4 LO ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4X4SUPERWHITE, Feb 12, 2013.
  1. Feb 12, 2013 at 5:16 PM
    4X4SUPERWHITE
    4X4SUPERWHITE [OP] Active Member
    My 2011 with 17K won't enage in L4, only in H4. Is this a common problem??:confused: I have read the owner's manual. All I get is a four -wheel indicator flashes & buzzer sounds.I have used it before with no problems.
    I wish my truck had the older style 4x4 shifter.:mad:
  2. Feb 12, 2013 at 5:22 PM
    Jib Bandits
    Jib Bandits Pork eating crusader. An "infidel".
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Red devil horn emblem, All-Pro Expo leafs, Fox shocks, K&N CAI, aFe throttle body spacer, Flowmaster american thunder dual exhuast, Defender roof rack, Hell Bent steel level kit, Rigid Dually LED lights, smoked halo headlights, smoked LED taillights, Cobra CB, red badge mod(+30 HP), Spider-Trax wheel spacers!
    Did you put your truck in neutral before switching from 4H to 4L? You have to be nearly stopped and in neutral or it'll just flash and beep at you.
  3. Feb 12, 2013 at 5:23 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This
  4. Feb 12, 2013 at 5:25 PM
    4X4SUPERWHITE
    Yes, its in neutral and not rolling. I have used it before.
  5. Feb 12, 2013 at 5:33 PM
    Jib Bandits
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    :notsure: Well... any more info you can give us to work with? Sorry, haha it's just easy to start with the simple stuff.
  6. Feb 12, 2013 at 6:08 PM
    OZ-T
    Peter North
    British Columbia
    The clutch has to be depressed in the manuals too does it not ?
  7. Feb 12, 2013 at 7:09 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Yes
  8. Feb 12, 2013 at 7:11 PM
    Dewey7015
    Dewey7015 Well-Known Member
    Massachusetts, USA
    2018 TRD sport
    With mine, the clutch pedal has to be almost pushed through the floor.. Nothing like regular shifting..
  9. Feb 12, 2013 at 7:12 PM
    OZ-T
    Peter North
    British Columbia
    That's what I thought
    There seems to be a lot of people who have had issues because the clutch pedal was not fully depressed
  10. Feb 12, 2013 at 7:32 PM
    moondeath
    Pa, Gardners
    Yeah. Mines touchy enough that sometimes when I'm trying to start my truck the starter will stop from me letting the clutch pedal come up just a little.
  11. Feb 12, 2013 at 7:36 PM
    4X4SUPERWHITE
    I will remove the floor mat and try to see if that works. Thanks
  12. Feb 13, 2013 at 12:29 PM
    OZ-T
    Peter North
    British Columbia
    any update ?
  13. Feb 13, 2013 at 5:23 PM
    4X4SUPERWHITE
    I removed the floor mat and it worked.:) I must have had the different floor mats when I used the 4L last time. Thanks for the clue.
  14. Feb 13, 2013 at 5:25 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Now trim the floor mat so it doesn't restrict the clutch pedal. :)
  15. Feb 13, 2013 at 6:08 PM
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
