4 Cylinder Load Range Tires
Discussion in 'Wheels & Tires' started by brow, Jan 5, 2012.
  1. Jan 5, 2012 at 8:27 AM
    brow
    brow [OP] Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    Finally looking to replace my stock 245/75/16 dunlops. I have a 4 cylinder 5-speed access cab, stock height. Planning on jumping up to an AT 265/75/16, however everything i can find is generally E rated, which is more than i need for my trucks purposes.
    Anyone have any experience on just how much power/mpg's i am going to lose with a tire thats is that much bigger and heavier? I know i am going to lose something, just wondering how much.
  2. Jan 5, 2012 at 8:31 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I have pretty much the same truck as you, I run 255/75/17 LT Nitto Trail Grapplers on a 3 inch lift
    I'd try and find an LT rated tire. They are a bit heavier, not sure on the exact number, my main power loss is in 5th gear on the highway. As for gas mileage I can't say as I don't really keep up with it too much.
  3. Jan 5, 2012 at 8:32 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Really with these trucks you don't need to go with an LT tire at all, P-rated is over what the weight+payload capacity of our trucks is. The only reason to go LT would be if you are big into offroading and really need the stiffer sidewall.
  4. Jan 5, 2012 at 8:35 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Agreed. I'm running P-rated tires on my double cab V6 4x4. I have a shell and a decent amount of weight in the bed at all times, tow, haul, etc. No issues with P-rated tires.
  5. Jan 5, 2012 at 8:37 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    Yeah makes sense. I just didn't want a 200 dollar to get ripped open down a trail somewhere.
    P-rated tires OP!
  6. Jan 5, 2012 at 8:38 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    If you stay stock size you can get a pretty agressive AT in C load
    I went with hurcules terra trac at, LT245/75R16 in C load, had same tread debth as E loand
    here is their spec page http://www.herculestire.com/catalogHercules/pdfCatalogPages/28_terraTracAT_2011_2012_english.pdf
    Other thing I considered was the goodyear duratrac
    shown here at tire rack http://www.tirerack.com/tires/tires...WDTOWLV2&vehicleSearch=false&fromCompare1=yes
    Part of the reason i stayed with 245 was for skinny in snow. I don't go too rough in summer so the stock size in more agressive have been just the right match for me. I like the hrcules just fine, just not as showy as the goodyears.
  7. Jan 5, 2012 at 8:40 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i have e loads on my 4 banger it was the only load range in my tire size and model the company made at the time.
    they are heavy but, tough i guess. i'm really wanting to switch out to a set of 295 cooper stt's they look awesome.
  8. Jan 15, 2012 at 12:00 PM
    ATweezy
    ATweezy Well-Known Member
    Brad
    Arizona
    11 Red RC 4x4
    I think you will find out that P-rated tires are going to be adequate for everday use and light offroading/trailing. I just recently bought Hankook RF10s P265/75R16 and they are an awesome tire. I went trailing with a buddy yesterday and the hankooks performed great in the sand and in the rocky trails by the mountains. He had BFG ATs on his Jeep and had some issues with traction in the sand. If you want something with a stiffer sidewall but want to save on weight, go with the Goodyear Duratrac in LT265/75R16 in Load Range C. Onlinetires.com has the best price on the duratracs that I have seen and treadlightly.org has the new 2012 goodyear $100 rebate form.
