4 WD question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DocD, Dec 1, 2010.
  1. Dec 1, 2010 at 9:12 AM
    DocD
    DocD [OP] Well-Known Member
    Mn./SoCal
    09 access cab
    This is my first Toyota and my first truck that does not have lock-outs, my question is this, When I use the truck in 4WD I get a noticeable "Clunk" sound when I switch it back into 2WD, not all the time, but just once-in-awhile, is this something to be concerned with or is this normal, Thanks, Doc
  2. Dec 1, 2010 at 9:16 AM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    Its normal, for me it usually happens when I disengage the 4wd and still have my foot on the gas. It usually won't happen when I let off the gas then disengage while coasting. :)
  3. Dec 1, 2010 at 9:17 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Mine does it too
    Many here claim it is normal but my question has always been why didn't any of my previous Toyota's do it
  4. Dec 1, 2010 at 9:22 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    ^This.
    You can avoid the clunk completely if you're driving in a straight line when engaging/disengaging and let up on the gas (take all the strain off the drivetrain) the moment you flip the switch. If you're turning or under load, you will almost always get the clunk when engaging/disengaging due to the pressure on the drivetrain. Of course, doing it this way isn't always avoidable, but you'll know in advance of flipping the switch whether you'll hear it or not based on what you're doing at the time.
  5. Dec 1, 2010 at 9:24 AM
    ink junky
    TACO LOVER
    TEXAS
    ^ This ^
    :D
  6. Dec 1, 2010 at 9:28 AM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    x2
  7. Dec 1, 2010 at 10:02 AM
    DocD
    Mn./SoCal
    09 access cab
    Thank-You Doc
  8. Dec 1, 2010 at 10:12 AM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    My 92 with manual hubs clunks at times
