4 cyl to 6 cyl
Discussion in '1st Gen. Tacomas (1995-2004)' started by BroncoBilli, Feb 9, 2020.
  1. Feb 9, 2020 at 4:07 PM
    BroncoBilli
    BroncoBilli [OP] Well-Known Member
    eric
    1998 Toyota Tacoma
    Okay, I'm considering buying a 4-cylinder stick shift Tacoma and immediately putting a v6 into it. I know this will require a new ECU and exhaust header and wiring harness, but I'm a decent mechanic and that doesn't bother me. It has a manual transmission.
    Besides the naysayers that will say "this is a lot of work", what else would I need to put the V6 in there? I'm pretty sure it's the same transmission, and I'm pretty sure nothing would need to change in the dash wiring. I don't know if the cat converter or the muffler need changed out. Don't care about changing out the brakes.
    What are some of the caveats I'd be missing?
    Please, don't go on and on about "just get the car you want in the first place". Answer technical details, don't try to warn me I'm pursuing the wrong thing based on effort or judgment involved. Just the facts - what would it take to swap it out, materially.
    thanks!
    TacomaJunkie8691 likes this.
  2. Feb 9, 2020 at 4:08 PM
    BroncoBilli
    eric
    1998 Toyota Tacoma
    By the way, V6 tacomas in my region (Seattle) are rare if not impossible to find, at a decent price. They're coveted and for good reason. The 4-cylinders, I think, are way underpowered and you can get a 4 cylinder for fairly cheap. The v6's are about DOUBLE in price for the same year/model around here.
  3. Feb 9, 2020 at 4:13 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard
  4. Feb 9, 2020 at 4:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @BroncoBilli
    Interesting that you're running into that situation.
    Tons of members post up 1st gen 4x4s in both I4 and V6 and I hate that they're always below $6k give or take a few hundred.
    In CA that's a whole different story where a 4x4 (regardless of engine) goes nearly double what a Prerunner goes for.
    The V6 won't win any races, and if you're going off road, the I4 with some gearing goes a long way, especially being a stick shift.
    jbrandt and 04Pre_Runner like this.
  5. Feb 9, 2020 at 4:24 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The trans is not the same it's a project have at it but research first about what you are up against. The 4 is a bulletproof engine yep they are short on power but it will get the job done.
  6. Feb 9, 2020 at 4:25 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  7. Feb 9, 2020 at 4:52 PM
    BroncoBilli
    eric
    1998 Toyota Tacoma
    "research first about what you are up against"
    Yes. Exactly. Which is why I bothered signing up for this forum.
    Can't IMAGINE why a v6 would have a different transmission than an I4. Maybe MAYBE a different bell housing and possibly a heavier duty clutch.
    Who on this site knows what MANUAL transmission pairs up w/ an I4 vs a V6? Year of Tacoma is a 1998.
    thanks!
  8. Feb 9, 2020 at 4:53 PM
    BillsSR5
    bill
    2014 SR5
  9. Feb 9, 2020 at 4:56 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Why? What's wrong with the 4 cyl? Maybe you should drive it first... You might actually like it.
    Black DOG Lila and BillsSR5 like this.
  10. Feb 9, 2020 at 5:00 PM
    sandalglue
    sandalglue Well-Known Member
    BC Canada
    2010 4x4 AC SR5
  11. Feb 9, 2020 at 5:06 PM
    BroncoBilli
    eric
    1998 Toyota Tacoma
    Okay, I found this:
    https://board.marlincrawler.com/index.php?topic=35818.0
    it seems like the v6 takes an R151B, and the I4 takes a W59B. I guess they're a bolt-in replacement, except the shifter will move by about 2".
    Can't imagine why this is the case, but oh well.
    Sigh.
  12. Feb 9, 2020 at 5:10 PM
    BroncoBilli
    eric
    1998 Toyota Tacoma
    Man... I can't handle "why don't you" questions... I've driven a handful of I4 tacomas while looking for the right car. I think they're piss poor on power. The Internets agree with me, BTW. Those of you who think the I4 has enough power, congrats on being able to get it to and from Safeway. This is going to be my Ski Truck. It needs to get up and down mountains. Easily.
    Also, I don't want to be in the middle of some jam on I405 in Seattle and not be able to throw it into 3rd and jet out of a death crush. The I4 will just go "unnnghh. Nope."
  13. Feb 9, 2020 at 5:40 PM
    ryfox0276
    Montana
    2013 RC 4x4
    What about a supercharger? LCE and I think URD make kits for the first gens. Idk man, I'm not trying to put you down I just figured if it ain't broke... But if you go thru keep us posted. I love watching swap threads.
    frizzman and Speakerboy like this.
  14. Feb 9, 2020 at 5:42 PM
    Speakerboy
    Speakerboy Well-Known Member
    Jim
    Center Valley, PA
    '02 Xtracab 5 lug manual
    Buy the 4 cylinder and put a small turbo on it. That will give you the power of the v6 without tearing the truck apart to replace the engine trans, driveshaft and rear end (because you know that's different gearing).
    ryfox0276 likes this.
  15. Feb 9, 2020 at 6:24 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Motor mount perches and trans crossmember are in different places.
    Will require cutting/welding.
    Rusty Taco 11 and pairodice like this.
  16. Feb 9, 2020 at 6:24 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Rusty Taco 11 and jacobrippey like this.
  17. Feb 9, 2020 at 6:28 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Engine mount perches as well as trans crossmember are in different spots, you'll be cutting and welding as well. I've had both, the 4 banger is only as intolerable as the driver. My supercharged 2.7 cooked v6s no problem and I wasn't far behind in NA form. Neither engine is a powerhouse
    DJB1 and ryfox0276 like this.
  18. Feb 9, 2020 at 6:31 PM
    Speedytech7
    Also I lived where you do and had no problems conquering passes for over 6 years with the 4 banger and 33" MTs. Wheeled in high elevation with low oxygen content. Itl get you to and from anywhere if you can drive competently. But it sounds like that might be a challenge and if that is then swapping will be even more of one, maybe just buy a v6, I recently got another from Puyallup. They're all over.
  19. Feb 9, 2020 at 6:57 PM
    BroncoBilli
    eric
    1998 Toyota Tacoma
    had no problems conquering the passes with a 4cyl Tacoma? obviously the low oxygen was affecting your sense of speed and what is acceptable Passing The Stonies power. i cant stand being on Hwy 2 behind some
    jacka$& 2wd car going 30 and the opposite lanes are full of carefree semis...
    however, y'all scared me off. i am just going to buy a more expensive V6.
  20. Feb 9, 2020 at 7:09 PM
    Speedytech7
    No prob maintaining 65-70mph at 4800lbs of weight. Even through crazy grades in Wyoming. It's only as bad as your driving.
