4.0 TRD Supercharger + URD pulley??????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by High-Gear, Jun 13, 2010.
  1. Jun 13, 2010 at 11:00 AM
    High-Gear
    High-Gear [OP] Zombie Killer
    Newton, KS
    09 TRD Off Road
    TRD Supercharger, TRD Cat Back Exhaust, DR / Icon 2.5 Coilovers, Camburg UCA, TSB with AAL, Walker Evans 2.0 reservoir rear shocks, ARB Bull Bar, Smittybilt 10K Comp Winch, ARE Camper Shell, Con-Ferr Safari Rack, 4 KC Highlights on rack, 2 KC Rallye 800 on Bumper Armortech Off Road plate rear bumper. Firestone Airbags in rear, with Firestone compressor.
    I had a TRD supercharger installed on my 09 4.0 V6 when I purchased it, and they reflashed the CPU. I plan on adding a URD pulley once the warranty is up. Has anyone done this? To change the tune, do they just reflash the CPU or do I need to purchase an after market computer? What sort of HP / torque numbers did you get after the swap?
    Thanks!
  2. Jun 13, 2010 at 11:11 AM
    75thrangertaco
    75thrangertaco Sua Sponte! RLTW
    charles
    casper wyoming
    procomp 6 inch co lift ,305/55/20 xtreme a/t tires,4.88 gears ,,grill shell painted white billet inserts.Trd cat back ,
    re flash or you can do an apr x1 ecu.supposedly 304 hp net with the reflash but wel see when mine gets here and i stick it on the dyno.
  3. Jun 13, 2010 at 11:28 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    You don't need to change anything if you add the 2.85 pulley. I've got the apr one that looks a stock pulley on my truck.
  4. Jun 13, 2010 at 1:17 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    CPU? You mean ECU? :D
  5. Jun 13, 2010 at 1:48 PM
    High-Gear
    Newton, KS
    09 TRD Off Road
    CPU...ECU...C3P0...Whatever it takes!
    rmepilot likes this.
  6. Jun 13, 2010 at 1:51 PM
    High-Gear
    Newton, KS
    09 TRD Off Road
    I thought 304 was just with the TRD supercharger. The URD pulley is suppose to get you another 60+ horsepower from what I have read.
    What is the APR One? Can you guys give me a link?
  7. Jun 13, 2010 at 3:47 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    If you have a 2009 or later, there is no APR X-1 available. Which is a shame. It kicks ass.
    The connectors at the ECU are different 2009 & up.
  8. Jun 13, 2010 at 5:15 PM
    rossk35
    hawaii
    You don't get 60hp from just a pulley change. You get about 20rwhp. Urd sells the apr 2.85 pulley.
  9. Jun 13, 2010 at 5:20 PM
    originalthoughts
    originalthoughts Well-Known Member
    Houston
    1997 Land Cruiser
    None, factory diff lockers are great.
    :rofl:
  10. Jun 13, 2010 at 5:33 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    some have run the pulley without any additional tuning.
    it really depends on your intake setup. I have seen some trucks run super lean on the top end with certain intakes ( K&N for one)
    many have not had any troubles
    I would def tune for it if possible. you cannot reflash again, you will need some sort of additional tuning hardware
    this reminds me, I need to put my pulley on. :)
    Justin
  11. Jul 2, 2013 at 11:28 AM
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
    Does the stock belt fit fine?no problems?
  12. Jul 2, 2013 at 12:25 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Yes. Plenty of room on the tensioner with such a small difference in diameter.....
  13. Aug 15, 2016 at 9:30 AM
    RunsGuns
    RunsGuns Well-Known Member
    Sam
    Colorado
    Previously SC LT ‘12 taco. ‘95 FZJ80.
    What about with a ARB snorkel? And what about at 5k ft elevation? My truck sc was installed at sea level but nowni live in denver co. Hmmmm i want a 2.85 pulley but i dont want to run lean.
  14. Aug 15, 2016 at 12:27 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    RunsGuns likes this.
  15. Aug 16, 2016 at 11:48 PM
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    I too have the URD 2.85 pully and truck runs just fine. Just do the swap and that's it.
