4" Lift with 33" Tires Rubbing Please Help
Discussion in '3rd Gen. Tacomas (2016+)' started by Buckshot-12-Coon, Jul 11, 2019.
  1. Jul 11, 2019 at 9:19 PM
    Buckshot-12-Coon
    Buckshot-12-Coon [OP] Active Member
    Josh
    2018 Tan Tacoma TRD Off Road
    Stock for now
    Just did my first MOD on my Tacoma, Which was 4" lift with P285/70R-17 117T Open Range and 17" -18 Off set Black Rhino Wheels. I'm rubbing on the corner fender and a little on the frame. I came here to see if someone can tell me the best way to fix this i don't want to cut unless i really have to maybe spacer would work better for me?
  2. Jul 11, 2019 at 9:22 PM
    RangerComa
    RangerComa High Speed Dirt Limo Adventure Rig
    Adam
    Bay Area, CA
    17 DCLB
    list is growing fast
    you did a drop bracket 4"? start by getting a good alignment.
  3. Jul 11, 2019 at 9:27 PM
    Buckshot-12-Coon
    Josh
    Stock for now
    Less Schwab did it all
  4. Jul 11, 2019 at 9:29 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    .......so take it back to Les Schwab and tell them it’s rubbing....:deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse::deadhorse:
  5. Jul 11, 2019 at 9:33 PM
    crx7
    crx7 Well-Known Member
    Grand Junction Colorado
    From what I've read and personal experience, the only 33" that fits is a 255/85/16. The 285 width usually requires cutting.
    BTW, the height of your lift only helps rubbing on regular roads. Off road the lift does nothing for fitting a larger tire when you stuff the tire all the way up in the wheel well.
    For you, 285 width 33 will often require a CMC (cab mount chop). Get your angle grinder and welder out. Have your alignment shop give you 1 to 2 degress of caster for your lift which will push the tire forward, and start cutting.
    Oh, and don't blame Les Schwab, they most likely aligned it to factory spec, which is 0 degrees camber, which sets the tire pretty far back.
    dhillr likes this.
  6. Jul 11, 2019 at 9:48 PM
    JaCado
    JaCado Water Janitor
    A spacer will make it rub worse. Only way to fix is cut and trim.
    El_Rocinante likes this.
  7. Jul 11, 2019 at 9:48 PM
    Buckshot-12-Coon
    Josh
    Stock for now
    Wont putting Camber where tires all crazy??
  8. Jul 11, 2019 at 9:50 PM
    JaCado
    Do you have aftermarket uca's?
  9. Jul 11, 2019 at 9:51 PM
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    I’d blame LS. All that work done with alignment and they didn’t even road test the vehicle afterward?? HA
  10. Jul 11, 2019 at 9:52 PM
    JaCado
    If he has stock uca's there is no way to get the caster above 3 to move the wheel forward
    El Duderino likes this.
  11. Jul 11, 2019 at 9:56 PM
    Matmo215
    Matmo215 Baylor '23
    Matthew
    Denton, TX
    2011 DCSB
    Get to trimming the plastic and cutting the cab mount:sawzall:
  12. Jul 11, 2019 at 10:01 PM
    crx7
    When I put on my 33's and had it aligned they made me sign a disclaimer saying it would rub and if it did, it was not their fault. Tech was cool and did his best and it only rubbed on the mudflaps, which I removed. This was Firestone. You have to realize, it's not their job to custom align vehicles. If you want a custom alignment to fit tires that most likely need cutting of the wheel well, then you need to take it to a 4wd shop.
    I blame thinking a 4" lift cures all.
    Sclarpepplar likes this.
  13. Jul 11, 2019 at 10:03 PM
    PapaRee
    PapaRee And now I'll do what's best for me
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport DCSB OVTuned
    OVTune, Raceline Assault 18x9 -6 Offset wheels,Falken Wildpeak ATW3 265/70/18 tires, GTS Dobinson's suspension lift, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro grille, Raptor grille lights, Pro Shift Knob, Predator side steps, RedLine Hood Struts, tinted windows, ProTuning Black HID headlights, Morimoto 55w 6500k HID kit, LED Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed light, LED reverse lights, LED license plate lights, Tacoma tailgate 3d decals, removed air dam, Custom TRD Sport emblems, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso ECT Stealth button on Pro knob, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Wheel spacers-front 1", rear 1.5", Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, Pro Rigid fog lights.
    Tell them to increase Caster to 2-4. Not camber.
  14. Jul 11, 2019 at 10:35 PM
    Buckshot-12-Coon
    Josh
    Stock for now
    Yes
  15. Jul 11, 2019 at 10:37 PM
    Buckshot-12-Coon
    Josh
    Stock for now
    They did they but they didnt tell me and by the time they got everything done and I paid they was already clocked out and lock the door behind me it was about 7:10 when I left
  16. Jul 11, 2019 at 10:40 PM
    Buckshot-12-Coon
    Josh
    Stock for now
    Either way I'm going back tomorrow I didn't just drop 4k at there shop to get half ass shit I noticed some loose shit and ungreased parts by the time I got home. Also i might add there gaps on the lower arm like there spose to be bushing there but there's not your guys thoughts??
  17. Jul 11, 2019 at 10:42 PM
    JaCado
    Pretty sure the gap is normal.
    Have them adjust the caster to about 4 and see how the handles. Toe and camber still as close to 0 as they can.
  18. Jul 11, 2019 at 10:42 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Pics?
  19. Jul 11, 2019 at 10:43 PM
    El_Rocinante
    El_Rocinante Well-Known Member
    Pete
    2019 Cavalry TRD OR dcsb 4X4
    :confused:
  20. Jul 11, 2019 at 10:51 PM
    Buckshot-12-Coon
    Josh
    Stock for now
    How will that effect tire ware?
