4 all you rock climbers and off roaders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tony2018, Apr 8, 2014.
  1. Apr 8, 2014 at 8:25 PM
    tony2018
    tony2018 [OP] Well-Known Member
    Are you running propane/cng or regular pump gas? I'm just curious.
  2. Apr 8, 2014 at 8:35 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Nobody is running an 05+ tacoma on propane/cng. Fuel injected engines are difficult to convert. There are a few running propane on old 22R's. You lose some power and mileage, but it will run upside down for a little while.
  3. Apr 10, 2014 at 4:01 PM
    tony2018
    So do you guys get air in the fuel lines or engine cutoff, when you're uphill,sideways (not drifting), etc..etc..?
  4. Apr 10, 2014 at 4:05 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    i wheel my truck pretty good and havent had a problem with fuel cutting out.
    im not staight up and down at long periods and basically sitting on the side trying to get through something though..
    you only need propane ect if you are doing extremely serious wheeling. and i wouldnt change anything till your rig actually doesnt get fuel anymore with the way you wheel. it is alot of work
  5. Apr 10, 2014 at 5:01 PM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    You new to fuel injection? You can run a fuel injected rig anywhere it could possibly go and not have fuel delivery problems... I suppose if you were low on fuel to start with you could have some fuel starvation but other than that it's a non issue.
  6. Apr 10, 2014 at 5:16 PM
    smd3
    smd3 Well-Known Member
    I don't think this is true.
    I know it can't be that hard to run newer vehicles on CNG because they are all over the place here.
  7. Apr 10, 2014 at 5:17 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    My 22r used to die on really steep hills. The beauty of fuel injection.
  8. Apr 10, 2014 at 5:22 PM
    smd3
