3rz TRD supercharger on 2trfe
Discussion in '4 Cylinder' started by TireFire, Oct 30, 2017.
  1. May 23, 2018 at 11:15 PM
    #141
    Rubin10
    Rubin10 Well-Known Member
    max
    Daytona beach fl
    11 4x4 regular cab 5speed
    Any more progress?
  2. Jun 13, 2018 at 11:28 PM
    #142
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  3. Oct 7, 2018 at 4:52 AM
    #143
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Hey, so I was cruising around ebay looking at m90 superchargers when I just had a quick thought.
    Would it be possible, instead of making a custom offset pulley to just add a spacer of the proper thickness to the snout? Pics:
    This is the input shaft of the Eaton m90. You can see the 3 straight pins on the left of the shaft.
    Those 3 pins interface with the 3 pins on the rotor via the coupler with 6 holes seen in the center of this pic:
    So possibly you could machine a spacer that goes between the rotor housing and the snout to bring the pulley into proper alignment, and all you would need to couple the input shaft to the rotor would be a thicker coulper.
    I suspect that prototypes could be made quick and dirty with maybe a band saw and a drill press. Certainly a lathe would help with the coupler and a cnc mill would make a beautiful spacer but perhaps this could even be mocked up in wood or 3d printed just to prove the concept.
    I think machining these spacers would be simpler and require less engineering than a custom offset 7 rib serpentine pulley.
    Does anyone know exactly how much the difference is for pulley alignment from the 3rz kit to the 2tr? How thick would a spacer have to be? Is it like .25" or more like 2"?
  4. Oct 17, 2018 at 10:10 PM
    #144
    Massione27
    Massione27 Member
    Massimiliano
    Hilux 2.7 4x4 2008
    Hi. I do not speak a lot of english. I have a hilux d'cab 08 2.7 (2tr) 4x4 mt. I'm about to start installing within 2 weeks. but I really want a supercharger. I hope you can do it so I would be encouraged to do it. I hare low boost that. with that m90 how much psi do you plan to place?
  5. Oct 18, 2018 at 7:49 PM
    #145
    05Taco4x4
    2TR-FE Enthusiast
  6. Jan 19, 2020 at 8:56 AM
    #146
    Tacoooma13
    Tacoooma13 Active Member
    Cole
    2016 Grey SR Tacoma
    3inch Rough Country N3 struts and N3 shocks. Freedom offroad UPCAs. Rough Country bull bar. 42inch curved light bar. roof rack. 20×10 -25 Arkon Lincoln. Achillies Desert Hawk x-mt. Afe drop in filter. LCE header and LCE 2.5" cat back.
    Has anyone mounted the 3rz SC on a 2TR yet? 10/10 would buy that spacer if someone has.
  7. May 23, 2021 at 7:50 PM
    #147
    Shawn989116
    Shawn989116 Member
    Robert
    2018 Tacoma SR5 4x4 2.7L 2TR-FE
    ARB Air lock diffs + 4.88 Ring pinion
    Any more progress with fitting the 3RZ supercharger to the 2TR-FE? Very interesting line of work getting this going. Is the CAD file available?
  8. Jun 23, 2021 at 8:12 AM
    #148
    Trucken77
    Trucken77 Well-Known Member
    Texas
    2021 Toyota Tacoma TRD off road
    Nope getting too old for all that just give me a push if I’m in your way…
