4.0 Idler Pulley Replacement OEM vs Gates Reference
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bruce988jl, Oct 23, 2017.
  1. Sep 16, 2021 at 5:48 AM
    #101
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    That’s incredible.
    R0dzilla75 likes this.
  2. Nov 9, 2021 at 3:46 AM
    #102
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    Bumping this back up vs starting a new thread. I attempted to change my idler pullies this past weekend, no dice. The bolts are so rusted, I started to round them off. I was going to grab one of my "biter" sockets, when I realized i probably should not do that since I do not have new bolts, washers etc... I bought a koyo kit offline, cant recall where. Its probably fake now that i read through this thread, but it is what it is now. Does anyone sell aftermarket bolts and washers that are the correct fit for this truck, or would i be better off just going oem?
    Also, when i took the belt off i found out the tensioner pulley is bad as well. Is buying the gates tensioner and swapping out the pulley still the best option? thanks!
  3. Nov 9, 2021 at 7:10 AM
    #103
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    If you feel that the tensioner is putting plenty of tension onto the serpentine belt, then replacing just the bearing is pretty easy.
    Unfortunate about the bolts. Even though my taco spent several years in places with salted roads, I had no trouble getting mine out. Made the replacement job super easy. I’d go OEM myself but I know that if I had needed to replace one, I would’ve headed over to the hardware store and picked up a replacement there.
  4. Nov 9, 2021 at 7:14 AM
    #104
    danteisme
    South Western PA
    The pulley on the tensioner is pretty trashed, all of the pullies are pitted and rusted so i'm going to just replace all of the pullies with new assemblies rather than swap out the bearings.
    i'm worried if i can get the bolt out, that the hardware store might not have an exact match. I think i'll just order new oem ones to be safe.
    Toy4me likes this.
  5. Nov 9, 2021 at 7:26 AM
    #105
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    This is the no-brainer to me.
  6. Nov 9, 2021 at 7:28 AM
    #106
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Many just replace the tensioner pulley but I did the whole assembly as had belt slip at full throttle and downshifts so tensioner was getting weak.
    Full tensioner assembly requires dismounting the alternator and AC compressor as its the base they bolt to/thru. A pain in the ass.
    Need to soak the bolts in PB Blaster or other penetrating oil and always use a good quality 6 sided socket (not 12pt)!
    Bolts are specific length so good luck mayby a good ACE has a match but note that the #1 post has the bolt part #s so save yourself the hassle and get OEM.
    Good luck and wear gloves and save your hands. Might help having a second person holding the socket on from above as you work from the bottom.
  7. Nov 9, 2021 at 7:46 AM
    #107
    danteisme
    South Western PA
    Oh yeah, i soaked this with blaster for 2 days. I attempted my standard 6 point socket and they just won't grip. Heck, the one won't even fit on the bolt its so rusted. And there isnt a ton of room to swing a hammer. i order the new bolts and washers and such, give it another shot (hopefully before winter hits) and if i cant get i'll just have to take the truck somewhere and have them do it.
  8. Dec 7, 2021 at 8:46 AM
    #108
    danteisme
    South Western PA
    Well, i'm still working on this project. A couple of items are on back order from Toyota...
  9. Dec 7, 2021 at 4:28 PM
    #109
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    So were you able get those rusted bolts out?
    Reggie4x4 likes this.
  10. Dec 8, 2021 at 8:35 AM
    #110
    danteisme
    South Western PA
    Havent given it my second attempt yet. I wanted to wait until i had the new hardware since i dont plan on re-using the junk thats on there now. But, with how cold its getting to be, i might end up taking the truck somewhere and pay them to swap them out.
  11. Dec 19, 2021 at 10:38 AM
    #111
    Macbugs23
    Macbugs23 Active Member
    Ephrata, PA
    2006 Toyota Tacoma SR5 4x4
    how did you get to the bottom two air conditioning compressor bolts to remove them to move the AC out of place to get to the tensioner?
  12. Dec 19, 2021 at 5:08 PM
    #112
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    It's been awhile but I don't remember them being super hard to get to.
  13. Feb 23, 2022 at 11:41 PM
    #113
    Flo_TRD07
    Flo_TRD07 Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    Bumpin' the thread. I see according to google images, there are two Idler number 2's... The left most as well as the upper most idlers. Then there is the right bottom most idler. I see that the oem part numbers are 16603 and 16604. Would anyone have any technical manual/data that states which part number goes with which idler? Really scratching my head here trying it figure out.
    To the best of my knowledge and research it seems like I need two 16603 pulleys and one 16604 pulley.
  14. Feb 24, 2022 at 12:29 AM
    #114
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Did you look at the diagram on the first post?
  15. Feb 24, 2022 at 12:40 AM
    #115
    Flo_TRD07
    Ben
    Truck things
    I did, just confused by it
  16. Feb 24, 2022 at 5:58 AM
    #116
    Bruce988jl
    Bruce988jl [OP] Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    If you're just replacing the idlers you will need two Number 2 Idlers (16604-0P011) and one Number 1 Idler (16603-0P030)
  17. Feb 24, 2022 at 8:14 AM
    #117
    Flo_TRD07
    Ben
    Truck things
    My hero!! Thank you so much that’s all I needed!
  18. Feb 24, 2022 at 10:39 AM
    #118
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Alternatively, if your pulleys are in good shape, you can replace just the bearings. 6302RMX (bearing size:10x42x13) is the part #; you need four bearings because the #1 idler is a double bearing. Also consider replacing the bearing in the tensioner pulley, type 5203-2NS, size: 17X40X17.5 (other types: 5203-2NSL, 5203-2RS; or Febest pulley/bearing # 0187-GRJ200). Rodavictoriausa is a good source for the bearings.
  19. Feb 24, 2022 at 11:23 AM
    #119
    Bruce988jl
    Southern NH
    This is what I did for pulleys I pulled off that way I have spares.
  20. Mar 27, 2022 at 8:16 PM
    #120
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Has anyone on here replaced the OE #1 idler with the gates 36174 idler and also have the supercharger kit? Did you have any issues with alignment on the supercharger Idler that sits on top of this pulley ?
    I tried replacing this #1 OE idler today only to find out that the 36174 gates pulley isn’t as wide at the bearing like the OE double idler and throws off the spacing for the lower supercharger idler pulley that sits on top of it. Pics below for ref :
    Pulleys side by side
    OE pulley spacing with supercharger idler
    gates pulley spacing with supercharger idler
