4.10 gears and mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LVTacoma, Sep 24, 2010.
  1. Sep 24, 2010 at 9:19 PM
    Tberry5000
    Tberry5000 Well-Known Member
    Travis
    Florida
    super white tacoma
    one day....
    and ill get better mpg's?
  2. Sep 24, 2010 at 9:31 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    The least it will do is get you back to your stock mileage. When you put on the lift and heavier tires you gained weight, wind resistance and changed your RPM to MPH.
    The gears will make it as if the new tires are the stock height just heavier, they won't do anything for the added resistance from raising your truck. When you went with a taller tire it made your gears act numerically smaller/a higher gear. Now by insatlling Numerically higher/lower gears it will revert back to stock depending on the gears you choose. My truck as an example. Stock gears are 3.73 I added tires 33" tall, gears now feel like they are 3.50. To counter act that I can insatll some 4.10 gears which will, due to the tires act almost like 3.73's again. Putting my truck back to stock.
  3. Sep 24, 2010 at 9:38 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I would assume your truck right now feels as if it has some 3.25ish gears because of the 35s.
    Rough estimates but will give you an idea.
    will feel like 3.58's with 4.10
    will feel like 3.98's with 4.56
    will feel like 4.26's with 4.88
    I can't promise better gas mileage with any of these but if you get it closer to 3.73 you will be better than you are now. You have to try and keep your truck in its power band. That will depend on the driving you do as much as the gears and tires.
  4. Sep 24, 2010 at 10:05 PM
    Crownedcustoms
    Crownedcustoms Well-Known Member
    Gilbert
    07 dc 4x4 fox coilovers 20's & toyo mudders
    Fox coil-overs, Fox shocks, 20" Helo wheels, blowthough, Jl and focal system, Grillcraft grill, Toyo Mud terrains
    That's what i was thinking. I put 33's on mine and just want it to drive as if it was stock again. I lost my torque on the hills to flagstaff when i put the 33's on it. Does anyone but toyota sell 4.10's? I know the 4 cylinder 4x4 tacos come stock with 4.10's but they are 800 per axle.
  5. Sep 24, 2010 at 10:14 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    higher rpm's dont always mean less mpg
    with my 33's and stock gearing i get better gas mileage driving at 2500 rpm on the freeway. around town 5th gear is bogged to i drive in 4th at over 2k and UG shows me getting 6-7 mpg better than i would if driving in 5th gear
  6. Sep 24, 2010 at 11:03 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    You could always shop around here for some used 4.10 gears thats where I got mine. Haven't installed them yet but I have them. The 4 cylinder guys normally regear once they start wheeling.
  7. Dec 23, 2017 at 9:00 AM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    Thread revival:
    Don't listen to the low gear propaganda. I put 4.10s in my truck and I fucking hate them. I spent 2k on gears and another 2k on parking brake cables, new rear wheel bearings, and other shit that was crusty and wouldn't come apart nice and now I would have to spend another 2k to get back to where I was. For 6k I woulda rather bought a supercharger and left the gears alone. I have 33 inch tires (32.6) and hit 2500 rpm at 80 mph which is where the truck starts eating fuel like crazy. Also, it's too low to run a decent speed on 4th gear so it's actually worse for towing. If I had 3.73's in 4th gear at 65 I would be around a comfy 2600 rpm instead of 3k which is really to high to cruise in. As for off-road, what the hell else is a t case for, and I always end up wishing my low range box went faster l, because I have never actually needed all the power of 1st in when in low range.
    Summary:
    Worst and most expensive mistake I have made 're my truck. Maybe 4.10's would be good with 35's but with 33's not.
    Kolter45 likes this.
