4 Low in snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by louis, Feb 8, 2010.
  1. Feb 8, 2010 at 6:28 PM
    louis
    louis [OP] New Member
    maryland
    07 tacoma sport
    I dont understand something I have a 07 Tacoma sport and was in 30in. of snow stuck and spinning tires. My question is when I switched from 4h to 4L my tires didnt spin and I drove through the snow. The problem wasnt me being bogged down it was loosing traction so why did I gain traction? Does something engage like the axle or locker and on the sport it has a limited slip from what Im told. Any opnions?
  2. Feb 8, 2010 at 6:30 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    4 low is geared lower.
  3. Feb 8, 2010 at 6:34 PM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    That doesn't change the fact that he had no traction....
  4. Feb 8, 2010 at 6:47 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    It changes the fact that you get less wheel spin. more torque.
  5. Feb 8, 2010 at 6:48 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    That's true. Touche'
  6. Feb 8, 2010 at 6:56 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    lower gearing also you have the limited slip so the truck will transfer power to the wheel's with grip!
  7. Feb 8, 2010 at 6:56 PM
    TacoSupreem
    Hayden
    Kentucky
    no locker on the sporty's!
  8. Feb 8, 2010 at 7:04 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I saw you comment about 30" of snow, had to be Maryland. I can't answer your question but I also have an 07 Tacoma 4X4 Sport double cab. What I can tell you is I also experienced the unbelievable traction from 4WD low in 30 plus inches of snow.
    The truck was awesome!
  9. Feb 8, 2010 at 7:10 PM
    TacoSupreem
    Hayden
    Kentucky
    oh and welcome to TW!
  10. Feb 8, 2010 at 7:20 PM
    louis
    maryland
    07 tacoma sport
    Thanks for the welcome. I dont believe sports have the locking rear. Yes from Md. lots of snow for us and more to come. I also have a CJ and put chains on the tires and had great traction but the tacoma was stuck in the driveway in 4wd h and I was going from drive to reverse to get it free and nothing but when I switched to 4wd low it came free. It amazed me enough to research why it worked in low but not in high.
  11. Feb 8, 2010 at 7:22 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I used 4 lo but started in second gear. I had chains on the front and the rear locked. I was pushing people through the 20 some inches of snow
  12. Feb 8, 2010 at 10:03 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    You will have a button on the left of the steering wheel for a locking rear differential, and an instruction lable on the door. On the rear differential will be the locker bolted onto it. Those things if nothing else tells you if you have a rear locker.
    You MAY very well have a mechanical LIMITED SLIP rear differential... Too bad you don't have an owner's manuel in the glove box!
    In L4, the Tacoma (and CJ) will have MUCH greater low end torque (power) for chewing into the mud and snow. You probably don't need chains on the CJ... Use LOW RANGE and go slow, but sure!
  13. Feb 9, 2010 at 1:49 PM
    louis
    maryland
    07 tacoma sport
    thank you good info.
  14. Feb 9, 2010 at 4:40 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    4Lo isn't for low traction enviroments. It's for more power and stability (not in a physical movement of the truck way, in a control of the acceleration way). It effectively doubles your torque so in low traction enviroments it's going to cause more wheel spin if you give it the chance. However, what it helped you do, was lower the speed of your tires giving you consistent power.
    Hope that's not too confusing.
  15. Feb 9, 2010 at 5:58 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    The lower gearing just allowed you to maintain a lower wheel speed, instead of the wheels breaking free and spinning, as was evidently happening in 4HI.
  16. Feb 9, 2010 at 6:04 PM
    TBAGRR
    TBAGRR Well-Known Member
    Md
    07 4x4 sport
    Trd intake Doug Thorley long tubes URD short shifter Eibach front springs Tsb rear leafs
    sports dont have a locker, just a limited slip diff!!!!!
  17. Feb 9, 2010 at 6:07 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Maryland's getting the smackdown tonight into tomorrow with the snow. 20" or more near Baltimore and Frederick. We're only getting 8"-14" here in NoVa. Which is a little better than the 32" we got over the weekend.
  18. Feb 9, 2010 at 6:08 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Doesn't your traction also depend on what shape, type of tires you have?
  19. Feb 9, 2010 at 6:10 PM
    PA452
    Western PA
    Yes.
