4 cyl./better gas milage, long bed vs. 6 cyl. 5 speeds, shorter bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airwreck, Feb 19, 2012.
  1. Feb 19, 2012 at 12:01 AM
    Airwreck
    Airwreck [OP] Member
    Tacoma
    I never bought a new truck in my life and never thought I would, but recently I did it. I will be traveling around the U.S. (highways, not off-road)...so I figured I should buy a 4 cylinder for good milage, plus I want to put a camper and sleep in it and the V6 trucks have less bed space...so I tried the Access Cab 4 cyl. automatic and really liked it...for what I need, it seems to be just right...not to say that I don't like the V6 trucks. Now, I'm here trying to reassure myself that I made the right choice. If I'm just traveling highways..do I really need a bigger truck and 1 more gear?
    What do you guys think? Don't be too harsh on me. :)
  2. Feb 19, 2012 at 12:32 AM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2018DCSB TRD Quicksand
    Emu 887x Nitrochargers Dakar Heavys, 255 85 16 ST-MAXX
    OP, u should set up a poll, with all available options for vehicles.you will get a faster result and a much easier read.
    But if u dont feel like it, I vote for a v6 dbl cab with a SIX foot bed. U wont regret it witrh the power and for hauling. Just my 02.
  3. Feb 19, 2012 at 6:16 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    With a camper in the back, I'd probably go with the V6 AC or DCLB myself. The four would use less fuel (and is a very good engine) but the transmission on the 6 is much more robust and more able to take heat in the mountains. I don't know if the 4 speed has a tranny cooler or not.
    Probably with an AAL for the weight of the camper.
    Now if I was using a tent, I'd use a 4 cylinder 5-lug without a shred of a regret.
  4. Feb 19, 2012 at 6:21 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Personally, I like the 4 cylinder. My '99 Taco was a V6 and I felt it had too much power unless you're hauling a trailer. Love my 4 banger with 5 speed. Plenty of get up and go.
  5. Feb 19, 2012 at 7:45 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    If you plan on running 70 to 75 MPH you will see little if any gas mileage difference between the V6 and 4 Cylinder.If you plan on running 55 to 60 MPH or around town you will see a little more gas mileage with the 4 Cylinder.If you don't plan on having rear seat passengers the access cab with the six foot bed is a good choice.Remember that the more weight that 4 cylinder has to haul around the harder it will be on fuel.The 5 luger should get better MPGs than a prerunner or 4X4.The 5 luger has less weight and sets lower to the ground and higher gear ratio that will give more MPGs.
  6. Feb 19, 2012 at 9:38 AM
    Airwreck
    Tacoma
    Thanks for all of the input guys.
    I didn't realize that there was an automatic, 4 cylinder-5 speed available??
  7. Feb 19, 2012 at 9:47 AM
    BlackSeven
    BlackSeven Grab your helmet, this shits about to get retarded
    Maryland
    '10 Reg Cab 4x4
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    I really like my 4cyl reg cab 4x4. I can fit my boys in there, I pretty much only drive it back and forth to work, but it's plenty comfy on the highway. Ton of highway power. I had an 04 frontier with the vg33 and the 4cyl toyota has more power on the highway then my old frontier with a v6. I'm perfectly happy with it, and it gets great gas mileage. I put a tool box in the back to fit anything I can't carry in the cab. I don't think it'll fit a camper shell though, even if it could fit a camper shell I don't think it'd do well with the 4cyl.
  8. Feb 19, 2012 at 9:52 AM
    Airwreck
    Tacoma
    Thanks Black Seven for making me feel better about my purchase. :)
    That was going to be my next question... How will this small 4 cyl. handle a camper shell?? (it won't be loaded down with any other extra weight...maybe some bigger tires later)
  9. Feb 19, 2012 at 9:54 AM
    Airwreck
    Tacoma
    oh...but yours is a 4x4
    5 speed?
  10. Feb 19, 2012 at 10:07 AM
    BlackSeven
    Maryland
    '10 Reg Cab 4x4
    Yes, 5spd manual. And by camper shell i mean like one of the ones that slides in the bed, not a cap.
  11. Feb 19, 2012 at 10:13 AM
    Airwreck
    Tacoma
    I want to get a regular fiberglass camper, to sleep in. Will this be a problem for this small 4 speed truck.
    So 5 speeds are only available on 4 cyl. models as manual??
  12. Feb 19, 2012 at 10:14 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I have the V6, campershell. The truck gets 19MPG on 91 octane (manual trans is lower MPG on the V6). If I was going to be traveling cross country for an extended period of time, and fuel cost was a factor, I would give up the extra power to gain MPG.
    My work truck is 4cyl 5 speed manual with a lot of weight in the back and a high profile shell on it. Never taken a long highway trip in it, but it gets 18MPG in town with a lead foot. I suspect it would get 25MPG highway with a reasonable load and low profile shell. It has plenty of power, just have to rev it up for the steeper hills.
  13. Feb 19, 2012 at 10:46 AM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    '11 DCSB MGM
    Plasti Derp'd Emblems rear bumper and grille. Debadge tail gate, Powder coat OR rims.
    I have a 4 cylinder dcsb and I still haul all my gear for paint balling. And 3 others with two.coolers 10 boxes of paint and 5 people in my truck just fine going uphill about 20 miles from my house. On the first month I had it, I had to move some patio furniture. (table and 4 chairs) 50 miles round trip with 3 full size men. I was surprised it went up hills just fine.
  14. Feb 19, 2012 at 11:34 AM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I had a 96 Tacoma 4x4 5sp with the 2.7L 4cyl in it.
    I also had a slide in Camper which I travelled well over 10,000km's with, with absolutely no issues.
    Actually I turned 400,000 km's with the camper in while up in New Found Land.
    I needed to add airbags, and fuel economy wasn't any better then the V6, but you'll be fine.
    Shawn
  15. Feb 19, 2012 at 3:36 PM
    jsutter
    jsutter Well-Known Member
    Jim
    Southeast Ohio
    08 Reg. Cab 4cyl 2wd
    cruise and intermittent wipers
    No, you should not have any problems. I have a regular cab 4cyl auto and get 26mpg with about 80% highway driving. I had a cap on it for a few months and it made no difference in mpgs or felt power. The 4cyl is a great motor and will give you all of the power you need for your driving and you will get better mpgs compared to the 6cyl.
  16. Feb 19, 2012 at 3:38 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    DCLB FTMFW
  17. Feb 19, 2012 at 4:21 PM
    the.sight.picture
    Nick
    Warren County VA
    4 cylinder doesnt have tranny cooler.
  18. Feb 19, 2012 at 4:24 PM
    the.sight.picture
    Nick
    Warren County VA
    ^^^^^(GOOD INFO)^^^^^^^^^^^
  19. Feb 19, 2012 at 5:28 PM
    Airwreck
    Tacoma
    Thanks to everyone for the info.
    Hey Sutter...was your 4 cyl. truck a 4 speed or 5?
    I'm ok with my new little truck, but it's just the 4-speed thing. I was used to a 5 speed, but now my legs are messed up so it is a pain to drive a standard especially for traveling long periods of time.
    Are 5 speeds available on 4 cyl. trucks only as a manual transmission??
  20. Feb 19, 2012 at 5:36 PM
    brow
    brow Well-Known Member
    Andy
    Minnesota
    17' MGM DCLB SR5 4x4
    5 speeds only come as manuals on the 4 cylinder, and the last year they offered the 4x4, access cab, 4 cylinder, with the 5 speed manual was 2010, they discontinued that combination for some reason.
    If you want an automatic and a 4 cylinder, the only option you have is the 4 speed automatic transmission
