4 Banger Lifts and Tires
Discussion in '4 Cylinder' started by yota17, Apr 20, 2009.
  1. Apr 20, 2009 at 12:32 PM
    yota17
    yota17 [OP] Member
    Arvada, Colorado
    2015 double cab prerunner
    I have seen a couple threads like this in here but most get side tracked and stop posting pics..lol...Lets see what kind of lifts and tires you 4 bangers got..i have a 05 2wd access cab with small 215/70/R15 tires...bout to get maybe a 6 inch prcomp lift and some 31 or 32's...want to see what they look like
  2. Apr 20, 2009 at 2:27 PM
    CaliforniaTaco
    CaliforniaTaco Well-Known Member
    BFG A/T 31/10.5/15's - rubs when I turn full left/right, trying to solve it but nobody knows.
  3. Apr 20, 2009 at 2:28 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    and be careful with the 6", you may have to regear
  4. Apr 20, 2009 at 4:14 PM
    yota17
    yota17 [OP] Member
    Arvada, Colorado
    Not going to lie i am a noob at this stuff so bear with me cuz i am not sure what all that means..like a rear limited slip..and regear..anyone mind filling me in
  5. Apr 20, 2009 at 4:17 PM
    DanGer
    limited slip differential is a differential locker on the rear axel. Google it for a solid description.
    Regear means shanging the gear ratios of your truck to deliver enough power to turn the tires. You need to regear if you lift high or run large tires
  6. Apr 20, 2009 at 4:19 PM
    yota17
    yota17 [OP] Member
    Arvada, Colorado
    ok thanks for explaining it..so its probably a good chance i might have to regear with a 6 inch lift
  7. Apr 20, 2009 at 4:23 PM
    DanGer
    I always thought it was a yes, especially with a 4 banger. It is also dependant on the tire size you run but others will correct me if I am wrong
  8. Apr 20, 2009 at 4:28 PM
    yota17
    yota17 [OP] Member
    Arvada, Colorado
    ok..ya i am probably just going to go with some 31's...does anybody know of a way for me to able to tell for sure if i have to ..or anybody else in a similar situation as me have to regear???
  9. Apr 20, 2009 at 6:19 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  10. Apr 20, 2009 at 7:35 PM
    yota17
    yota17 [OP] Member
    Arvada, Colorado
    ya see thats what i am worried bout now...cuz i dont know if it can handle a 6 inch and 31's without reagering...does it effect that it is a manual...
  11. Apr 21, 2009 at 11:51 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    you have to regear anything above 3 inches
  12. Apr 21, 2009 at 11:16 PM
    john.308
    john.308 Active Member
    Orcutt, CA
    2006 2.7 Prerunner
    Magnaflow exhaust, K&N 77 intake, lift, 16" eagle alloys
    2006 2.7, K&N CAI, magnaflow
    16" Eagle alloys
    Hercules mud 31's
    How's it look?
    ancient11 likes this.
  13. Apr 21, 2009 at 11:30 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    That is one sweet ride:thumbsup:
    What kind of lift do you have?
  14. Apr 22, 2009 at 6:46 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    Maybe I'm missing something here, since I have a gen 1 with a 2.7L. Why would a lift require a regear? Maybe because it increases wind resistance? I suppose that would make a difference on the highway.
    Your tire size may require lower a lower diff gear (higher ratio), and you may be required to add a lift to fit your tires under the body, but I've never heard of the lift requiring lower gears.
    Find out what your diff gear is. Your vin carrires that information and there are guys on this forum who can tell you what gears you have from that. My pickup runs 31X10.50s, which is the largest tire most tire places will mount on it (liability issuses, they tell me). I do just fine. As a matter of fact, I just added 2.5" of lift and intend to go with 33s in the near future. My '00 TRD has a 4.30:1 diff and a manual 5 speed trans behind a 2.7L four-banger. I run 2750 rpm at 65mph on the highway and come in right at 22mpg. My speedo reads about 67 at 65mph by the GPS, so I figure going to 33s will probably correct that as well as bring my rpms down at 65mph. With the 4.30 rear, I should have satisfactory power for my driving, and I have low range for messing in the muck.
    Somewhere on this forum there is a good tire size calculator that relates diff gears to tire size and a range of probable satisfactory performance, relative to stock performance. Look around a bit. You'll find it.
  15. Apr 22, 2009 at 8:52 AM
    yota17
    yota17 [OP] Member
    Arvada, Colorado
    I didnt know because i have had a few people i might have to regear..you said you have a 2.5 lift...does it matter that i want a 6 inch..and does the fact that yours is a TRD have any effect either..probably doesnt but i am not sure bout this stuff so i am asking all the questions i can before i sink a lot of moeny into this stuff..appreciate the info everyone..
  16. Apr 22, 2009 at 9:39 AM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    Actually the automatic trans supplied trucks have a 3:58 rear gear ratio and the manual trasmission trucks have a 3:31 rear. This allows the auto trucks a bit more mechanical advantage to overcome the big tires or/and lift kit. The auto's torque converter also helps with higher launch rpm.
    Motoretro
  17. Apr 22, 2009 at 12:00 PM
    thenrie
    Stafford, VA
    The height of your lift doesn't matter at all regarding gearing. The tire size is what matters. Your tire size can determine the amount of lift you need, though.
    Like I said before, you can determine exactly what gear ratio your diffs carry by the vehicle identification number (VIN). There are several gear ratios Toyota puts into their trucks, depending on the year, options package, trans, engine, and customer special orders. My pickup being a TRD gives me an electric locker rear diff, the 4.30:1 gear ratio, and Bilstein shocks (among a couple other things). Before you decide what tires to put on, figure out what your gearing is and then check out the TIRE SIZE CALCULATOR under the "Mods and Tutorials" button at the top of this page. You'll save yourself a lot of headaches if you will do some figuring before you order.
  18. Apr 23, 2009 at 9:09 AM
    yota17
    yota17 [OP] Member
    Arvada, Colorado
    thanks bro..thats wat ill do
  19. Apr 23, 2009 at 4:12 PM
    BioMed80
    BioMed80 Well-Known Member
    Colorado Springs, CO
    09 Regular Cab
    3" ReadyLift Kit, 31x10.5x15 General Grabber AT2s, AFE Drop-In, Bull Bar, Hella 500FF, Secondary Filter Removed
    Well said. The tires are what affect the gearing more than anything else. Here's a before and after of mine. 3" Readylift with 31x10.5x15. It's a base model Taco (standard trans, 4 cly, etc.). Yes, you can notice a power loss, but not enough for me to regret doing it. I'd do it again in a heartbeat.
  20. Apr 23, 2009 at 7:39 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Every time I see a truck w/ the Readylift Kit installed the more I want to lift my truck. I like your setup.
