3RZ to 5VZ how? PLZ HELP!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97YoterS, Aug 24, 2008.
  1. Aug 24, 2008 at 9:32 AM
    97YoterS
    97YoterS [OP] Well-Known Member
    North Carolina
    Chevrolet 2500HD Duramax 4x4
    None of your business
    ok, so lately ive been driving my friend's 2000 5VZ TRD 5speed Tacoma, and noticed a huge difference in torque and horsepower between the 3RZ and 5VZ, and Ive been wanting to take out the 3RZ and replace it with a 5VZ V6 motor, but what would change if I switched out the engines. Transmission? Wiring? Driveshaft? PLZ someone tell me, cause Ive never had a straight answer from nobody!:confused::help:
    P.S. How much would it cost if I took it to somebody to swap out the engine's, because I dont know a dam thing about swapping engines in a Toyota:(
  2. Aug 25, 2008 at 10:17 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    see if we had a compatibly guide for the years this would help right here and now..
    I do not have your answer, but it could be done i know this much, but what you can keep and what has to be replaced is not known to me.
  3. Aug 25, 2008 at 12:37 PM
    HighDesert
    HighDesert Active Member
    99 4x4
    The transmissions differ. So, unless you can find a donor vehicle, you would probably be better off selling your vehicle and buying another as it will likely be less expensive. If you are intent on a motor swap, why not try to find a D4D; you would have the torque of the six with fuel mileage well into the thirties.
  4. Aug 25, 2008 at 5:58 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    it would be a near complete drivetrain swap.... engine,trans,transfer case.... wiring engine computer the works... cheaper and easier to call up LC Engineering and get performance cam,header and supercharger for 3RZ i have personally seen a 250 rear wheel HP 3RZ ... I think LC may now offer complete crate engine 3rz's that you could add the super charger to
