4.0L belt squealing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skynet Surfer, Apr 19, 2023.
  1. Apr 19, 2023 at 8:04 AM
    Skynet Surfer
    Skynet Surfer [OP] Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    So I replaced my belt about a year ago. It starting to squeal again. I'm wondering how bad of a problem this is? Only happens on startup and under hard acceleration.
  2. Apr 19, 2023 at 8:48 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Could be a pully or your belt tensioner
    wilcam47 likes this.
  3. Apr 19, 2023 at 8:56 AM
    Skynet Surfer
    Dis
    15 DC v6 SR
    I replaced all pullies when I did the belt using koyo bearings, as I can recall. It hasn't even been a year. But should I be concerned it if only happens at startup and hard acceleration? Granted it could be the tensioner but that looks like a pain to replace.
  4. Apr 19, 2023 at 11:33 AM
    DaleRS
    DaleRS Well-Known Member
    Dale
    Cleveland, Ohio
    2015 Black DCSB SR5 w/ Snugtop
    Have you pulled the belt off and visually inspected it for damage? Even if it looks alright, there still may be damage to it. I just went through this about a week ago. The belt was squealing but looked perfectly fine when I pulled it off the truck. Swapped it with a new one and I haven't had a problem with the squealing since.
    Is the belt OEM? Aftermarket?
  5. Apr 19, 2023 at 11:38 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The tensioner pulley can be replaced in-situ. Beware it's a LH-threaded bolt. Usually the tensioner pulley is the same P/N as the lower idler pulley.
    Use either OEM or Bando-branded belt. Other brands can squeal.
    davidstacoma and DaleRS like this.
  6. Apr 19, 2023 at 4:17 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check pulleys and tensioner.. but keep in mind there's 2 kinds of Bando available. The OEM Bando is more expensive and will stay quiet. There's a cheapie Bando that sucks and will make noise within 3 weeks. Ask me how I know..
    Gates makes a good belt. Some guys swear by Continental "gator-back" ..
    goforbroke123 and TnShooter like this.
  7. Apr 19, 2023 at 5:15 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^My experience with Gates in my Subaru was bad. Belt liked to slip on the power steering pump pulley no matter how hard I cranked the tension. Replaced with aftermarket Bando from Rock Auto and the slippage went away.
    For the 4Runner, the Toyota OEM belt carries the same Bando P/N as the aftermarket Bando.
  8. Apr 19, 2023 at 5:30 PM
    Bishop84
    Bishop84 Well-Known Member
    When I offroad more often I eat belts, dust, dirt, mud, all are bad for belts.
    I had a busy offroad year 2020 and my belt only lasted one year. Bando belt.
    SlimeInnaTaco and HondaGM like this.
  9. Apr 19, 2023 at 7:29 PM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    Certain things make sense to price shop, but when it’s comes to Serpentine belts, timing belts/chains get OEM. Just the peace of mind and what are saving $20 buying an auto parts store belt. Not worth it IMO.
  10. Apr 19, 2023 at 7:29 PM
    DaleRS
    Dale
    Cleveland, Ohio
    3JOH22A and goforbroke123 like this.
  11. Apr 20, 2023 at 7:21 PM
    B Dog
    B Dog Active Member
    Barry
    Eugene, Or
    2009 silver Tacoma PreRunner Double Cab
    I recently had a problem similar to this. I had replaced y belt about two years ago and it had started to squeal on start up. I replaced it with a new belt and after a couple of days was having the same problem. I went to a friend who has been a mechanic for years to figure out why. He took one look and asked to see the routing diagram. I had accidentally gone underneath the pulley between the power steering pump and the water pump. He noticed that that pulley was not shiny like it should be. I had been running it like that for two years and when I put the new belt on I did the same thing. I was kind of embarrassed that I did not catch that.
  12. Apr 21, 2023 at 8:32 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The bearing in the pulley is replaceable if the pulley is in good condition. Last I checked, only Febest sold a pulley/bearing combination but it is a Chinese-made part. There are several Japanese-made bearings that can replace the oem bearing in the pulley. I have a thread with more detailed info.
    https://www.tacomaworld.com/threads...arings-in-the-idler-tensioner-pulleys.480961/
    Spray belt with water to see if the noise goes away temporarily - until the water dries out. If noise goes away, that tends to ID the belt as the source of the noise. First spray on one side of the belt, then the other. If no change in noise, a hearing is likely the culprit - this could be a pulley/tensioner bearing or the water pump, alternator or PS bearing.
