4 banger tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smithrw, May 20, 2009.
  1. May 20, 2009 at 3:37 AM
    smithrw
    smithrw [OP] Well-Known Member
    wichita, kansas
    09 tacoma sr5
    Does anyone happen to have experience putting larger tires on a 4 cyl 2 wheel drive. Was tryin to get some idea about how much larger than 205-70-15 I can go and not take too much away from low end power.
    Thanks
  2. May 20, 2009 at 5:24 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Any tire larger than stock will have some impact on low end power. The impact gets larger the more tire you put on. There are 4 cylinder Tacos that are running 31 x10.50s but the drivers tell us they can feel the impact. Unless you plan on some serious mud boggin' I'd not get too froggy with tire size.
    The TacomaWorld tire calculator will tell you the effect a new tire will have over the stock tire.
    And IIRC the standard tire is a 215-70-15, not a 205.
