4.0 bottom end engine mods.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrGone, Mar 18, 2014.
  1. Mar 18, 2014 at 11:18 PM
    MrGone
    MrGone [OP] New Member
    Tennessee River Valley
    '06 TRD Sport SR5 6speed
    Sup fellas? First post here so pardon my greenness. I was wondering if anybody had any experience with windage tray/ oil pan baffles, or crank scrapers. I know the scrapers won't do much for bottom end, but I would feel vindicated if it helped throttle response or idle roughness, which makes my teeth grind. I know I have to replace the entire exhaust because of bum cats, but any other input would be appreciated. BTW I got the P0420 curse.
  2. Mar 19, 2014 at 1:02 AM
    talofox
    talofox Northwest Member
    Justin
    Port Angeles, WA/Minot,ND
    '07 DCSB 6spd
    You will find more info about baffles and windage trays for the 1gr on xrunner forums as they have quite a few auto-x enthusiasts. However I'm pretty sure their factory pan is quite a bit more shallow due to ground clearance.
    The actual pan itself as you probably know is a 2 piece design and the pickup sits directly over the small lower pan. With the deeper lower pan on the 4x4's, a tray/baffle would be unnecessary unless the engine is running at crazy angles for extended amounts of time while offroading.
    That being said you shouldn't have a rough idle to begin with and the stock throttle response seems pretty good to me with the 6spd. You said you have a P0420 code, chances are it's a bad O2 sensor or cat which could easily cause bad throttle response and idle. Best to get that taken care of and go from there before looking into custom oil pans.
    A couple modded xrunner pans if you're interested:
    http://www.tacomaworld.com/forum/x-runners/180215-custom-oil-pan.html
    http://www.xr-underground.com/forum/showthread.php?t=51726
  3. Mar 19, 2014 at 10:17 AM
    MrGone
    This is exactly why I'm interested in it. I wanna get hectic. Don't wanna bust my jurnt doin it. Nomsayin? Thanks for the links. I love the heavy look of that pan. Good lookin out.
  4. Mar 19, 2014 at 11:46 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    WTF did I just read ? :confused:
  5. Mar 20, 2014 at 3:51 AM
    MrGone
    Yeah, wtf did you just read, really? I mean, like we must totes not stand for this nonsense. Luls. :p
    -Enter New Guy Bash Here-
