4.10 gears and mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LVTacoma, Sep 24, 2010.
  1. Sep 24, 2010 at 1:45 PM
    LVTacoma
    LVTacoma [OP] Well-Known Member
    Would swapping up from the 3.73 to the 4.10 have a big impact on mpg? Im getting ~ 19 right now. I would assume it would drop a bit. Input?
  2. Sep 24, 2010 at 1:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    What size tires are you running? Might as well go up to 4.56 if your running 33's.
  3. Sep 24, 2010 at 1:56 PM
    LVTacoma
    265/75 for now but they are shot and will be putting 285/75 on within the next two months or so
  4. Sep 24, 2010 at 1:58 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    go with 4.56's then, You will actually get better mileage with these and 285's than with 4.10's and 285's and have more power.
  5. Sep 24, 2010 at 2:02 PM
    Tberry5000
    Tberry5000 Well-Known Member
    Travis
    Florida
    super white tacoma
    one day....
    i am running 35's. what gears should i upgrade to if i want better mpgs?
  6. Sep 24, 2010 at 2:05 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    what drivetrain?
    If you have a 4.0L V6 then 4.88's
  7. Sep 24, 2010 at 2:20 PM
    LVTacoma
    Whats a 4.56 going to limit me at freeway speeds? I do 70mph @ ~1800-2000rpms. A guy I work with has a TJ with 4.56s, 35's and gets 10mpg :eek:
  8. Sep 24, 2010 at 2:27 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    i have been wondering about this also...i travel mostly interstate at 70mph @ 2500-2800 rpms......any way i could drop the rpms for better mpgs
  9. Sep 24, 2010 at 2:43 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Higher gearing will always lead to decreased mileage if you actually calculate real driven miles and not what your odometer is telling you.
    edit: by higher gear I meant higher RPM. Sorry for miss expression. But I stand my point, higher RPM = Lower MPG.
  10. Sep 24, 2010 at 2:55 PM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    this guy is out of his head your gas mileage will go up with lower gears there sure are alot of dumb people on here and yes i dont sign with some stupid ass quote
  11. Sep 24, 2010 at 2:55 PM
    DevL
    DevL Well-Known Member
    4.10 is already steeper than foactory gears and tires when paired with 285 tires. Why would going even steeper than that give him beter gas mileage? Why would Toyota intentionally give us worse gearing for gas milage AND power simulataneously? Your post makes no sense.
  12. Sep 24, 2010 at 3:00 PM
    davestaco
    David
    Schofield Barracks
    ok...last 3 post really screwed me up going with higher gears gives you worse gass milage? i always thought you got higher gears for better highway driving and mpgs and but you would sacrifice offroad crawling and performance
  13. Sep 24, 2010 at 3:12 PM
    N3ZAT
    Charlie
    Coatesville,Pa.
    09 tacoma
    4:10s are lower gears so you will be turning higher rpm so you truck will feel more power but actually u have more torque . hp from engine will not change with different gears.At 70 mph you will be topping out on speed but you will get there alot faster.
  14. Sep 24, 2010 at 3:33 PM
    Twiget
    Twiget Proud to be Awesome
    America's Vancouver
    654, 6 Cylinders, 5 Speeds, 4 wheel drive
    Alpine Headunit, Soft Tonneau Cover, CAI
    Changing your tires and rear end gear ratio is a game of give and take.
    The simple version is that changing the size of your tires will change the RPM your motor needs to run at to maintain a given speed. The bigger the tires, the lower the RPM for a given speed. Rear end gears are the opposite. Lower gear ratios will reduce RPM for a given speed and higher gear ratios will increase RPM for a given speed.
    In my Taco with my current setup, 70mph is ~2000rpm. Increasing the tire size will reduce the RPM's needed to run at 70mph, which can result in improved MPG. However, if you increase the tire size too much, 2 things begin to happen. First is that the lower RPM's at a given speed may mean your no longer in the power band for your motor and performance will suffer. Combine this with the fact that bigger tires are usually heaver and will take more power to spin and the end result is that the truck feels sluggish and MPG may suffer.
    To counter the sluggishness of bigger tires, you can increase the gear ratio in the rear end of your truck. Increasing the gear ratio to 4.10 or 4.56 will increase the engine RPM at a given speed, and hopefully put your engine back in its power band.
    To answer the question of what RPM you'll be running at with a given tire/rear end combo, try out this calculator.
    To answer your original question about MPG, changing the rear end ratio will affect it. I dont know how much though. It is one of those "Your mileage may vary" (no pun intended) things.
  15. Sep 24, 2010 at 4:05 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Couple of questions...
    1. Who makes the 4.56 gears?
    2. Does anyone make STRONGER gears than the factory ones?
    I'd assume that for a 4x4 you'd need gears for front and rear *unless you never engaged 4x4 mode... I'm really curious as to how much this would cost as I live no where near a good off road shop.
  16. Sep 24, 2010 at 4:14 PM
    DevL
    I believe all 4.56 gears are actually weaker than stock gears becaus e of the reduction in gear teeth on the pinion.
  17. Sep 24, 2010 at 4:40 PM
    DrRabbitFurHead
    Salem, VA
    Can't they change the material? Ion Nitride the steel? Something to make the gears "stronger"?
    Also, did some research on TTORA and found a few companies, but this gets confusing fast. :confused: Good luck to the OP!
  18. Sep 24, 2010 at 6:17 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    according to this, http://www.grimmjeeper.com/gears.html with 33's and 4.56 gears you will be at 2319 RPM at 70 mph with an automatic transmission.
    with 4.10 you will be at 2085 RPM. Now you have to remember those are way heavier tires than stock so you will want to have the RPM's up to stay in the power. You may loose a bit of highway mileage but you will gain some city. If you live in flat area the 4.10's may be fine but if you do any offroading at all, you will love the 4.56's. It depends on what you use the truck for.
    If you match the gear ratio with the tire size, IE get the RPM's back to where they were with stock tires you will get your mileage/power back, do a little searching/get some common sense and you will find the same :thumbsup:
    The 3.73's are ok for stock 31" tires, but OP is upping the size to 33's so he needs a lower gear ratio to get the mileage back.
    :thumbsup:, but he won't be anywhere near topping it out at 70.
    :thumbsup:
    This is true, but the difference is so small its almost negligible. Plus most aftermarket gears are WAY better than the stock toyota gears as many members on here will verify.
  19. Sep 24, 2010 at 8:57 PM
    Tberry5000
    Travis
    Florida
    super white tacoma
    one day....
    so i want to get better mpgs guys.... right now i have 6inch lift on 35's. help me please!!!!!
  20. Sep 24, 2010 at 9:11 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    you will likely want the 4.56 or 4.88
