4.10 gears and 33's
Discussion in 'Performance and Tuning' started by Volcom21, Feb 17, 2012.
  1. Feb 17, 2012 at 9:01 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    How do heavier/wider tires at the same rpm getting you better mpg?
  2. Feb 17, 2012 at 9:03 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    that is what i run currently. pretty exact i must say.
    stock gears with 33's
  3. Feb 17, 2012 at 9:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The engine is doing less work to spiin the larger tires. Less work = better mpg. Larger tires add much more rotational mass to the drive train. Re gearing can give the engine more leverage in which to turn the tires. More leverage = less work= better mpg. I dont think I was able to do any accurate highway testing to be able to draw an accurate conclusion as to a gain.
  4. Feb 17, 2012 at 9:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  5. Feb 17, 2012 at 9:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  6. Feb 17, 2012 at 9:10 PM
    worthywads
    So what are you recalculating if the ODO is accurate?
  7. Feb 17, 2012 at 9:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Tire size. By increasing the tire size by 7.4% (Which I did), I added that to the odo when calculating my MPG. On my Dodge, as with most vehicles, changing tire size affects the ODO.
  8. Feb 17, 2012 at 9:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    AS can be seen in the graph (tranny tested in a 1:1 gear) 4.11's and 33" tires, will put the truck only 92 rpm higher at speed, than the stock gears/tires combo.
  9. Feb 17, 2012 at 9:16 PM
    tacobo670
    Ray
    Las Vegas
    very good link. bookmarked. thanks
  10. Feb 17, 2012 at 9:26 PM
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    I got 33"s and though I should go 4.56 when I regear in future, but now I see that 4.10 is better from this thread and the chart. Maybe better for lil more power back to go with thee 4.56 since overgeared more, but 4.10 is still over from stock...
  11. Feb 17, 2012 at 9:30 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    So whats better for 33's 4.10's or 4.56's im gonna regear in the future and i dont know shit about regearing :(
  12. Feb 17, 2012 at 9:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I prefer 4.10's, as you are still slightly "over geared".
  13. Feb 17, 2012 at 9:35 PM
    BulletToothTony
    So basically i'll go back to how it was stock before the 33's?? And would that mean that 4.56's are even higher "over geared"?
  14. Feb 17, 2012 at 9:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. The 4.56's would put you about 400 rpm higher at speed, than what stock with 31" tires would be.
  15. Feb 17, 2012 at 9:42 PM
    #35
    BulletToothTony
    Thank you sir, you just cleared up alot :cool: now i dont have to research and start a new thread lol :rolleyes:
  16. Feb 17, 2012 at 9:43 PM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!! :)
  17. Feb 17, 2012 at 9:46 PM
    #37
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Chris, what should I expect to pay to have my new gears installed in my rear differential?
  18. Feb 17, 2012 at 9:47 PM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For parts and labor, figure about 500 to 650 per axel, depending on the shop. Its about the best mod for the buck you can do for the truck.
  19. Feb 17, 2012 at 10:04 PM
    #39
    Cortland
    Cortland
    California
    Any recommendations of where to go in Phoenix? Also, with 255's or 285's and 4.10's do you think my MPGs will go up from what I'm getting with 265's and stock 3.73's?
  20. Feb 17, 2012 at 10:06 PM
    #40
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Hey Chris, this may be a dumb question but I heard there is a difference in sizes when it come to a Tacomas pumpkins. I heard that because I have a locker I have to get a ring and pinion for a 8" and all others can use the 8.4...I'm not sure what this means :eek:
    Help :confused:
