4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Mar 20, 2011 at 11:06 AM
    #421
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    sub'd for future reference. :)
  2. May 3, 2011 at 4:24 PM
    #422
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I usually have the dealer do my oil to save time, and it was only a couple bucks more than buying all the stuff to do it myself.. Not anymore. I found out that instead of using a tube on the oil filter plug, they stick an empty quart under the nipple and let it drain out into it. Want to know how I found out? They left it there. It fell. My fan shredded it. Oil everywhere.
    :facepalm:
    I'll be doing it myself from now on.
  3. May 3, 2011 at 4:52 PM
    #423
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Sounds like a real mess they made but look at the bright side... at least you know they actually changed the filter! :rolleyes:
    You'll enjoy doing it yourself and knowing it's done right. Get the 5/16" inside diameter hose and use a hose clamp to permantly install it on the filter drain. I use a plastic plug to cap it off at the other end between oil changes...works great!!:)
  4. May 3, 2011 at 5:01 PM
    #424
    pjr66255
    pjr66255 Member
    Patrick
    Boston
    4x2
    Great tip about the tubing! I have been using a coffee can, but you know it's only a matter of time before it slips out of my hand!
  5. May 23, 2011 at 7:56 AM
    #425
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    Quick question ... The oil filter drain plug that you attach the 5/16" hose to .. do you have to turn that plug to loosen it, and that is what allows the filter to drain or is it just an already open drain and that nipple is for easy connection to a hose?
    I am preparing for my first oil change in my '11 Taco .. I have been doing the oil on my '95 Taco since '99, so I am sure this will be MUCH easier then that. Thanks
  6. May 23, 2011 at 8:30 AM
    #426
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its always open.
  7. May 23, 2011 at 12:27 PM
    #427
    Hipster
    Hipster Nothing beats a Butter Shave..
    Tom
    Tucson
    '10 DC trd 4x4
    Billy's @ .85 w/ Eibachs front, TSB w/ 5100's rear + 1.5" AAL & shims, Debadged, Avid Bolt On Sliders, NFab Light Bar w/ (2) Lightforce 170's. Weathertechs, ATO bed bars.
    As recommended here previously, I use a 16oz empty water bottle, I shove it in and then dump it in the oil drain pan when done.
  8. May 23, 2011 at 1:52 PM
    #428
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Or use a 5/16 hose, and run it to the oil pan......
  9. May 23, 2011 at 2:16 PM
    #429
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    ^^ Cleanest way to do it....
  10. May 25, 2011 at 8:26 AM
    #430
    Big O
    Big O Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    Guys .
    The plug is just a rubber push on cap. There is a little mushroom on the end of the stem that keeps the cap from sliding/falling off. Just pull on it.
    Since the filter is already upside down it's pretty much empth when not powered up. Drain the pan, pull the plug, slip a plastic coke bottle over the plug , & remove the filter. There will not be much oil in it. During all this leave the motor's drain plug off.
    After everything is back together , I always stick a magnet on both the motor's plug & the side of the oil filter's body to help catch any possible metal pieces floting around. It couldn't hurt.
  11. May 25, 2011 at 8:30 AM
    #431
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    this
  12. Jun 3, 2011 at 12:11 PM
    #432
    ee1284
    ee1284 Well-Known Member
    Louisiana
    05 Prerunner Sport
    Just changed my oil for the first time. What a change from my Cobra. Didn't spill one drop. I love this truck more and more.
    Went ahead and put on the fumoto; its hard to believe the oil change could get any easier.
  13. Jun 13, 2011 at 3:48 PM
    #433
    Austan
    Austan Member
    Austan
    Spooner, WI
    '06 DBLcab TRD Stock
    I just finished the first oil change on my Tacoma. I read this thread last night and got the stuff today. quickest oil change I've ever done. This Tacoma makes my Buick look like an idiot. Thanks for the great thread.
  14. Jul 14, 2011 at 1:37 PM
    #434
    JimT
    JimT Active Member
    Jim
    Indiana
    2016 DCLB TRD Offroad
    I don't know if this question has been answered, but it's not simple.
    The cap wrench that I wound up with is 73mm 14 flat I believe. That fit the Toyota filter I put on. The filter I took off was some offbrand T3614 or something and this wrench did NOT fit it. It seems everyone has a different number of flats and diameter. The FRAM filter number is 3614, and the first wrench I bought said it would work on the FRAM, but it didn't work on the other brand 3614. So, if you buy a cap wrench, plan on using one type of filter only.
    I pulled the drain plug first, then the filter. I had no oil drip out of the filter into the catch basin thingy. Gatorade bottle got no love. I also did not have a cap on the nipple. Whatever the quick change places use to "torque stripe" the plug all along the edge is some tough stuff. I had a heck of a time breaking it loose with a 3/8" ratchet.
    Just confirmed 73mm 14 flat is what fit the Toyota filter.
  15. Jul 22, 2011 at 11:24 AM
    #435
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Quick question for Chris or anyone who knows. It is a question that I am pretty confident I know, but just need to make sure.
    I have recently switched to Mobil 1 High Mileage Full Synthetic, I have about 2 quarts of Mobil 1 (regular) Full Synthetic; is it okay to mix the two in the same oil change?
    I assume it is no problem, probably same stuff with just an additive to the high mileage so mixing will dilute the additive, but just wanted to make sure before I did anything like Krazy.
  16. Jul 25, 2011 at 12:51 AM
    #436
    scott572011
    scott572011 Well-Known Member
    SCOTT
    SO-CAL.
    THE RELENTLESS PRUIST....
    BF GOODRICH T/A ko, BILSTEIN HDs, AMERICAN RACING RAZOR`S 16X7.5, READYLIFT SST HYBRID LIFT SYSTEMS, ALTEC LANSING AUDIO,DREGS OF THE EARTH SYSTEMS,WOLF EYES,SUREFIRE ILLUMINATION TOOLS,HK-PROTECTION!!. POP LOCK, SHORTY ANTENNA, TACO TENT #3,. NITECORE ILLUMINATION, FENIX FLASHLITES. STILL PROTECTOR`S, FACTORY BED MAT, CUSTOM BED WEB, INTRO-TECH INTRO-GUARD CUSTOM TRUCK COVER, CENTER CONSOLE LOCK MOD, TECH-SHADE M1068, WEATHER-TECH CLEAR-COVER`S, OEM MINI TIE-DOWNS, TRUCK BEDZ AIR MATTRESS EXPEDITION SERIES, McGARD TOUGH NUTS WHEEL LOCK`S, DISABLE SEAT/BELT CHIME MOD, GARMIN GPS, KERSHAW BLADE`S, SKELETOOL, WEATHER-TECH FLOORLINER DIGITAL-FIT GRAY # 461781, NITE(IZE) KNOT-BONE ADJUSTABLE BUNGEE SYSTEM, WET OKole SEAT COVERS, UNDER DASH FLYZEYE BW LED LIGHT W/CUSTOM BLUE HALOS. NITECORE IFE1 INFILUX ILLUMINATION SYSTEM. JETBEAM BC-10 HANDHELD, HK VP-70Z 9mm PROTECTION!. JETBEAM PC-10 550 LUMEN ILLUMINATION SYSTEM. SUREFIRE E2D-LED-DEFENDER ULTRA 500 LUMENS KICK ASS ILLUMINATION...VIPER ALARM SYSTEM`S,ROCKFORD FOSGATE POWER COMPONENT SYSTEM`S.KENWOOD AUDIO/VIDEO,HUSHMAT SOUND DEADENING INSULATION,3M AUTOMOTIVE FILMS.
    pretty safe bet, as long as you stick with the same viscosity should be good to go!!
  17. Aug 14, 2011 at 6:28 AM
    #437
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    subbed
  18. Aug 16, 2011 at 5:07 PM
    #438
    Saltlife
    Saltlife Member
    kevin
    Florida
    2010 TRD sport 4x4
    None yet
    this question may have been answered already but, the tubing is 5/16" ID correct?
  19. Aug 16, 2011 at 5:12 PM
    #439
    rex99
    TArdCOMAWORLD
    Proton Cruiser
  20. Aug 16, 2011 at 5:37 PM
    #440
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ID is correct.
