4.0 Idler Pulley Replacement OEM vs Gates Reference
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bruce988jl, Oct 23, 2017.
  1. Jan 22, 2024 at 11:28 AM
    #141
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    @TheBlueBeast15 I have no experience with the AC compressor. If it has some fore/aft movement, it may be normal, as long as it is not excessive. 2mm would be the most for me before I’d start worrying. I would definitely not tolerate side-to-side play. That would introduce a wobble that could derail the belt.
    TheBlueBeast15 likes this.
  2. Feb 21, 2024 at 6:14 AM
    #142
    Zdosse935
    Zdosse935 Well-Known Member
    How is the Gates parts holding up for you? any update as this is 2024?
  3. Feb 21, 2024 at 6:19 AM
    #143
    Zdosse935
    How are the Gates parts holding up for you?
  4. Feb 21, 2024 at 3:18 PM
    #144
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Mine is 5 or 6yrs maybe more but still running strong.
    GrandMasterChooch likes this.
  5. Feb 21, 2024 at 4:08 PM
    #145
    Zdosse935
    Ok. I'm thinking of getting 3 Gates pulleys and 1 OEM tensioner then only replacing the tensioner pulley. I'll save the tensioner assembly for later when replacing the AC compressor. The price comes out to be about $211 compared to all OEMs which is about $300 plus.
  6. Feb 21, 2024 at 4:18 PM
    #146
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    I know everybody likes to cheap out & not replace the tensioner (cause its so hard) not!
    But if the pulleys & bearings are wore needing change how about the spring in the tensioner.
    To buy a new one and throw it on the shelf makes no sense.
    CowboyTaco likes this.
  7. Feb 26, 2024 at 4:25 PM
    #147
    Zdosse935
    Gates pulley came with a sleeve that acts as a washer so the question is do I still need to use the OEM washer?
