4" backspacing...will it hurt my truck?!?
Discussion in 'Wheels & Tires' started by headhunter247, Feb 19, 2009.
  1. Feb 19, 2009 at 10:51 AM
    headhunter247
    headhunter247 [OP] Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    Im looking at buying some black rockcrawler rims, and have read that others have had to grind a little on thier calipers with 4.5" backspacing. Will getting 4" backspacing hurt the coponents?
  2. Feb 19, 2009 at 9:18 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    The Back spacing has nothing to do with rubbing the calipers. It's the design of the rims you have.
    Some rims just don't have enough clearance for the Toyota calipers. 4.5" BS is the ideal!
    You need to look into a different brand of wheel.
  3. Feb 20, 2009 at 5:49 AM
    headhunter247
    St. Louis, MO area
    but would the 4" BS do any sort of damage, since its not 4.5"
  4. Feb 20, 2009 at 7:10 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That would put the wheels out farther by 1/2"
    If they're not rubbing the calipers, then you shouldn't have anything else to worry about.
    I have BlackRockcrawler rims w/ 4" backspacing on my jeep - and there's nothing special about them in terms of design and can't imagine they'd be a problem. But - I don't know first hand (on a tacoma that is).
    What wheels are you getting? You should make another post about the exact wheels you wanna buy and find out what everyone else is getting (in BS) and if anything esle has experienced problems.
    And lastly - try to make some phone calls to your local accessories shops. Maybe they'll let you buy/borrow a single wheel with that configuration and you could try it on and see how things fit.
  5. Feb 20, 2009 at 9:23 AM
    headhunter247
    St. Louis, MO area
    Yea, they are the black rockcrawler rims. I work down the street from this 4x4 shop, they would have to order them. I like the look and their cheap!
    Ill make another post..thanks.
