4-5100's at 1.75 front with 265/70.17 PICS
Discussion in 'Suspension' started by maxpower29, Nov 11, 2011.
  1. Nov 11, 2011 at 5:38 AM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    It took me a while to decide on what suspension/lift to get so I want to give as good feed back as possible to anyone wondering.
    Put the 5100's on and WOW I cant believe the difference. Unreal feeling in the truck now. Went from the stock Bilstein HD (yellow and blue) to these and it makes the truck feel like a full sized truck because it floats over bumps and the road. I am INSANELY happy with it.
    Here is a picture. The tires are 1" bigger, so about 1/2 of lift there and added to the 1.75 in the front its about 2.25" in the front and .5 in the rear. I have the TSB done stock (all canadian Tacos have them) and it sits VERY close to level, with a slight and basically un noticeable rake to the front. Makes it look like a beefy stock look and I love it. Nothing I would change about it. Didnt really hurt my MPG yet either. I lost about 2 mpg with winter gas, and about 1.5-2 with the tires, but nothing since the lift.
    BEFORE
    without tires
    with tires
    AFTER
    I will post more pictures, but Its raining like a bastard now and I dont wanna get wet. Anyone with questions feel free to ask
  2. Nov 11, 2011 at 11:41 AM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    You mention the loss of MPG with the larger tires.
    Are those the E load range tires 55lbs or the C load range 47lbs.
    Trying to figure out how much I am going to loose when I switch tires as well.
    I really cannot believe the E range weigh that much for each tire that is crazy.
    Stock is about 36-38 pounds depending on what brand tire for standard load rating.
  3. Nov 11, 2011 at 11:43 AM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    Looks good, my truck is in the shop now but I have a set of 5100s that I am getting installed at 1.75 once I get it back. Need the extra height for tire clearance.
    To be honest I haven't had my truck that long and I am not sure what leaf pack I have on the rear. I am assuming it is not the TSB as it is a 2006.
    I will eventually add a leaf and 5100s in the rear.
  4. Nov 11, 2011 at 4:14 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ya I dont think till this year they came with the 4th leaf. But I will say, you will like the 5100s. My girlfriend noticed a difference right away and she knows nothing. So much smoother
  5. Nov 11, 2011 at 4:17 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I went with just the C rated ones, but its also the tread pattern that kills the MPG. I like to coast alot to drive it up and these tires have a lot of momentum killing in them. Not TOO bad and I wouldnt change it anyways. Its also noted I went from the stock Bridgestone Dueler 684 II's and IMO they are one of the best MPG friendly tires around.
  6. Nov 11, 2011 at 4:31 PM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    Nice looking truck. I would have got those C range BFG's but they don't make them in 16 inch.
  7. Nov 13, 2011 at 9:19 PM
    go8soccer
    go8soccer Memba
    Grovetown, GA
    '08 Super White DC LB Prerunner Sport
    Leaf TSB, front Billie 5100's (1.75"), 265x70x17 BFG Rugged Terrain
    looks awesome dude! so you just went with the billie 5100's in the front with no new coils, right? I'm about to do the same to mine.. just getting more info.. again, looks GREAT!
