4.10 gears and 33's
Discussion in 'Performance and Tuning' started by Volcom21, Feb 17, 2012.
  1. Feb 17, 2012 at 10:07 PM
    #41
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Chris knows all...
  2. Feb 17, 2012 at 10:08 PM
    #42
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    You drive around chino right?? I've seen you're truck alot lately...I'm regeared if you wanna see how 4:56s run...I regeared about a year ago. :thumbsup: let me know...
  3. Feb 17, 2012 at 10:08 PM
    #43
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I agree
  4. Feb 17, 2012 at 10:21 PM
    #44
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont think your gonna get better mpg than you would stock.
    Yes. The locker has an 8" housing, while the TRD SPorts, and others have an 8.4". IIRC, THe gears are all 8" though.
  5. Feb 17, 2012 at 10:25 PM
    #45
    ColtsTRD
    Scott
    AZ
    so 4.10s from a 4cyl WILL fit my truck no issue? Should I even bother regearing when I get 285s?
  6. Feb 17, 2012 at 10:27 PM
    #46
    Cortland
    Cortland
    California
    do you think that it will be worse than stock though?
  7. Feb 17, 2012 at 10:30 PM
    #47
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I see the argument but that goes against what I've seen.
    I've tried many times with a scangauge to compare mpg using 4th and 5th gear, and in every situation 5th gear shows better mpg even if at lugging speed. On flat ground or climbing a hill I never see an increase in mpg with higher rpm and more leverage as you describe. Driving at near lugging speed is essentially the same as bigger tires and no regear.
    All us hypermilers keep it low rpm short shifting below 2000 rpm with no leverage, but better results.
    This is a topic that I haven't found any solid testing done after much research.
  8. Feb 17, 2012 at 10:40 PM
    #48
    Volcom21
    Volcom21 [OP] Member
    Inland Empire
    05 white prerunner
    Yeah i think i have seen your truck a lot this week. That would be cool if i could see how it runs. What would you say you top out at? And if your still doing the led speedometers, id be interested in that too. Thanks
  9. Feb 17, 2012 at 10:49 PM
    #49
    Jerez
    Rod
    Ontario Ranch
    Estock
    Yup, you have your custom CA plates "VOLCOMA" right??
    Let me know, and yes I still do the swaps...send me a pm n we can meet up.
    I saw you yesterday at Chino high when I went to pick up my bro
  10. Feb 17, 2012 at 11:44 PM
    #50
    Volcom21
    Inland Empire
    05 white prerunner
    If i went back to even getting to close to the mpg's i did when i was stock that would be fine. Anything better than what i get now would be good. I just wanted to make sure i could at least get to 90-100 mph top speed
  11. Feb 18, 2012 at 12:06 AM
    #51
    commando
    commando Well-Known Member
    Brandon
    Oregon
    2006 SR5 Double Cab 4X4
    3" spacer lift
    I haven't even burned up 1 whole tank of gas yet! I just got them last week. I can tell you that I drove around in the woods all day and only burned 1/2 tank. It seems to be better.... (I know it is.) I will PM you once I do a mileage check OK?
    That's what I did! Did you check out my thread I linked in post 7?
    My truck could do 100mph easily. I have to double check, but at 60MPH I am only at 2000rpm or so. It dosen't seem to me like it is winding up bad on the highway at all. It's perfect, and the power aint bad either!
    It's pretty nice not having to mash down on the gas, and force it to drop down a gear, to make it go anymore!
    Again, I am running 4:10's and 255/85/16's in my 2006 4.0L 4X4.
  12. Feb 18, 2012 at 12:23 AM
    #52
    Volcom21
    Inland Empire
    05 white prerunner
    Thats basically what i was looking for some extra acceleration power and not getting horrible gas milage on the freeway, thanks
  13. Feb 18, 2012 at 6:39 AM
    #53
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They should.
    It shouldnt be.
    Are you running larger tires? The method you are useing as a "test" is flawed, as you are already geared optimally from the factory, for best mpg/performance. Adding larger tires throws that all out of whack, and you become too "Under geared", and the engine works too hard at trying to spin the tires, along with moving the truck. Read the link I posted.
  14. Feb 18, 2012 at 10:02 AM
    #54
    worthywads
    Is this what you are directing me too?
    "Your truck comes from the factory with the optimum axle gear ratio to work with the truck's engine, transmission, and stock tire combination as well as provide a good balance between acceleration and fuel economy. When taller tires are installed on a truck but the axle ratios stay the same; the effective gear ratio is reduced. This means the engine is forced to operate below its power band, and performance and fuel economy suffer as a result. In order to restore the effective gear ratio (and the truck's performance), you'll need to have the axle gears swapped to lower (numerically higher) ratios."
    I'm intentionally staying below the powerband of my engine with excellent mpg, but this says I'm wrong. It doesn't say my test method is flawed. It does speculate that every car manufacturer is optimized every engine/tire/gear combination which we know isn't true. My wife's Element spins 4000 rpm at 80, that is retarded Honda optimizing.
    This also from your link would seem to agree with my take.
    "If you're looking for a ratio that will give better fuel economy for highway driving at the expense of some acceleration and overall performance, choose a ratio in the yellow shaded area. If you're looking for a ratio that will improve acceleration and towing power at the expense of some fuel economy, choose a ratio in the blue shaded area."
  15. Feb 18, 2012 at 10:34 AM
    #55
    DevL
    DevL Well-Known Member
    Dude it does not work the same using a fixed tire size and shifting gears. Bigger tires require harder accelerator pressing to get moving at the same rate. You regear you gain city stop and go milage... but have higher rpm on freeway at fixed speed. Changing your gear from 4th to 5th in no way simulates this. My buddy has done dozens of gear swaps on Tacomas and Jeeps and always gets better mileage. Am I supposed to believe his and everyone else's real world experience or your imagination based off a flawed experiment?
    Reagearing will boost your milage in the city. He also told me I would get a similar gain in city milage with 4.56 in the city but hurt highway milage substantially. The negative is the requirement for a new carrier if you go 4.11 in the front diff. Ther is no carrier break for rear gears. If you get a ARB up front it IS a new csrriet so not a problem... then there is the shortage of 4.11 gear availability.
  16. Feb 18, 2012 at 12:07 PM
    #56
    worthywads
    Thanks for joining the conversation.
    What you say may well be true for many applications, maybe with automatics it is different than manuals where I can pick the gearing and not be forced into some downshifting that big tires might cause.
    With the V6 and poorly chosen OD 6th gear I would guess that with bigger tires you will gain back the mpg that you would have gotten if Toyota decided on a better OD like on the auto.
    Anyone out there with V6 Stick find their mpg increased with bigger tires after factoring for tire size change? The extra weight and rolling resistance may simply offset the lower rpm, but I don't see how regearing to get back to a poor OD ratio for highway speeds will ever help mpg in that example.
    If toyota optimized like we are supposed to believe the 6-speed would have the same OD gearing as the auto and there wouldn't be a 2mpg EPA hit with the stick.
  17. Feb 18, 2012 at 12:11 PM
    #57
    bizjettech
    bizjettech Well-Known Member
    Sunny Florida
    Anyone running 33's with 4.10's and V6 - Automatic?
  18. Feb 18, 2012 at 2:02 PM
    #58
    commando
    Brandon
    Oregon
    3" spacer lift
    Me. See link in post #7.
  19. Feb 18, 2012 at 2:11 PM
    #59
    bizjettech
    Sunny Florida
    How is that workin out for you? Happy with it?
    MPG?
  20. Feb 18, 2012 at 2:15 PM
    #60
    commando
    Brandon
    Oregon
    3" spacer lift
    Very, very happy. I am still on my first tank of gas, just got them last week!
    I will try and get some MPG#'s up soon.
    The power you get back is noticeable, and much mo' better.
