4" Lift with 33" Tires Rubbing Please Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Buckshot-12-Coon, Jul 11, 2019.
  1. Jul 11, 2019 at 10:51 PM
    El_Rocinante
    El_Rocinante Well-Known Member
    Pete
    2019 Cavalry TRD OR dcsb 4X4
    Terribly!
  2. Jul 11, 2019 at 10:52 PM
    Buckshot-12-Coon
    Buckshot-12-Coon [OP] Active Member
    Josh
    2018 Tan Tacoma TRD Off Road
    Stock for now
    I will post some in the AM
  3. Jul 11, 2019 at 10:52 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    As long as toe and camber are close to 0 it will not effect tire wear. Caster just pushes the wheel forward, zero effect on tire wear.
  4. Jul 11, 2019 at 10:53 PM
    Buckshot-12-Coon
    Josh
    Stock for now
    That's what I figured thought I would ask for shit and giggles
  5. Jul 11, 2019 at 10:53 PM
    tcjacado
    tcjacado Well-Known Member
    Normal wear
    El_Rocinante likes this.
  6. Jul 11, 2019 at 10:55 PM
    El_Rocinante
    Pete
    I’m
    Totally wrong for certain!
    Clearwater Bill and tcjacado like this.
  7. Jul 11, 2019 at 10:56 PM
    medic2230
    Murph
    Bama! Roll Tide
    Caster should be as close to 3 as they can get. Camber and toe at 0 with the lift.
  8. Jul 11, 2019 at 10:56 PM
    Buckshot-12-Coon
    Josh
    Stock for now
    Well 2 out 3 says it's fine
  9. Jul 11, 2019 at 10:56 PM
    El_Rocinante
    Pete
    Make it 3
    tcjacado likes this.
  10. Jul 11, 2019 at 10:57 PM
    medic2230
    Murph
    Bama! Roll Tide
    Make it 4.
    tcjacado and El_Rocinante like this.
  11. Jul 11, 2019 at 10:57 PM
    tcjacado
    I have seen the caster run as high as 5
  12. Jul 11, 2019 at 10:59 PM
    Buckshot-12-Coon
    Josh
    Stock for now
    So tell them 2 and try it out at first? If I do this I still worry about when I'm off road I mean God sakes I'm not building a street queen so do the caster and still trim it up??
  13. Jul 11, 2019 at 10:59 PM
    medic2230
    Murph
    Bama! Roll Tide
  14. Jul 11, 2019 at 11:00 PM
    medic2230
    Murph
    Bama! Roll Tide
    Try what I said caster 3, toe and camber at 0. That's where I'd start with a 3" lift. 4" may need a little more but start at 3.
  15. Jul 11, 2019 at 11:03 PM
    #35
    tcjacado
    If you do the caster, there will be minimal trimming, but it will be on the front fender instead if you keep going past 4. Not sure with that lift, but you may need to hammer the pinch welds then seal with rtv and heat gun the fender liners to make the new contours.
  16. Jul 11, 2019 at 11:04 PM
    #36
    medic2230
    Murph
    Bama! Roll Tide
    How do you use the truck?
  17. Jul 11, 2019 at 11:05 PM
    #37
    tcjacado
    Lol, it was my friends truck. He had 285 17 and had it moved up to 5 to keep from rubbing. He eventually put it back to 3 and did the proper cmc for it.
    medic2230[QUOTED] likes this.
  18. Jul 11, 2019 at 11:17 PM
    #38
    Buckshot-12-Coon
    Josh
    Stock for now
    Getting to remote hunting and fishing spots nothing really crazy me and the wife do plan to do some overlanding as well
  19. Jul 11, 2019 at 11:20 PM
    #39
    Buckshot-12-Coon
    Josh
    Stock for now
    I will do the caster at 3 but still going to do the trim and cut the pinch weld just in case I watched some vids and it does not look bad at all. Give me excuse to buy a welder as well lol
  20. Jul 12, 2019 at 12:05 AM
    #40
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    You need to provide the whole story?
    What type of lift are you running?
    What UCA did you get?
    What tires do you have?
    What are the wheel specs. Not just the off set. -18 doesn't really tell us anything without knowing the width of the wheels? (Unlless you're saying you have 17" wide rims???)
    Picture would really help.
    285's on 9" wide wheels even running Spidertrax spacers on a 3" lift would only rub a little. (if the caster is set correctly)
    Makes me doubt that you have 4" lift on there?
    Unless you're runnng 14" wide wheels?
    It is impossible for anyone on the internet to help you unless you provide all the important information. Picture would help a lot!
