4.56s or 4.88s?
Discussion in '4 Cylinder' started by hillbilly taco, Nov 13, 2012.
  1. Nov 13, 2012 at 5:15 PM
    hillbilly taco
    hillbilly taco [OP] Well-Known Member
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    3 INCH LIFT 285/75/16 TIRES CUSTOM GRAPHICS ROLL BAR
    4.56s OR 4.88s with 285s on your 2.7?Is 4.56s enough is 4.88s to much?
  2. Nov 13, 2012 at 5:19 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
    4.88 is WAY too much
  3. Nov 13, 2012 at 5:20 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    X2
    4.56 would be good
  4. Nov 14, 2012 at 2:21 PM
    hillbilly taco
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    I had already ordered 4.88s.but I called company they said I pay 26.00 shipping and send them back.they will overnite me 4.56s for free.Sounds like this will be well worth my 26.00$.Im mostly on the blacktop anyway.
  5. Nov 14, 2012 at 6:14 PM
    Madmax702
    Madmax702 Well-Known Member
    Las Vegas, NV
    2013 AC 4x4
    Could someone explain how/why 4.88's would be too much? just out of curiosity...
    I understand the rpms will be higher at highway speeds, and one would have to shift more often accelerating to speed, but where does the negatives come into play?
    Then, when in 4LO, the gearing would be even lower right??
    How much of a difference is there between 4.56 and 4.88?
    thanks :confused:
  6. Nov 14, 2012 at 6:18 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    I personally don't have either. But, talking with others has led me to say 4.88's. The guys I have talked to said 4.56's weren't enough of a jump to justify the cost of the gears. One guy even went up to 4.88's. Those trucks were 3.4's too. If I were going to regear it would be to 4.88's. Just my $0.02
  7. Nov 15, 2012 at 4:36 PM
    hillbilly taco
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    I run a 4ply 265 in the winter with factory wheels for more power in the snow.Pretty light combo.Would 4.88s be to much ? I run a 8ply 285 in the summer.Almost twice the weight.Would 4.56s be enough?
  8. Nov 15, 2012 at 4:48 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    My suggestion is to look at stock RPMS with your transmission ratios (probably your OD) and stock sized tires and stock gears. Then look again with stock gears and whatever sized tire you run. Then again with 4.56s and once more with 4.88s. All for varying speeds.
    For me with 35s, 4.56s, and 6 spd MT I run 80 mph and 3000 RPMs.
    I wouldn't want higher because I do run 80 with frequency and for long durations.
    Evaluate your needs.
    Might also look at the torque curve of your engine. And see where which gears will put you where at what speeds.
  9. Nov 15, 2012 at 4:51 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    with the 4cyl id deff get 4.88's us 6cyl guys only need 4.56's ........keep the 4.88's will help when u tow or haul a heavy load...expecially if your wheeling.....slightly higher highway rpms are worth the extra power and offroad ability
  10. Nov 15, 2012 at 4:53 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Don't mean to hijack...but I still haven't decided what's best for me....
    35s
    5AT
    4.0 V6
    Lots of highway, lots of offroad.
  11. Nov 15, 2012 at 4:55 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    You can get away 4.88s Jamie, with that auto trans OD your RPMs will be close to mine at 80 MPH
  12. Nov 15, 2012 at 5:00 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Alright thanks. I want 4lo to be nice and low. I don't generally go 80 either. Highest speed limit here is 65. I'll give 4:88 a try.
  13. Nov 15, 2012 at 5:03 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    You'll be golden.
  14. Nov 15, 2012 at 5:06 PM
    hard2kill
    Rhinebeck NY
    agree with max
  15. Nov 15, 2012 at 5:13 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    firm believer in 4,88s here after having them for a couple years - i personally wounldnt go any other way with 33s and the 2,7.
    4.56 would work if you do a lot of flat highway driving without a lot of hills and dont offroad much.
    I get 20 mpg on the highway going 72 mph at 2700 rpm
  16. Nov 15, 2012 at 5:36 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    4.88s here with 33s and a 4 cylinder, LOVE IT. wouldnt do it any other way
  17. Nov 16, 2012 at 11:37 AM
    ARkansasTAco521
    ARkansasTAco521 Well-Known Member
    Nick
    North West Arkansas
    98 tacoma Reg Cab
    Pro Comp 3in lift, steel wheels, Bushwacker fender flares, in progress
    On the subject of reagearing, How can I tell if my truck has been regeared??
    Per sticker on the door it came out with 225/75-r15, one of the previous owners put 31 10.5 r15s on it its a 98 2.7l 5spd originally came with 4.10 gears. How could i tell if they have been changed
  18. Nov 16, 2012 at 1:47 PM
    hillbilly taco
    tommy
    WEST VIRGINA
    09 standard cab 4x4
    Thanks for all input.Thank Ill just stick with my orginal plan.And have the 4.88s installed tuesday.Just wanted some input to make sure I wasnt messing up.But I think up here in the mountains Ill be fine with 4.88s.THANKS AGAIN!!
    Sep1911 likes this.
  19. Nov 19, 2012 at 4:29 PM
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    I thought I heard somewhere that the 4.56s require a different carrier than the 2.7 has. Am I crazy?
  20. Nov 19, 2012 at 5:47 PM
    Mr. Annoying
    Mr. Annoying Active Member
    CT
    2002 Taco x-cab
    4.88 with 33's
    I had that setup was a bit buzzy on the highway I don't do radical off road (hardly any off road)
    I guess it is livable with a quiet exhaust
    4.56 with 33's end up giving you about the same RPM as 265/70/16 and 4.30's (stock)
    off road, local, the way to go
    DD mostly on road an lots of highway 4.56
    just my .02
