4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Dec 23, 2019 at 11:55 PM
    #1081
    VathPoots
    VathPoots New Member
    VathPoots
    I have this question about oil change in my mind.
    Toyota recommend every 6 month/8000km for the oil change for Yaris, but it seems a bit long to me, will it hurt the engine if I change it every 8000 km, or should I change it like every 5000km or 6000km?
    Need some expert to give me some advises on it
  2. Dec 24, 2019 at 8:54 AM
    #1082
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Not sure if you're serious, or aiming for humor?
    Following car manufacturers' recommendations should not hurt an engine they built, as long as you use oil and filters of at least the same specification/quality as called for in your owner's manual. Many modern vehicles using synthetic lubricants call for oil/filter changes at or above 8000km (5000mi). (My wife's last few BMWs recommended a roughly 15,000mi/24,000km change interval!)
    Rick_Taco likes this.
  3. Jan 14, 2020 at 5:00 PM
    #1083
    jaydeebee
    jaydeebee Little-known member
    Wild West
    2010 TRDORDC
    Forgive me if this has already come up, but my oil filter had no oil to drain at all when I changed mine this morning. Is that a bad sign or something? I changed it cold after the truck was sitting in a freezing garage for a good 12 hours, so I thought that might be the reason. But I wanted to check in with the gang here before I errantly drive this thing over the pass next week thinking I've done good.
    I used to always do my oil when life was simple - no kids and a basic fwd coupe. This was my first time doing the Taco after putting 50k on it (it's at 105k+ now), and honestly I'm just glad I didn't accidentally drain the transmission instead of the engine.
  4. Jan 14, 2020 at 7:42 PM
    #1084
    Norton
    Gravity is hard to escape and drainback valves aren't 100% reliable. I'm relatively confident you'll be fine driving over the pass, as long are you properly secured a decent filter and addded the proper amount of oil. What kind of filters are you running, BTW?
  5. Jan 14, 2020 at 8:38 PM
    #1085
    jaydeebee
    Wild West
    2010 TRDORDC
    Thanks for the feedback.
    I didn't take note of the filter I took out, but it was whatever aftermarket they use at my local Jiffy Lube :crapstorm:Like I said, I'm getting back into doing some basic maintenance but was always kinda lazy/intimidated by the needs of a truck compared to what I used to drive (mechanic stuff is totally foreign to my upbringing and it seems that everything useful thing that I need to know comes from TW or YT). But now I have proper 0w-20 Mobile 1 oil at 5.5 quarts and OEM filter, I felt the truck was running better after the change, more "effortlessly" if that makes sense. But again, the fact that no oil drained from the filter upon removal weirded me out. I did just see this thread, so apparently I'm not the only one, so perhaps with my new OEM filters there'll be some oil spillage when I replace it in 5k miles.
  6. Jan 15, 2020 at 4:27 PM
    #1086
    Norton
    I found the problem! :rofl:
    I think you'll be happier with OEM filters, which many believe to be the best choice for our trucks. Mobil 1 is good stuff too, though opinions are more varied when it comes to oil types, brands, etc. As long as 0W-20 is what your Owner's Manual recommends, you should be in good shape.
  7. Feb 4, 2020 at 7:41 PM
    #1087
    avery81
    avery81 New Member
    2009 Tacoma Sport Double Cab
    Anyone have the part number for that "New oil plug gasket (available from dealer)" Can I literally just drive up to a Toyota dealer and get a bunch for free/less than $20?
  8. Feb 4, 2020 at 8:00 PM
    #1088
    CO Ryan
    CO Ryan Well-Known Member
    Colorado
    13 TRD Offroad
    stuff
    90430-12031
    Usually sold in 10-packs for around $10. Beware of counterfeits if you order them online. Welcome to TW!!
    avery81[QUOTED] and Rick_Taco like this.
  9. Feb 5, 2020 at 6:02 AM
    #1089
    avery81
    avery81 New Member
  10. Feb 5, 2020 at 8:05 AM
    #1090
    Jon M
    Jon M Well-Known Member
    SE Minnesota
    09 Tacoma SR5 TRD Sport w / Towing Pkg
    I just installed the Fumoto F-103S. That thing is sick. No oil drips, drops, leaks, or anything. Actually makes me look forward to the next oil change (the first time I'll be able to use it).
    I run Pennzoil 5W30 Platinum Full Synthetic with the Toyota filter; 5.5 quarts gets me right at the full mark. I only look at the side of the dipstick where the little nubs stick out.
    Edit: I installed the 103S. The shorter one.
  11. Mar 11, 2020 at 10:23 PM
    #1091
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    The other guy gave you the answer you were looking for, but just FYI can also use standard M12 copper crush washers. You can get them just about anywhere and they are dirt cheap (Amazon for example).
  12. Mar 22, 2020 at 2:20 PM
    #1092
    lechuza39
    lechuza39 New Member
    john
    2013 tacoma V6
    none
    Does the skid plate (gravel guard?) need to come off to be able to reach the drain plug?? Doing my first oil change... Looking underneath engine it is not easily spotted.
  13. Mar 22, 2020 at 2:58 PM
    #1093
    Norton
    Not for a stock 2nd Gen.
  14. Jun 29, 2020 at 9:42 AM
    #1094
    D3LT4C0
    D3LT4C0 New Member
    Glen Rock, PA
    2015 DCLB 4x4
    Great write-up! Couldn't find a bungie so 16ga wire had to do
  15. Aug 18, 2020 at 2:50 PM
    #1095
    SpyderMan
    SpyderMan Well-Known Member
    Morgan Hill, CA
    05 TRD
    Nice article. Helped me change my oil the first time I did it way back when...
  16. Oct 8, 2020 at 7:56 AM
    #1096
    RedSki7
    RedSki7 CRF | TRD | PBR | 802
    Hollis
    Vermont
    06 AC V6 TRD OR 6sp | 02 RC 2.7L SR5 4x4 5sp
    Duck Tape, Zip Ties, & Spray Paint
    Is it possible to leave the oil filter drain line attached and route it so that it is secure for the next time?
  17. Oct 8, 2020 at 9:37 AM
    #1097
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    Certainly is, but for the oil drips in the driveway.
    Maybe route it near the oil pan drain plug, with a stopper in the end between oil changes?
    RedSki7[QUOTED] likes this.
  18. Jan 9, 2021 at 6:55 AM
    #1098
    SoCal_Erik
    SoCal_Erik Tiki Taka, Tika Taka
    ‘23 Tundra SR5 Sport, ‘16 SR5 DCSB (sold), ‘15 SR5 DCSB (sold), ‘16 4Runner SR5, ‘15 OR DCSB (sold), ‘05 SC (sold)
    Didn’t have to come back to this thread yesterday as I changed my oil for the second time. Took me 20 minutes! And in between changed all my filters.
  19. Jan 9, 2021 at 7:00 AM
    #1099
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    didja lube the prop shaft????
    Norton likes this.
  20. Jan 9, 2021 at 7:07 AM
    #1100
    SoCal_Erik
    I’ma newbie to maintaining my own vehicles. Motos i can work in all day. Correct me if I’m wrong, but it’s this a 4x4 maintenance only? Thought 2WD tacos were sealed.
