4 Cylinder 2015 Taco Acceleration
Discussion in 'Performance and Tuning' started by reminton50, Dec 19, 2019.
  1. Dec 19, 2019 at 7:55 AM
    reminton50
    reminton50 [OP] Active Member
    2015 Pre-Runner 2.7 L 4 Cylinder
    Yep. It is a 4 banger. So it sucks on acceleration. I’ve ok with that. What I am wondering about is there anything in particular I can do to make it accelerate a bit better? I’ve heard cold air intakes allegedly worked on them, but I’ve done reading her and it seems the consensus is it would just make noise. Nothing else. Short of strapping a rocket to the back like Willey Coyote...am I wasting my time?
    whatstcp likes this.
  2. Dec 19, 2019 at 7:56 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    downshift to 3rd gear
  3. Dec 19, 2019 at 7:57 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    SC or turbo....
    BassAckwards likes this.
  4. Dec 19, 2019 at 7:59 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    TheFang likes this.
  5. Dec 19, 2019 at 7:59 AM
    BassAckwards
    Regear is also good option, but its pricey
  6. Dec 19, 2019 at 8:01 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Regear it. Or if you haul around a bunch if extra stuff in it. Take it all out. Maybe lighter weight wheels and tires.
    The only thing that will make a substantial difference is a turbo/supercharger or regear
  7. Jan 24, 2020 at 11:51 AM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    Is yours an auto trans?
  8. Jan 24, 2020 at 11:53 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Gears and Nitrous Oxide.
    Good luck with that.
  9. Jan 24, 2020 at 12:43 PM
    BassAckwards
    I can attest the urd sc helps quite a bit, even down low. Drivability is 100% better than before. Gas mileage is about the same, still shitty. Feels similar to a v6 1GR but with just more power up top.
    Skierrichy and Torspd like this.
  10. Jan 28, 2020 at 7:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A little boost will go a looong way. Makes that 2TR very responsive.
  11. Jan 28, 2020 at 7:52 AM
    BassAckwards
    Couldnt agree more. Dont see more than about 5-6lbs in most driving situations, but the truck is a whole different animal now. Seems like a solid platform to build upon! Im surprised you havent got a little single cab to play with already. Would make for a fun little project truck/daily driver
  12. Jan 28, 2020 at 7:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  13. Jan 28, 2020 at 8:55 AM
    BassAckwards
    Dont blame you there, probably the cheaper alternative vs buying your own lol.
    that is a nice compressor. Im just waiting for the rotrex in my URD kit to take a dump on me, then ill likely be jumping ship and joining the turbo bandwagon:p
    speaking of which, how did you and your friend bypass the blower on his truck? Id kinda like to keep the parts on hand that are needed in case mine craps out on me during a trip. Is it as simple as removing the idlers, changing belts and rerouting the piping with a different silicone fitting?
  14. Jan 28, 2020 at 8:57 AM
    BassAckwards
    I guess you can see my confidence in the rotrex lol. Read a few things about the shafts shearing off, so id like to be prepared for when the time comes inevitably
  15. Jan 28, 2020 at 12:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    A lot cheaper. ;) His is a tax write-off anyway, since it is his work truck. In due time. :D
    I had a few silicone couplings that I used to route around to the intake. The he used an OEM length belt to bypass spinning the blower. Not to sure why the bearings failed on it. Never inspected why. Just needed it running without the blower. It maaaay have been an oiling issue, but I cannot say so with any certainty. Just a guess at this point.
    He already has the same intake components as @05Taco4x4, since he was originally planning on building that engine. It will still be ready when the turbo time comes.
    BassAckwards[QUOTED] likes this.
  16. Aug 3, 2020 at 4:38 PM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    What is a URD SC?
    I have a friend that wants more go go.
    I figured it out, sorry little slow with the abbreviation.
  17. Aug 3, 2020 at 4:43 PM
    BassAckwards
    URD sells or did sell (looks like they're out of stock) a supercharger kit that uses a Rotrex c30-94. Doubles the rear wheel hp of our little 2.7 on stock internals and 93 pump gas. Pretty good little kit
    Skierrichy[QUOTED] likes this.
  18. Aug 3, 2020 at 9:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
