4.0 throttle body specs?...
Discussion in 'Performance and Tuning' started by tooter, Aug 16, 2013.
  1. Aug 21, 2013 at 11:39 AM
    tooter
    tooter [OP] play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I actually like that the engine runs fine on cheap regular 87 octane gas, and already gets excellent gas mileage. So it doesn't make any sense to go through the considerable expense of tearing the engine apart to mill the head, or replace pistons, and then to be stuck with an engine that only runs on more expensive premium gas.
    The throttle body only meters air, so running one with a larger bore and butterfly just makes the throttle more responsive.
  2. Aug 30, 2013 at 7:08 AM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    Nitrous=more compression
  3. Aug 30, 2013 at 8:16 AM
    tooter
    Greg
    Los Angeles
    Yeah, it does. But I'm speaking within the practical context of normal day to day driving.
    Still haven't made it out to the wrecking yard (going to the dyno shop today :) ), but I highly suspect that the 4.0 throttle body bolt pattern is 65mm square just because so many other Toyota throttle bodies are also square.
  4. Aug 30, 2013 at 8:47 AM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Im getting 9.6cr from my searches, which leads me to say you've got lots of room for improvement there. I used to run 87octane on a 12.8cr daily driver with a conservative tune. It'll wake up the entire rpm range. It does sound like a hassle to do but like you mentioned, milling the head wouldn't be too bad. Maybe pick up a spare head at the autowreckers
  5. Aug 30, 2013 at 8:58 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Benefits from this?
  6. Aug 30, 2013 at 12:11 PM
    lemon177
    Matthew
    Oahu
    Raising the compression ratio or larger throttle body?
    As op said, bigger diameter(with some exceptions) will allow more air to flow at pretty much all throttle positions and should give you gains.
    Raises cr will create a more compact explosion to happen in the chamber and push the pistons down harder(in a nutshell).
    While one thing alone may not show drastic results, everything working together will provide great results.
  7. Aug 30, 2013 at 12:34 PM
    nfs257
    DFW
    She gone
    Sorry that ^^^^ was what I was asking.
