4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Jan 11, 2014 at 6:44 PM
    #761
    parallel60
    parallel60 Member
    Richmond, British Columbia
    07 Tacoma SR5 4x4 4.0L
    Going to do my first Oil Change on my new(used) Tacoma 4.0L V6. I bought Castrol Edge Synthetic Oil and a Toyota filter from the dealer. Anyone had any issues with Castrol Oil?
    Thanks
  2. Jan 11, 2014 at 6:59 PM
    #762
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Others can chime in about the Castrol, but the majority of people here on TW are avid users of the Mobil 1 product. And welcome to TW! :wave:
  3. Jan 11, 2014 at 7:02 PM
    #763
    quantum
    quantum Well-Known Member
    i switched from Mobil1 to Pennzoil Platinum and the engine idles quieter and last time i change oil the magnetic drain plug had NOTHING on it.
  4. Jan 12, 2014 at 12:19 PM
    #764
    parallel60
    parallel60 Member
    Thanks for the Welcome, yep I've been hearing that most use Mobil one. And its about half the price of Castrol in Canada so after this one I will probably switch to Mobil 1 SYN.
    Quantum, so you had some metal with Mobil 1?
  5. Jan 12, 2014 at 12:52 PM
    #765
    quantum
    not alot, but some, but since i switched to PP there has been none
  6. Jan 12, 2014 at 2:30 PM
    #766
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I wonder if it's good or bad? Bad = metal shavings still suspended in the oil causing damage. Good = "higher viscosity" keeping parts from wearing and creating shavings.
  7. Jan 12, 2014 at 7:34 PM
    #767
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I used nothing but Castrol Syntec in my 08 PreRunner and started with it in my '10 until they phased out Syntec for Edge. All the numbers were showing... Edge is crappy oil that doesn't protect. Read up on bobistheoilguy.com and there's plenty of Blackstone Lab reports showing how poor Edge was protecting. The 4.0's do like Mobil One and constantly show good lab results with the 4.0... so that's what I switched too for the last 60 or so thousend miles.
    The Toyota filters are some of the best filtering as well, basically a WIC filter. I run K&N on my truck mainly because... I like the 1" welded on nut and it performs very adequately.
  8. Jan 12, 2014 at 9:18 PM
    #768
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    I've been sticking with the Toyota filters as well. Toyota filter and Mobil 1 full synthetic :thumbsup:
  9. Jan 13, 2014 at 3:51 PM
    #769
    parallel60
    parallel60 Member
    Ok thanks for the info, will go with Castrol on this one and the Toyo Filter then most likely swap to Mobil 1.
  10. Jan 17, 2014 at 3:24 PM
    #770
    ryan c
    ryan c rookie
    ryan
    661 Lake Ez
    '06 4x4 swb dc
    2.5" lift in front, aFe air intake, anytime foglights, cut 9" off antenna, superwhite headlights, spintech exhaust, med. tint in the front, weathertech floorliners and caltech seat covers, dashtek dash cover, CHLM, debadged and destickered,
    Hey guys this might have been asked somewhere but I didn't read all 39 pages. Sorry lol. Ive changed my oil about 10 times now and have always just put in 5 qts. Not 5.5 qts. Could this cause damage? My dipstick is always in the middle. Its an 06 4x4. Thanks!
  11. Jan 18, 2014 at 1:57 PM
    #771
    vanlancf
    vanlancf New Member
    Chad
    Dallas
    Thank you for clearing that up. I was confused by the picture.
  12. Jan 18, 2014 at 4:45 PM
    #772
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I must be missing something, but I've been reading bobistheoilguy and am not finding where it says Edge doesn't protect. Everything I've read, says it's a good oil. Do you have a specific location where it says the Edge isn't as good? I've been using Edge and will discontinue it's use, if I can see what you mentioned. Thanks.
  13. Jan 19, 2014 at 3:17 PM
    #773
    AznTRD
    AznTRD Well-Known Member
    813 FL
    '12 TRD Sport DCSB
  14. Jan 19, 2014 at 3:24 PM
    #774
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Honestly I don't remember. There were a bunch of threads on it when it first came out and started phasing out syntec. It was not tacoma specific. I was also following 3000gt and g35 / 350z stuff around there too
  15. Jan 19, 2014 at 5:29 PM
    #775
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I used Castrol GTX for years (3000 mile intervals) and switched to Castrol Syntec (now Edge) several years back and have been doing 5000 mile intervals. The 22R-E in my '92 was pristine at 130K miles on conventional oil. Honestly, I think GTX would be fine at 5000 mile intervals, I just like the (possibly perceived) start-up protection of synthetic. I will continue to use Castrol and not be worried.
    I couldn't find any info on BobIsTheOilGuy either, but I might be convinced to change to Mobil 1 if there was some verifiable information on it being significantly better. That other site seemed like an Amsoil rep put it up. If I can't get it at AutoZone, I am not going to mess with it.
  16. Jan 19, 2014 at 5:40 PM
    #776
    ImpulseRed008
    Susan
    SC
    Ok..... thanks
    ^this. Used to use castrol and change 2500 - 3000 miles, had to change when I had the chance. Actually, even with the Syntec, I'd change the same mile interval. Most of my driving was 2100 - 2400 miles at a time (over 3 days) and figured it was cheap insurance and didn't want to go over 5000.
  17. Jan 23, 2014 at 10:05 AM
    #777
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Get a silver sharpie and write the date/miles/oil brand on the new filter
  18. Feb 19, 2014 at 12:00 PM
    #778
    fenderpicks
    fenderpicks Well-Known Member
  19. Feb 19, 2014 at 12:10 PM
    #779
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    That is how i discovered the local oil change shop didn't replace the filter in my wife's car. I've been doing it myself ever since.
  20. Feb 19, 2014 at 12:46 PM
    #780
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
