4.88 Gears
Discussion in 'Towing' started by spaulding88, Mar 27, 2011.
  1. Mar 27, 2011 at 4:43 AM
    spaulding88
    spaulding88 [OP] Well-Known Member
    Sam
    Lacey, WA
    Tonka Toy
    6" Pro Comp Lift, K&N CAI, All-Pro front bumper and Revenge-Fab Sliders, 285/75/16 BFG TKO's, Tire Rack, Flow-master 10 Series muffler
    I have very little knowledge when it comes to gearing on our trucks. I have a 08 DC TRD off road that I use as my dd and wheel occasionally on the weekends, plus during the summer I haul a 18ft bass boat around. I'm currently running 285/75/16's. I feel like the truck struggles a little while hauling the boat down the freeway at 60mph and its very noticeable while climbing hills. Ive been looking around the threads to find what gears I should try to go with, 4.88's sound like they would do the trick but I'm not sure if that's going to run my rpm's to high and kill my gas mileage while cruising at 60mph
    Any feed back would be very much appreciated.
  2. Mar 27, 2011 at 8:06 AM
    tig1
    tig1 Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    myself I'm hoping to upgrade to 4.56's,I'm just a 4 banger so 4.88's on your truck should do the trick.
    later tig1
  3. Mar 27, 2011 at 10:18 AM
    gtrotter
    gtrotter Well-Known Member
    Interlake, Indiana
    2009 Regular cab 4x4, ARB's, 4.88's, bumpers, 2017 DCSB SR5 stock
    locker,mud tires, lifted, toolbox
    With a V-6 I would stick with 4.56's. I've got 4.88's on my 4 cyl and it is almost overkill with that engine. You've got more than enough power, especially with the 4.56's. 4.88's would have you pulling some pretty high rpms.
  4. Mar 28, 2011 at 5:49 AM
    muddluvr
    muddluvr know it all
    Kalamazoo
    Definitely 4.56 gears..
    I have 285s terra graplers on my 06 prerunner and I started towing a 22' 4500 lbs travel trailer with the stock gears (3.73). I towed it about three times before i upgraded to the 4.56...world of difference..
    before it would struggle to get to 60 and merging onto the freeways was a nightmare.. with the 4.56s it made the truck feel like it has the original power that it had with the stock tires on it..it pulls so much nicer, accelerates faster and merging into traffic is no longer a white knuckle experience while towing the trailer. IMHO 4.88 would be great for towing but you would hate it on the freeways, rpms would be to high..
  5. Mar 28, 2011 at 9:04 AM
    spaulding88
    Sam
    Lacey, WA
    Tonka Toy
    What was the final cost of the gears plus getting them installed?
  6. Mar 28, 2011 at 9:12 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I have 4.88s with a 4 cyl and it's not too bad on the freeways. Plus since you're 6 cyl, I believe your highest gear is higher than mine so that will help at keping the rpms down.
    Gears cost about $700 per axle (parts and labor)
  7. Mar 28, 2011 at 5:47 PM
    muddluvr
    Kalamazoo
    the gears were 225 the master install kit was 231 and a local shop charged me 200 to install.....so around 700 like the man said in a earlier post...
    best bang for the buck i have done to the truck...
  8. May 22, 2012 at 8:43 PM
    imprezzivesti
    imprezzivesti Member
    I have a 2011 Tacoma 4wd on 37's what brand gears are the most reputable for price/performance i'm looking to get 4.88's in the front and rear. and where do I get larger carriers for the front to fit the 4.88's up there? Any links would be appreciated to recommendations.
    Right now I'm on stock gears with the 6 speed manual v6 and while it moves i'd like the power back and to actually be able to use 6th gear on the highway
  9. May 23, 2012 at 5:16 AM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    You might consider 4.1 axle gearing.
    Your tires are 7% larger circumference than stock, which makes it like gearing up by 7%. 4.88 gears is like gearing down 30%, 4.56 like 23%, 4.1 like 11%. Even with the 4.1's, you will effectively be at a ratio lower than stock.
    The alternative, is to leave the gears where they are. You mention struggling at 60 mph, but not getting to 60. Perhaps it would be sufficient to leave it in 4th gear while towing? 4th gear is 28% lower ratio than 5th on your A750 transmission. Leaving it in 4th would be close to running 4.88 axle.
    flying_waitacoma and Tacoblue07 like this.
  10. May 23, 2012 at 9:15 AM
    especk
    Erik
    Redding, CA
    4.88s would be perfect for your application. I have a 4 cyl so I didn't need to worry about a larger carrier - so I can't help you there. Do not consider 4.10s as mentioned below.
    This sounds all bad. First, please show me how 37" tires are only 7% larger than stock. 4.10s are barely going to make a difference pushing those 37s - you are going to need 4.88s to really get your power back. And with that large of a tire, your RPMs on the highway will still be decent so dont worry about that.
    It is not a good idea to just leave it in a lower gear, you need to MAKE all of your gears lower. Think about first gear - this can be the most important at times and the only way to lower this (in your situation) is to regear the diffs. Simply put: your truck has 6 speeds, it will perform much better when you regear so you can actually use those 6 speeds. Trust me, I know from experience, and I'm a doctor :cool:; seriously
    edit: i think knucklehead's response was to the original post over a year ago, not to the most recent post question. So excuse me for treating you like you dont know what the hell you're talking about
  11. May 23, 2012 at 12:44 PM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Eh, my bad. Why imprezzivesti bring back year old thread?
  12. May 24, 2012 at 5:02 AM
    imprezzivesti
    Cause i search instead of asking things that have topics on the forum already? Why start new threads for no reason??
    rjbiii likes this.
  13. May 21, 2013 at 1:13 AM
    NADFUMAUI
    NADFUMAUI New Member
    MAUI
    04 tacoma
    6"FABTECH HEADERS,EXHAUST,COLD AIR,
    I HAVE A 2004 TACOMA AND IS LOOKING TO UPGRADE MY GEARS.I HAVE A 3.4 AND CURRENTLY RUNNING 33'S IN 20X12, I BOUGHT THE TRUCK BUILD WITH ALL STOCK PARTS ON ENGINE AND GETTING HEADERS,EXHAUST,AIR INTAKE INSTALLED BUT I LOVE TO BURN OUT AND WAS WONDERING WHAT GEARS SHOULD I GET ?,I WILL BE RE-LIFTING MY TRUCK AND PUTTING 4LINK IN REAR AND 3LINK IN FRONT WITH THE WORKS OF FOX SHOCKS ALL AROUND AND A FEW COIL OVERS,TRYING TO STICK WITH 33'S NOT 35'S WRAPPED ON 15X16 REALS.HAWAII WE RUN UM WIDE!JUST WANT SOME FEED BACK ON THE GEARING BECAUSE I AM GETTING ALL KINDS OF DIFFERENT OPINION'S FROM A FEW PEOPLE SO IM HERE ASKING THE TACOMA ENTHUSIASTS.WHAT DO YOU GUYS THINK ?
  14. Sep 9, 2016 at 5:48 PM
    Mr.PowerTrays
    Mr.PowerTrays (Formally ROK-NJA) Vendor
    Maverick
    Colorado
    2011 dcsb trd or
