4.0 V6 Performance Mods (1gr-fe)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XR Drift, Jul 25, 2017.
  1. Jul 26, 2017 at 5:42 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I was very close to doing this about 5 years ago. It would have happened except the Raptor model, color and options pack I wanted was sitting there with a sold sticker.
  2. Jul 26, 2017 at 5:56 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    35 at the wheels for intake and exhaust? Hahaha no
  3. Jul 26, 2017 at 5:57 AM
    PMK
    Florida
    10 DCLB TRD Sport
    Not sure how much HP you are willing to buy. Never dynoed my truck, 2010 DCLB Prerunner. Stock the mpg was pretty sad, and the power seemed flat.
    Yes, I have a hood scoop, but no stickers to go fast.
    The current setup is much better but no drag queen. Volant cold air scoop into a DIY duct into the oem airbox with Volant oem replacement filter. I did blend and smooth the edges of the airbox and throttle body. The throttle body was also polished. I stuffed an intake manifold spacer in, added a URD Maf black box. Exhaust was swapped to DTLT headers, URD y pipe, followed by the stock exhaust rear section and stock muffler. With no cats, I installed the URD o2 sims. The rear axle got a Tru Trac diff.
    As I mentioned, it is no drag queen, but certainly runs better and the Scangage shows the mpg while driving. Stock was 20 on a great day, now, with no effort, 24/25 mpg at the same speeds with the same tires.
    For the earlier trucks there was an aftermarket setup available with cam gears and more. Apparently Toyota swapped the design of the engine computer connectors making it very difficult to plug and play unless you go boosted.
    I have not stayed current on what is now the best mods for newer trucks. I will say though that if I had gone supercharger, those bearing would be replaced well before the known worn out times others had.
  4. Jul 26, 2017 at 6:01 AM
    PMK
    Florida
    10 DCLB TRD Sport
    If this going in the 08 X runner, get the cam gears and kit that goes with it. The early version seemed popular and got good results, no doubt the later version is better.
    A while back I belonged to the x runner website. There is a lot of good solid info there.
    XR Drift[QUOTED][OP] likes this.
  5. Jul 26, 2017 at 6:35 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    You need to calculate your me league the correct way
    Accipiter13 likes this.
  6. Jul 26, 2017 at 6:48 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  7. Jul 26, 2017 at 10:55 AM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Point is he's gonna be disappointed if he thinks simple bolt-ons will net him any satisfactory gains.
  8. Jul 26, 2017 at 10:57 AM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
    Stickers. 5hp per sticker.
  9. Jul 26, 2017 at 11:04 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Don't forget that adding an almighty hood scoop with get you at least 50hp, maybe 60 with a proper tune.
  10. Jul 26, 2017 at 11:06 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    spend the money for boost!!
  11. Jul 26, 2017 at 11:11 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    725hp to the wheels.
  12. Jul 26, 2017 at 11:21 AM
    PMK
    Florida
    10 DCLB TRD Sport
    I guess you mean mileage. Not sure what me league is.
    I have kept fuel burn / mileage data from day one. Truck was bought new 12/31/2009. MPG is trended up about 10% without the cats and having the other mods.
    FWIW, those highway mpg shown on the scangage actually beat the 10% average mpg. So around town, 10% on the highway closer to 15%, maybe more.
    Sorry, I am not all techno about tracking mpg, just watch fuel burned for trends or changes. Never bothered to setup the scangage to do all that stuff.
  13. Jul 26, 2017 at 11:25 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
  14. Jul 26, 2017 at 12:12 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    You just have to divide miles driven by how many gallons you put in (always full tank obviously). Your way is very inaccurate and I think you will be surprised how much lower actual mileage you are getting.
    The mods you did did absolutely nothing to help your mpg
    rydr1 and TireFire like this.
  15. Jul 26, 2017 at 2:20 PM
    #35
    PMK
    Florida
    10 DCLB TRD Sport
    Inaccurate, I laugh, as you try to school me on this, the fuel log since 2009 has every drop of fuel added, with 99% being fuel topped off the same way each time, with odo miles and trip log miles recorded.
    Since I have the Excel spreadsheet I setup for another vehicle, maybe I need to put the Tacoma in there and see.
    You do not need to be a genious to see the miles traveled vs fuel burned, and when traveling on a highway road trip, to see the scangage showing current mpg it gives a pretty good idea of how far a tank will get you.
    For comparison, how do you log your fuel mpg and have you made any mods to the truck to help or hinder the mpg number. I know one thing, BFG Mud Terrains are expensive to roll compared to other tires, but work good in sand.
  16. Jul 26, 2017 at 2:43 PM
    #36
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    If you expect anyone to believe you are making an AVERAGE 25 mpg you are a fool
  17. Jul 26, 2017 at 3:30 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Misinformed. Science, facts, history, and I all disagree with you. Lol. True
  18. Jul 26, 2017 at 3:32 PM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    All of you mpg nannies can hash it out, while eat my :popcorn: , and enjoy my Smiles per gallons. :p
    TacoLeeSD, oni06, Pigpen and 4 others like this.
  19. Jul 26, 2017 at 3:50 PM
    #39
    82lightfighter
    82lightfighter Well-Known Member
    Donald
    San Francisco
    09 AC TRD Sport 4x4
    Only drivetrain mods I've done to my 2009 AC TRD Sport so far are the TRD exhaust, intake, URD clutch/flywheel, and URD MAF with the map for my setup - thinking this is as far as I will go. Butt dyno tells me midrange has more grunt, more responsive off the line, but this truck will probably never see real dyno testing (I had a 2005 G35 coupe with 360+ at the rear wheels, which did get dyno'ed). Highway MPG has increased, but the truck sounds so good that I ruin my city mpg because I'm having fun with it. Very happy with what these mods have done to my truck.
    Worth the cash? Completely subjective, but I can't leave any of my toys alone...
  20. Jul 26, 2017 at 3:57 PM
    #40
    Whiteghost184
    Whiteghost184 Well-Known Member
    Florida
    2007 URD 4x4 DC LB
    2007 SR5 DBLB 4x4 G2 456 gears front and rear 6" Procomp stage 1 XD 20Ă—10 Toyo 35x12.50x20 E-Load Pioneer head unit Alpine amp running all the door speakers Backflip bed cover Fender Flares URD Stage 1 and 2 Aftermarket seat covers Built Transmission including After market valve body IPT Torque Converter Trans Cooler and EPC Solenoid Full 2.5" URD exhaust and Headers (part of the stage 2 kit) 30" light bar mounted in front bumper Next: M1102 Camp Trailer Conversion
    How in the hell did this turn in to an MPG war? This thread was asking about HP. MPG is not gained through boost or ls swap. Looks like the xls and its doubters are high jacking the sh#t out of this.
    Back to topic, Boost the hell out of it while you build a motor. A wise man on the forum had a sticker that said: "HP is like good sex, you can never get enough!!"
    Torspd likes this.
