4 runner's front and rear diff on my taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by djo991, May 29, 2013.
  1. May 29, 2013 at 6:59 PM
    djo991
    djo991 [OP] Active Member
    07 Double cab SR5
    Nothing on it .... FOR THE MOMENT
    anyone have done this here ???
    swap the 2 diff( both with e-locker ) from a 4 runner 2005 4x4 4.0L to a tacoma 4x4 4.0L 2007 rear diff is the 8.4'' but i will sell it , keeping the housing and install the 8'' with locker from the 4 runner and put the front too with the locker.
    i've seen on east coast guear supply that the front diff is the same 8'' apparently fits on tacoma/fj/4runner
    the biggest question .. will it work :O and will the lockers work
  2. May 29, 2013 at 7:07 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Your post is kind of hard to understand
    4runner is coil sprung in the rear. If you are wanting to swap the entire rear axle assembly you will need to cut off the existing coil and link brackets and weld on leaf perches. If you are only wanting to swap the third into your existing housing that will not work. Assuming you have the SR5 (as it says in your profile) with the 8.4" rear axle the 8" e-locker rear will not bolt into this housing.
    If you are installing into a truck without e-locker you will need all of the electronics to go with the locker in order to make it functional.
  3. May 29, 2013 at 7:13 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    ^great first post. Somebody actually knows what their talking about. Why can't more new members be like you lol
  4. May 29, 2013 at 7:37 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Yes difficult to understand but to the best of my knowledge, in the states, the 4runner never came with an e-locker in the front. The rest of what you seem to be talking about would be difficult at best and very impractical if even possible. Why not find an e-locker out of a junk Taco and install it in the rear? I do not think that Toyota ever offered an e-locker for the front of any of their vehicles.
  5. May 29, 2013 at 7:42 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
  6. May 30, 2013 at 3:02 AM
    djo991
    07 Double cab SR5
    thank you , yes i was expecting to keep the 3rd member and install it with my current housing . then i will look in a junkyark thank you
    the seller told me the front can be locked too , that's why i want it , but i dont even know if its true ,
    the guy told me he will sell me all the electronics thing to make it work
  7. May 30, 2013 at 3:30 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    No e locker from any vehicle will fit into your existing axle, without so serious mods to the axle housing. After that drama you will have a unreliable axle.
    Eastcoastgearsupply.com
    Arb air locker and compressor.
    Easy day.
