4.56 gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pa blaster, Feb 7, 2012.
  1. Feb 7, 2012 at 8:31 AM
    pa blaster
    pa blaster [OP] Well-Known Member
    Scott
    central pa
    2015 DCSB TRD OR 4x4
    5100's front & rear , Eibach springs, LR uca,Icon progressive aal
    well i just ordered master & install gear kit from east coast gear supply any body ever deal with them?
  2. Feb 7, 2012 at 8:32 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I've heard good things.
  3. Feb 7, 2012 at 8:34 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i have heard good things too. how much did you pay for the 4.56s and master installs if you dont mind me asking
  4. Feb 7, 2012 at 8:36 AM
    pa blaster
    Scott
    central pa
  5. Feb 7, 2012 at 8:38 AM
    97yota4wd
    Eric
    Mesa, AZ
    and that comes already installed in the 3rd member and the front carrier right? all you do is switch them out?
  6. Feb 7, 2012 at 8:42 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I don't think in this case.
    Gonna do the work yourself OP?
    I had 3rds built by ECGS, nothing but happy here.
  7. Feb 7, 2012 at 8:42 AM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    16 Quiksand TRD Offroad
    Fog Light Mod, Pro Grille, raptor lights, 1.25 spacers, RC coilovers
    is it higher # gears for better gas mileage or lower #? i forget stock is 3.73 correct? :threadjacked:
  8. Feb 7, 2012 at 8:43 AM
    PLC721
    Patrick
    Chandler, Az
    It depends on tire size and daily commute.
  9. Feb 7, 2012 at 8:45 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    higher numer lower the gear
    lower the number taller the gear
    torque vs speed
  10. Feb 7, 2012 at 10:02 AM
    pa blaster
    Scott
    central pa
    any guesses as to how its gonna run with fab-tech 6'' 35x12.50x17 pro-comp mt's, trd cai & the hypertech speedometer module
  11. Feb 7, 2012 at 10:55 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    East Coast Gear supply is great. Ordered front and rear from Chase. the guy knows his shit. Worth every penny. Just remember to listen to their recomendation about using Lucas 85-140 and not using synthetic.
  12. Feb 7, 2012 at 12:11 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    is that with 4.10 carrier or with out it (you have your own)?
  13. Feb 7, 2012 at 12:13 PM
    BlueT
    NorthEast
    You using 85-140 in upstate NY. you can cut that oil with knife at -14F :confused:
  14. Feb 8, 2012 at 1:18 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    thats what my reaction was when ECG advised me to use that particular oil. they give a 5 year waranty on their setup. I have had no issues at all in the cold weather (mornings have dipped into the single digits with a few being at zero) and everything is quiet and runs like butter.
  15. Feb 8, 2012 at 8:46 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Pretty sure you don't need a different carrier unless you go to 4.88s or 4.10s.
    Correct me if I'm wrong though.
  16. Nov 19, 2014 at 7:56 AM
    TicoTRD
    TicoTRD Well-Known Member
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    so im looking into getting the 4.56s as well, and I was on ECGS' website and they had all these add on options....not sure what they mean. anybody help?
