4 channel amp help
Discussion in 'Audio & Video' started by Justyn98, Jun 21, 2017.
  1. Jun 21, 2017 at 8:17 AM
    Justyn98
    Justyn98 [OP] Well-Known Member
    Justyn
    West Virginia and Kentucky
    09 barcelona red tacoma trd sport DCSB
    Led pod fog light inserts, kn cold air intake, Bilstein 5100 with 2 inch coil combo and progressive AAL. Touchscreen pioneer stereo and infinity components with 2 kicker comp r10's and jones turbine exhaust
    I'm about to purchase a 4 channel amp that is 1200 watts so that means I would be pushing 300 to each door speaker with are pioneer 3 ways it's a planet audio and I can get it for around 85 bucks would 300 watts be to much for the doors since my pioneer headunit pushes 50 watts to each should I get a lower watt amp or stick with it?
  2. Jun 21, 2017 at 9:19 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    300 is peak power not RMS. Make sure you match your speakers RMS with your amps RMS.
  3. Jun 21, 2017 at 9:21 AM
    SigGuy
    SigGuy Well-Known Member
    Sean
    Wilmington, Delaware
    2015 DC SR5
    ADS Coilovers & Camburg UCAs @ Front, Wheelers 5-leaf HD & 5100s @ Rear, Satoshi Grill, Pelfrybilt Rear Bumper, BAK Roll X, WeatherTech Floor Liners and Vent Visors, Wet Okole Covers, @mrmarv/Kenwood/HAT/Arc Audio system
    300 watts is a little excessive for Pioneer 3-ways, but you could always just turn down the gains on your amp to keep from blowing the speakers. Start the gain settings low, and the volume high and adjust the gains until the volume is as high as you'll need it. If the speakers start to distort, drop the gain back a little.
    Justyn98[OP] likes this.
  4. Jun 21, 2017 at 1:11 PM
    Justyn98
    Justyn
    thats probably what i will end up doing
