4 Cylinder Oil Capacity Not Correct In Manual?
Discussion in '4 Cylinder' started by GrnXnham, Oct 17, 2017.
  1. Oct 18, 2017 at 2:52 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I changed my oil recently and used about 5.7 qts with filter. Dipstick is spot on after letting the oil circulate.
    TheCookieMonster likes this.
  2. Oct 19, 2017 at 4:46 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    The capacity is 6.1 quarts. This is for a new engine with no oil in it. When you drain oil, there is still some in the system clinging to the components. It really depends on conditions as to how much will stay in there (temperature, etc ..)
    davidstacoma likes this.
  3. Oct 20, 2017 at 8:33 AM
    uwu
    uwu Well-Known Member
    When I first got my truck, I did 6 quarts as recommended by the manual, that has me about an inch above full on the dipstick... one 5 QT jug gets me right to full on the stick... so weird. I've changed my oil 7 times in the last year (one of those weirdos that changes ever 5k miles) and 5 quarts is the ticket for me.
  4. Oct 20, 2017 at 8:33 AM
    uwu
    I wonder what's wrong though, the manual or the dipstick?!
    TheCookieMonster and SOSC like this.
  5. Oct 20, 2017 at 8:50 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    This subject has been talked about a lot on this forum. I go by the dipstick. I end up putting anywhere from 5-5.5 qts back in my 2.7. There is always oil left inside during an oil change depending on the "slant" you may be on. I change mine now on a driveway that is pretty steep. I change it, add 5 quarts and then drive it to a level spot somewhere and top it off. I've now figured out that if it's about 1/4" below full on the steep driveway then it's just about perfect. I doubt anyone will ever get a full 6.1 into a 2.7 unless it is a new engine with no oil in it at all. 5.5 qts with a filter change gets me about 1/8" above the full line on the dipstick but that can change depending on how level the spot is that I'm checking it on. As long as I'm within an 1/8 or 1/4 of an inch either way I'm happy.
  6. Oct 20, 2017 at 8:52 PM
    TRVLR500
    Wyoming
    You're correct. A little underfilled is better than overfilled. Overfilled can blow seals. Up to a qt underfilled hurts nothing.
  7. Oct 20, 2017 at 8:54 PM
    TRVLR500
    Wyoming
    From what I have read on this subject the golden rule is to obey dipstick readings. That's what I do and no problems. That is also what the dealers are told to do. I suspect that if you do an oil and filter change on a 2.7 and add 5 qts "after" filling the filter as well you'd be good to go without ever even bothering to check the dipstick.
  8. Oct 23, 2017 at 12:51 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I've owned my 2.7 for 8 years and nearly 100,000 miles, done 98% of the maintenance myself, and the oil change process has become VERY routine. I am so confident that 5 qt will put the level in the middle of the dipstick's normal range, a few times I have actually driven away without ever checking the dipstick. I check for leaks at the filter and the drain plug and of course check the oil light is not on. But otherwise, put on a new filter and dump in 5 quarts and bam - done. I think many of us worry too much about the oil level being exactly at the full mark.
  9. Oct 23, 2017 at 4:21 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Service department puts 6 quarts in and a new filter on mine and calls it good. Works for me.
  10. Nov 9, 2017 at 7:09 AM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    I been putting 5.5 in mine since the 2nd change.198,000 and counting.every 5000 miles so I've changed its lot.
  11. Nov 9, 2017 at 6:03 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I did an oil change at 15k, per here I filled with 5.5qt let her run for a few minutes then checked the dip stick. Put it right on the F mark so I’ll stick with that.
  12. Nov 20, 2017 at 9:00 PM
    tuanhuy0301
    tuanhuy0301 Well-Known Member
    2017 Tacoma SR DCSB 2.7l 4X2
    I went home from work and let the oil drain for 2 hours, change the filter and fill up 6 qt. Turn the car on 10 minutes and pull the dip stick out let it park overnight and it right at full mark.
  13. Dec 7, 2017 at 12:23 AM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    So I have been told by toyota.....the 4 bangers hav more oil because the gear ratios are lower and it requires higher revs to be driven in traffic than a v6 does at the same speeds. Take that how you will.
    Greenbean likes this.
  14. Dec 11, 2017 at 10:29 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    It's true that after putting in 6 my dipstick reads a tad high. I still put in six (with new filter every time) and call it good. That slight of an "overfill" isn't going to hurt anything.
    that said OP 4.6 seems low. Typically people say 5.5-5.75 fills up the 2TR with filter after running it. Did you run the engine a bit after filling then let it sit?
  15. Dec 11, 2017 at 11:09 AM
    #35
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I put in 6 quarts per the manual. It's always above the top line on the dipstick. I've had no problems.
    You will find many threads on this.
  16. Dec 19, 2017 at 2:48 PM
    #36
    Teuton
    Teuton Well-Known Member
    2011 Reg Cab 4x4, 2021 TRD sport, 2024 TRD Sport
    I always go by the dipstick (which is completely useless in the Taco). I usually do 5.5 quarts with filter and it reads about a quarter inch above the full line.
    Keep on Truckin' likes this.
  17. Dec 23, 2017 at 5:55 AM
    #37
    weazleburger
    weazleburger Well-Known Member
    Baton Rouge, LA
    07 base reg cab 5-speed
    6qt, send ehht
  18. Dec 23, 2017 at 7:23 AM
    #38
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    I like to think of it as over engineered, lol...
    Oil=Lifeblood of the engine...
    Another great thing about the 2.7 if you ask me. I do think the 2.7 has to be working a bit harder to achieve the same results comparatively to the V6.
    In reality I believe the most important goal is engine temp which leads to oil temperature as well. Oil does indeed lubricate but it also has some temperature regulating ability. Case in point is my Land Cruiser with the 4.7L holds just over 6 qts IIRC, but has a beautifully designed remote oil filter housing with its own door in the front “skid” aka gravel guard lol... It also is the cooler for the oil and has coolant circulated through it to help cool the oil. It sits barely above the oil pan lever so if you can just change the filter you barely loose @1/2 of oil.
  19. Dec 29, 2017 at 1:24 PM
    #39
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    2.7 = 5.5 Qts. w/ filter change
  20. Dec 30, 2017 at 10:30 PM
    #40
    TRVLR500
    Wyoming
    I'd suspect you are talking about oil/engine temp. My 2.7 runs very cold once the temps get below 30 degrees. Oil temp usually runs about 20 degrees below water temp. I just installed a grill cover last summer because my 2.7 runs way below 180 degrees once the temp drops well below 30 degrees.. It never gets past 179 degrees. Even in the summer sometimes. With the grill cover completely closed I still never see 180 degrees when the ambient temp is below 30 degrees. Before the grill cover? If it got down to 0 degrees I never saw the temp get past 165 degrees.
    That's just too cold for a modern day engine. Temps that cold can mess with the emissions systems even on a 2004 engine. With the cover I have installed I can maintain 179 degrees even when the temp drops to well below 30 degrees around town.. I'll have to wait and see how it does once it gets down to 0 and below. I like to see 180degrees when out on the interstate but that never happens even with the cover completely closed at less than 30degrees. Around town I get 180+ with the cover closed below 30 degrees but the temp drops out on the interstate.
    Greenbean[QUOTED] likes this.
