4 channel amps- Which would you spring for?
Discussion in 'Audio & Video' started by glandnut, Apr 13, 2010.
  1. Apr 13, 2010 at 11:12 AM
    glandnut
    glandnut [OP] Grease Monkey
    Florida
    09' MGM TRD DC Sport LB(gone), 16' 4Runner Trail
    secret stuff.
    More than anything, I am needing advice on those running class D stuff for mids and highs. I like the compactness these amps tend to have, but only have used them for subs in the past. Stick with class AB for mids and highs, or is this not so much an issue anymore?
    I have an Alpine MRP-M450, or my old school Kenwood KAC-823 I'll be running on my sub- not sure which one I'll use yet, but I plan on staggering the sub amp and whatever 4 channel I buy either in the drivers side bin or on an amp board in the same spot. I was all hot to try one of the Alpine PDX amps, but see that they are intended to be mounted flat, not vertical.
    Whatchoo think?
  2. Apr 13, 2010 at 11:19 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I'm using an Alpine MRP F-450 4 channel. Ive got it mounted under the drivers seat. I didn't see it in the Crutchfield web site. It's 70 X 4 and I'm using Polk speakers. I've got no complaints. Here's a picture of it mounted under the seat.
  3. Apr 13, 2010 at 7:59 PM
    glandnut
    Florida
    secret stuff.
    Thanks for the pic, I was wondering what size I could put under a seat- yours is 13-1/4"W x 2-3/8"H x 9-9/16"D, so that gives me a good reference, thanks!
    I can't believe I just stumbled on woofersetc.com-- their prices put my budget into a whole new class of amps!
  4. Apr 20, 2010 at 4:31 PM
    glandnut
    Florida
    secret stuff.
    Ended up going with a Punch P400-4. Walking through Best Buy today and they were on clearance NIB for $199!! Never had any Rockford stuff, but the build sheet shows 77 X 4 rms @ 14.4v, 30% better than the advertised 50 x 4!!
  5. Apr 20, 2010 at 5:47 PM
    tunedx
    tunedx Well-Known Member
    X-Runner
    Alpine PDX-4.150
    4-channel car amplifier
    150 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
    300 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
    variable high- and low-pass filters (30-400 Hz, 12 dB/octave)
    Class-D amplifier design
    stackable installation design with front-panel controls
    quick-connect speaker connectors
    preamp-level inputs
    MOSFET power and output stages
    CEA-2006 compliant
    fuse rating: 30A x 2
    4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
    10-3/16"W x 2-1/2"H x 8-7/8"D
