner
  14. Jan 21, 2018 at 2:48 PM
    Trident904
    Brian
    17 4Runner TRD OR
    A drop bracket lift does not give you more clearance on the front diff. Plus, there’s not any heavy duty skid plates available for dB lifts that I am aware of. The only way you are going to get clearance with a dB lift like you would with a 3” suspension lift is by riding on 37” or larger tires. Then you are looking at rehearing and cutting fenders, etc.
  15. Jan 21, 2018 at 2:48 PM
    Mod fan
    Is there a lot of cutting/ clearanceing to get 35s under the 3 inch suspension?
  16. Jan 21, 2018 at 2:50 PM
    RigginsTaco
    Andreas
    Stuff...
    I didn't say it did, OP asked the reason why people don't go DB lift and I said the clearance.
  17. Jan 21, 2018 at 2:50 PM
    Trident904
    Brian
    17 4Runner TRD OR
    I agree that people do wheel with dB lifts, like stated in my previous post, you are not gaining any diff clearance by running one.
  18. Jan 21, 2018 at 2:50 PM
    RigginsTaco
    Andreas
    Stuff...
    Lol bruh I never said db lifts give you more clearance haha
  19. Jan 21, 2018 at 2:51 PM
    Trident904
    Brian
    17 4Runner TRD OR
    Just a CMC and hammer the pinch weld flat. Have to make sure you are a true 3” lift and run aftermarket UCAs.
  20. Jan 21, 2018 at 2:51 PM
    Trident904
    Brian
    17 4Runner TRD OR
    My fault, I misunderstood what you were getting at.
